Question about Seagate HDD 40GB 7200RPM ATA100 2MB (ST340014AP) Hard Drive
Dual seagate hd on pl 2506 controller, only one drive detected.
I contacted the manufacturer of the chipset in my external hd enclosure. The chipset is PL2506. It says it can handle two ide drives on the same controller. Question is this: I have two identical seagate 40 gigs attached to the enclosure. The only drive that is detected is the one jumpered as master. It doesn't matter what the second drive is jumpered as. It isn't detected unless I switch the master from one drive to the other. Then the first isnt detected. It's like the controller is refusing to recognize the attached slave. What wire(s) need to be present/absent in a 40 conductor ide cable for this to work?
  • 1 more comment
  • danman1453 Oct 12, 2008
    I tried that... read the question a little better... I want to know why the controller is refusing to "see" the second drive, regardless of cable position and jumper position.
    ok, just tried switching cables... cable works in desktop. desktop cable is same result in external. only master is detected.
    the only time there are no jumpers is slave. already tried cable select. would the models of the hds be helpful?
    Sergeant:
    Champion:
  • 334 Answers
Yes it does matter what second one is jumpe dto it must be slave on middle of ide cable end of cable master one slave on sec drive do it
Posted on Oct 12, 2008
  • 1 more comment
  • nick helpap
    nick helpap Oct 12, 2008
    well it has to be on right jumpers to see matsr on top slave jumper in middle of cable ok go in bios make sure controler is on or defult bios or upgrade bios if u have to ok change the cable ide cables can go bad try anther
  • nick helpap
    try both on cable select then and does one say it dont need jumper if its on master
  • nick helpap
    i see whatthey are on ide ch not useing cd rom ide 2 r u use 1 only main one cleaer cmos once pins 2and3 for sec then back on 1 and 2 pins for cmos clean out is ther updated bios avb heklp suport it maby bad hard drive did u formatt it ntsc quck ?
Transplanting Hard drive from Seagate Free Agent go flex to another enclosure. I believe the power supply is dead only one light comes on and it just beeps
Here's one case. They're not terribly scarce, but not found just everywhere, either.
http://www.amazon.com/Aluminum-External-Drive-Enclosure-Silver/dp/B000F3WB0Y
Jul 07, 2011 | Seagate Free Agent Go Small 12 GB USB...
To be able to ship the hard drive back for repair
When your hard drive goes bad, you have to contact the manufacturer of your computer. They will replace it, if it is still under warranty.
If it is a hard drive that you installed, then you have to go to the manufacturer of the HD's website, IE: Western Digital, Seagate etc., and request a RMA to return it. When you return it, you will lose all the data that is on the HD. Try to back it up, before you send it. This can be done by installing the bad hard drive into an external USB enclosure. Or setting it up as a secondary HD in another computer.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Jo
Feb 12, 2011 | Office Equipment & Supplies
My seagate momentus 5400.2 external hard disk can't be detected by any computer. doesnt show up in the device manager, or anything. the light is on, for some reason, sometimes it blinks red/green,...
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge" guarantee.
Dec 12, 2010 | Seagate MOMENTUS 5400.2 - HARD DRIVE -...
My seagate external hdd 500gb is not working and is not detected and regonised in any pc..
* the USB cable
* the power-adapter
Nov 07, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
I have been using Seagate FreeAgent on this dell laptop with Windows XP for about 2 years now. But since last evening, i am unable to detect it on my computer. The freeagent is plugged on, the orange light...
The external storage device has several major components:
* USB cable
* external power-supply
* disk-drive inside the enclosure
* USB-to-disk-drive adapter inside the enclosure.
Try a different USB port on your computer.
Try a USB port on a different computer.
Take a multi-meter, and measure the output voltage/amperage of the power-supply,
and compare with the specifications on the label of the power-supply.
Open the enclosure, and remove the disk-drive, and attach it as a "slave" drive in a desktop computer, to see if bypassing the USB-to-disk-drive adapter bypasses the problem.
Look at the label on the disk-drive, for manufacturer, product-number, serial-number, and manufacture date. Access the manufacturer's web-site, and use "check warranty status" to see if the warranty still is valid. If so, the drive can be replaced, at minimal cost to you.
Buy a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Search online for a professional "data recovery service". For a significant fee, they can repair your disk-drive, just long-enough to copy your files to a new disk-drive. Seagate's web-site has an data-recovery offer: no charge if we cannot recover your files.
Nov 05, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
My mac wont read my external
Connect it to another computer, to see if the Seagate device works at all.
If not, then disassemble the enclosure, remove the disk-drive, purchase a new, compatible, disk-drive, and install it into the enclosure, to "revive" your external storage device.
Is the manufacturer's warranty still valid? If so, exercise the warranty, to get a replacement, at minimal cost to you.
Nov 02, 2010 | Seagate FreeAgent Pro 500GB External USB...
PC does not detect Seagate 500GB external hard drive
Try using the device on another PC & see if it works. if it does then you have a issue with your PC. whast the OS you are using? also try another USB port.
May 06, 2010 | Seagate Free Agent Go Small 12 GB USB...
Seagate FreeAgent Pro Desktop 250GB - no power
go get a external drive enclosure from computer supplier
compusa
best buy
circuitcity
Feb 04, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Windows xp drivers for seagate ST3160203U2-RK
Drivers are not needed for this Ext HDD.
If you go to your Computer Management>Storage Devices,you will have to assign a Drive letter for it to show in your "My Computer" as a External Hard Drive.
Also ensure that drive is set as "slave" and do not connect until computer is booted to Desktop.
All changes will take effect after reboot.
Feb 02, 2008 | Computers & Internet
Seagate HDD 40GB 7200RPM ATA100 2MB (ST340014AP) Hard Drive Logo
183 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
