Question about Toshiba 51HX83 51" Rear Projection HDTV-Ready Television
Sound is out for all inputs on Toshiba 51HX83
I hooked up a new cable box and couldnt get any sound. I thought it might be the box, but the playstation and wii dont have sound either. did i blow something?
  • patapus Oct 12, 2008
    I reset the sound... there was not a specific output setting.....still no luck.
There is a switch on the back of the TV for center input. Make sure you have this set to OFF.
Posted on Dec 28, 2008
    Sergeant:
    Champion:
  • 334 Answers
Cheak sound output settings on tv ect defult them
Posted on Oct 12, 2008
  • nick helpap
    nick helpap Oct 12, 2008
    cheak the new cable box is soudn pout put in its menu use pcm not digital dolby k
My Toshiba 62hm195 DLP HDTV's HDMI ports have been losing sound intermittently. Both HDMI ports while connected to multiple devices (HDTV cable box, Panasonic Streaming Player) lose sound intermittently...
Your problem is in the streaming player. It is not keeping up and when an HDMI loses connection it will not auto find it again. To verify this take the Panasonic out of the loop and see if this fixes it. I love HDMI but it is touchy
Feb 18, 2015 | Toshiba 62HM195 62 in. HDTV DLP TV
I have a toshiba 43ax60 has sound no picture and the power light stays on when powered
you need to explore menue for tv options and select the proper input as well as other options.
Sep 17, 2012 | Toshiba 43AX60 43" Rear Projection...
Toshiba 51HX83... what kind of lamp/bulbs and what size do i need to bring the brightness back?
your model doesnt have a lamp it has three CRT (Picture tubes) often just cleaning the rear mirror will restore brightness. If that doesnt do it then the CRT coolant may need to be replaced.
Aug 06, 2012 | Toshiba 51HX83 51" Rear Projection...
I have a Toshiba D-VR16. How do I copy a VHS video onto a CD?
Just put the tape and a blank cd in and just press the Copy from the case.
Aug 10, 2010 | Toshiba Televison & Video
57H83 57 in. Rear Projection HDTV Television: I have a Toshiba 57H83 and recently purchased the ...
I would suggest to leave your directtv hd/dvr box connected the way It is.
The HD Colorstream 1input on your TV should work just fine.
This TV does not have an HDMI input but you can buy an adapter and connect to DVI/HDCP IN and that might be able to get 1080i video resolution on your TV.
Jun 30, 2017 | Toshiba 57H83 57" Rear Projection HDTV
Stereo hook up to my 51h84c toshiba
YES YOU CAN DO IT BY YOURSELF. IF YOU HAVE A STEREO, IT SHOULD HAVE AUX INPUT...YOU WILL NEED AUDIO CABLES, RED AND WHITE...CHECK AT THE BACK OF YOUR TV, WHICH SAYS...AUDIO OUT..PLUG THAT TWO CABLES COLOUR CODE MODE...AND THIS END YOUR CABLE GOES IN YOUR STEREO AUX INPUT...ON YOUR STEREO SWITCH TO AUX AND SAME TIME ON YOUR TV....SO YOU WILL BE ABLE TO HEAR SOUND
Oct 14, 2009 | Toshiba 51H84 51" Rear Projection...
Sony Wega Trinitron HDTV Blue Screen with Sound
Had similar problems with HD cable on dvd. swapping with another cable solved the problem.
Aug 11, 2009 | Televison & Video
I have a 1997 sanyo tv and would like to hook up an older toshiba dvd player and playstation for my kids. I also have a cale box to this tv. When I hook everything up the cable works great. I can only...
The only way this is possible is if you have individual inputs (1,2,3) and use the input button to switch between. You should have at least 2, check the back, and even should have one in front. Make sure the inputs don't share audio inputs, it will say on the cabinet.
Jan 12, 2009 | Televison & Video
Hooking up to digital cable box
Darth,
There are 2 ways you can accomplish this.First is the least quality which is via coax.What you want to do is connect the cable service coming from the wall to the input on your cable box.Then the TV output on the cable box goes to the input on your surround sound then the coax goes from the surround sound to the coax input on the TV.The second is to Connect using the RCA AV1 input.what you want to do is look at the back of the digital cable box and locate the OUTPUTS for the RCA jacks(or AV output)connect RCA cables (yellow red white) to the 1st INPUT on your surround sound.depending on models you should have a couple of different INPUTS for a signal.Choose one and plug it in.After that take a second pair of RCA cables and connect them to video OUTPUT on the surround sound and connect them to your AV1 OUTPUT on your TV.With the original remote for your TV,NOT the cable universal one,Look for an INPUT button on the remote.Some are called input some are called SOURCE,TV/VIDEO basically it tells the TV what signal source to look at on the back of the TV.If you dont have the remote put the TV on channel 3 then press the channel down button and when the TV gets to channel 1 press it again and it should start cycling through the AV inputs,choose AV1.
Once you have done this you have correctly
hooked everything up,BUT Like I said depending on the model of surround sound you are going to have to CHOOSE or physically select or "tell" the surround sound receiver which input to RECEIVE the sound through.In general the INPUT on the back of the surround sound will be labeled with something like Video IN,VCR IN, DVD IN and so forth.Make sure the surround sound is selected to Receive the sound coming from the digital box.Sometimes there is a dial on the front of the surround sound that allows you to select which INPUT on on the back becomes active .make sure that what you have selected matches what you have your cable box is connected to.Hope this helps!
Nov 03, 2007 | Pioneer HTD-510 System
Toshiba 51HX83 51" Rear Projection HDTV-Ready Television Logo
144 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
