Question about Kenmore 44072 Front Load Washer
Moldy smell in front load washer
Oder coming from my front load washer, making my clothes smell moldy. already tried baking soda.
  • beandawgs Jan 11, 2009
    Can anybody tell me where to find the drain plug for this type front loader washer - Kenmore 44072 - I have that horrible smell and affresh does work, but I also want to clean out the drain plug
  • beandawgs May 11, 2010
    I did open the bottom panel but still can't figure out where the drain plug is....
    President:
  • Kenmore Master
  • 2,651 Answers
Www.affresh.com this will help with odors, also make sure you are using HE detergent and little bit at that(2-3 tablespoons)
Posted on Oct 12, 2008
What lime scale / detergent remover can be used for regular cleaning of my front loader.
Front-loading washing machines are energy efficient and use less detergent than top-loaders, but they sometimes have a tendency to harbor mold and unpleasant smells. By giving your washing machine a quick clean once a month, you'll keep your front-loader fresh, which means cleaner clothes, too. This eco-friendly method doesn't use bleach, costs only pennies to make, and comes together with ingredients you already have on hand.
What You'll Need:
  • 2 cups vinegar
  • 1/4 cup baking soda
  • 1/4 cup water
  • Scrub sponge
Directions:
  1. Start by mixing together the baking soda and water in a small bowl. This is going to be the "detergent" for cleaning the washing machine. Pour the vinegar into a measuring cup and head over to your washing machine.
  2. Add the baking soda mixture to the detergent container of your machine and pour the vinegar into the drum. Set your washer to normal load at the hottest water setting. Close the door and start the machine, letting it do all the hard work for you. The baking soda and vinegar naturally break up mineral deposits and any mold growth while cleaning and refreshing your washing machine.
  3. Use a clean scrubber to rub around the opening of the washing machine, removing stubborn mold or residue. Wipe clean with fresh water.
  4. Your washing machine is sparkling clean and ready to do a load of laundry! Give your front-loader a cleaning once a month to keep your clothes smelling fresh and your machine working in tip-top condition.
Mar 20, 2015 | Washing Machines
Getting a smell out of a kenmore front loading washing machine
If you have a smelly front loading clothes washing machine, toss in a Finish Geltabs (the ones that are all liquid) and run the machine on a hot wash cycle, medium to heavy load (to get more water in the tub) with no clothes in the machine. You don't need to use much of a spin cycle so set it on low. The washing machine will come clean and even the moldy spots on the rubber gaskets will disappear. A second treatment may be needed if the smell is not completely gone. We tried everything from vineger to bleach to baking soda to borax to commercially available odor removers from Whirlpool and Tide. Nothing worked until I hit on this idea. It's cheap, easy and can be done anytime your machine needs a refreshing. I used the orange Geltabs but any fragrance would be fine. Keep the door on your washer open a bit when possible to air out to help preclude thiose nasty smells.
Aug 14, 2014 | Washing Machines
Bad smell from front load Miele washing machine
If you have a smelly front loading clothes washing machine, toss in a Finish Geltabs (the ones that are all liquid) and run the machine on a hot wash cycle, medium to heavy load (to get more water in the tub) with no clothes in the machine. You don't need to use much of a spin cycle so set it on low. The washing machine will come clean and even the moldy spots on the rubber gaskets will disappear. A second treatment may be needed if the smell is not completely gone. We tried everything from vineger to bleach to baking soda to borax to commercially available odor removers from Whirlpool and Tide. Nothing worked until I hit on this idea. It's cheap, easy and can be done anytime your machine needs a refreshing. I used the orange Geltabs but any fragrance would be fine. Keep the door on your washer open a bit when possible to air out to help preclude those nasty smells.
Nov 02, 2013 | Miele W4842 touchtronic series 27" front...
Front loading Samsung washing machine smells from mildew. I have tried to clean the gaskets to no avail. What should I do to correct this problem.
Aug 03, 2013 | Samsung WF337AA Front Load Washer
Mildew odor in the machine....can't get rid of it and makes clothes STINK!
Oct 21, 2012 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Our front-loading HE washing machine delivers
try putting in 2 caps of a citrus or pine bleech straight in to the drum with some old rags. then select a boil wash. the rags will spray the water around the tub, the bleech will clean the tub and make it smell fresh. DON'T put any clothing in whilst doing this. if you are worried about bleech in the machine just select a rinse cycle after. i do this once every 3 months
Aug 05, 2009 | Maytag MAH2400A Front Load Washer
Maytag neptune front load odor
its better do a maintenance, or put it to wash without cloths, only water and clorox, and varsol with the max level (water)
Nov 12, 2008 | Maytag Neptune MAH5500B Front Load Washer
The clothes smell if left in the washer wet overnight
Wet clothes should not be left in the washer over night as mold will develop and cause a moldy odor. You could run the load through a rinse cycle with fabric softener or baking soda to get rid of the odors.
Jun 07, 2008 | GE WHRE5260E Top Load Washer
Moldy smell in front load kenmore washer
I had the same problem. Have you cleaned the filter under the front panel? Simply remove the three screws holding the panel below the door and remove the 2" white screwcap. Be sure to have a basin handy to catch the water. (possibly a couple of gallons if the stainer is really clogged) I suspect you'll find several moldy items that are causing the odor. Good luck.
Feb 28, 2008 | GE WSXH208A Front Load Washer
Kenmore 44072 Front Load Washer Logo
234 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
