Question about Jl Audio 500/1 Car Audio Amplifier
Clarification for jl amp problem
Nah thats not it. and nothing has changed. I had a kenwood amp with the two kicker subs for almost three years and it blew out. i got the jl and it worked for 4 weeks. The subs are 8 ohm and were connected in series. does that have anything to do with it? do you know if there is a fuse inside the jl amp that i might have blown for having too much resistance.
  • Inno Laur May 11, 2010
    Too much resistance wouldn't be an issue, the higher the resistance the less demand on the amp.
    I'd wire the subs in parallel for starters, that'll get you a 4 ohm load (assuming you have two subs at 8 ohms each) which the amp will have no problem with and you'll get lots of power. The 500/1 is a very robust amp........I connected a load to one years ago that I had miswired and it was somewhere around half an ohm and although it had virtually no control over the woofers, it just kept on working! Quite a good amp!
    Do you have a multimeter? Disconnect the subs from the amp and meter the leads from the subs to make absolutely sure you have a load that's more than 2 ohms.
    Problem Solver:
  • 12 Answers
Sounds very much like resistance was an issue and no they dont have an internal fuse sorry
Posted on Jan 30, 2009
A kicker 600.1 wired to a jl w7 10" sub? Will that work?
The kicker 600.1 provides 600 watts at 2 ohms and 300 watts at 4 ohms the 10" JL W7 has 2 1.5 ohm voice coils so you will have to wire them in series. Take about 1.5 feet of 14 gauge wire and connect the positive of one voice coil to the negative of the other then the positive and negative that are left go to the amp. Your impedance should be 3 ohms and that amp should work just fine.
Jan 14, 2016 | Kicker Car Audio & Video
JL Audio 1000/1 v2 distortion problem
Make sure all your connections are tight , really tight . Check ground , make sure it's to clean shiney metal. Three subs are going to have a low ohm load if paralleled . These amps are not 1 ohm stable ,if below 1.5 ohm's you will have problems. They need to be series paralleled to raise the ohm load. These amps put out the same power from 4 to 1.5 ohms.
Mar 14, 2012 | Jl Audio Car Audio & Video
I have a Kenwood DNX8120 installed in a Jeep Wrangler(4dr). Running a 4 channel JL Audio amp for mids and highs and mono JL audio amp for the single 12" sub. Tried to have the deck tuned by two...
I do not know what sub woofer and speakers you have and how they are installed, don't change the JL Audio amplifiers, they are very good amplifiers. Also amongst others, I have been using Kenwood in my installs for many years and believe them to be one of the top brands for head units. The unit that you have is a good, very good unit, honestly. In a nut shell, the equipment that you mention are all top class and if functioning correctly, should not be the cause of your disappointment. Low quality cables, bad installations or even incorrect tuning, are often the guilty party in cases such as these. You could fill me in on what else you have and what kind of box the sub woofer is in and what car they are installed in? Search for the source of your disappointment somewhere else. dreamsystems.
Feb 22, 2011 | Kenwood Car Audio & Video
It just stopped working after about 4 years. the amp went in and out a couple of times then it just stopped working.
ok what type of amp are we talking about, what impedence and voice coils are your subs, and have you checked power, ground, fuses, etc... a quality amplifier kicker, jl, mtx, rockford... etc... should, if set up and wired properly, last you a very long time... I actually had a kicker amp since 96 and it still worked great to the day i gave it to my buddy... That's 11 years old with no issues...
Dec 12, 2009 | Jl Audio 300/4 Car Audio Amplifier
I want to know the best subwoofer wiring diagram for three kicker cvr 10 inch subs, 2 of them are dvc 4 ohm and 1 is dvc 2 ohm, the amp that i am using is jl audio 500.1 1.5-4ohms stable. can anyone help...
if the amp has a 2 outputs then i would wire the two 4ohms together, and the 2ohm by itself. and if its a 4 channel output then wire them all sepretly, if its a 1 channel output then wire the two 4ohms together and leave the 2ohm sub out
Nov 29, 2009 | Kicker CVR10 Car Subwoofer
I wonder if i get two kicker cvx 10 can be push by jl audio 500.1
It can but it'd be a waste for your subs. 1 of those by itself will handle that amp. it'll push them just not really hard, i'd recommend an upgrade to a 1100-1200 watt rms amp if you're gonna run 2 cvx's. if you only run one sub that amp'll work well...
Oct 08, 2009 | Kicker CompVX CVX104 Subwoofer - 10" Dual...
Best amp for Kicker Sub
Hello dalex7,
The Kicker 08ZX400.1 would be a great amp for your subwoofer. It will work into a 4ohm load with no problems.
But you can buy an amp with more power, looks better, has a smaller footprint, and cost less than the 400.1. I'd look at the Alpine MRP-M500. Take a look at it here at Crutchfield. The M500 is also easy to install, runs cool, and is very efficient.
Hope this helps.
May 21, 2009 | Jl Audio CVR12 Kicker 12" CompVR Series...
One of 2 subs stopped working.
ya the sub is blown or the amp channel is blown
Apr 09, 2008 | Jl Audio 12W3 Car Subwoofer
Added another amp to system now subs dont hit as hard
This sounds odd, but try putting your subs out of phase from the mains. Just see if it changes anything.
Feb 16, 2008 | Jl Audio 250/1 Car Audio Amplifier
500/1 v2 and one kicker VS12L7
It will work fine. This amp is stable to 1.5 Ohms, but is designed to put out about the same amount of power at 2 or 4 Ohms (unique).
Feb 03, 2008 | Jl Audio 500/1 Car Audio Amplifier
Jl Audio 500/1 Car Audio Amplifier Logo
118 people viewed this question
Top Jl Audio Car Audio & Video Experts
Mark Skinner
Tygh Duval
Tygh Duval
hoyzee1
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
