Question about Roper Washing Machines
The agitator on our roper washer seems to have spaeated in the middle as the bottom half still agitates but the top now does nothing but sit there.
    President:
  • Roper Master
  • 2,651 Answers
There are what they call agitator dawgs that have probably stripped out, think i might have saw a video on how to repair them on you tube (search whirlpool agitator repair). simole enough to do you will need to remove the agitator using a 7/16 socket. Part number 80040.
Posted on Oct 12, 2008
My roper washers top half of the agitator stoped
you will need a flat blade screwdriver long plyers 7/16 socket and ratchet, the verry top of the agitator prys off look verry close you will see a spot to put the screwdriver, then take the plyers and carfully reach in side and pull on handle of the domed shaped piece gently. then remove the 7/16/ nut. then lift off the corkscrew top portion of the agitator. you will see 4 tear drop shaped pieces called dogs part # 80040, look at the way there in there so they can be put back right later, use a camera take pictures as you go to each step for reasembly.the thrust washer will probly need replacing to, it's the plastic washer that the cork screw part sits on. when you go to put it back together use some vasaline where the dogs go in the holder, this will help hold them in place durring assembly. look close at holder for square holes they need to line up with the flat pins on top of lower portion of agitator. use an exstention and a large socket to hold dog holder in top in agitator top wile puting it on lower half. use the bag the dogs came it to hold the bolt in the socket til you get it started, then pull bag off before tightening. use two exstentions to put inner cover back in then put main cover on you are done,be pacient this may test your pacients.
Jan 08, 2010 | Roper Washing Machines
Washer does spin but barely agitates
It sounds like the agitator dogs are worn.
To remove the agitator, pry off the agitator cap and remove the bolt that holds down the agitator. With the bolt out pull up on the top section of the agitator (auger) to remove it. Underneath the auger you should see 4 small white or beige plastic gears (dogs). . Replace those and it should be ok.
The part number is 80040
Let me know if you need more assistance.
Apr 08, 2009 | Kenmore Washing Machines
I have a kenmore 110 238 121000
remove agitator cap remove bolt in middle of agitator top section will pull of replace the 4 dogs (slightly off white objects whirlpool part # 80040)
Dec 22, 2008 | Roper RAB2121KW Top Load Washer
Machine will not aggitate
remove center cap on agitator remove 7/16 bolt in middle of agitator replace pull center of agitator up sharply replace agitator dogs in center section whirlpool part #80040
Dec 19, 2008 | Roper RAS8445KQ Top Load Washer
Agitator gear is stripped
just place both feet on the agitator as it sits on the floor and lift up on the top half. there are plastic tabs on the bottom half that hold the two pieces together. you will need to remove the 2 tabs before putting the 2 pieces together. the bolt that you screw the agitator down with will hold the 2 pieces together. Joe
Dec 03, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Roper washer, agitater stripped?
It sounds like you need to replace your agitator dogs (yes, there is such a thing). They are small plastic pieces that are used by the upper portion of the agitator to grip as it turns. This is a common problem when they wear out. If you go to searspartsdirect.com, there's an illustration of what I'm talking about under the "Agitator, Basket and Tub Parts" heading. Item number 10 (part number 80040) is what you need to replace. Just type in your complete model number in the "Search by Model Number" block. The following link provides you with step-by-step instructions on how to do this:
http://www.fixya.com/support/r823955-replacing_agitator_dogs
You can find these same parts at repairclinic.com and a cheaper price. Use the part number provided. I hope this helps you.
PS The item is priced for a package of 4.
Aug 06, 2008 | Roper RAX7244KQ Top Load Washer
Roper RAX4232KQ - Top part of agitator won't turn
you need to install new agitator dogs . very in expensive. remove cap on top of agitator reach in and remove opaque cover. you should see a 1/2 " bolt remove that and pull up on agitator. pull apart two halves. disassemble. install four dogs. reassemble in reverse order
Feb 06, 2008 | Roper RAX4232KQ Top Load Washer
Washer fills and spins but does not agitate
Im sorry to say, it sounds like the transmission in the washer may have gone out, the unit it self sits at the bottem of the main agitator shaft under the the tub, you may be able to have this replaced, but shop around for the right price.
Jan 26, 2008 | Washing Machines
Agitator won't agitate
Replace what is called the dogs in the agitator (part number 80040? i think)
Oct 29, 2007 | Roper RAS8244KQ Top Load Washer
Washing Machines Logo
64 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
