Question about Canon Cameras
The LCD monitor on my SD 200 is not functioning. When the camera is turned on the screen is bright amd shows vertical colored lines in the bottom left corner, a grey blue patch in the top left and a purple blob in the top right. It is the same with the card in or out and none of the function keys make any difference.
  • Canon Master
  • 4,738 Answers
Sounds like a cracked LCD screen. You may be able to fix it if you can find a replacement screen. I usually search ebay for a broken camera with other problems that I can cannibalize. Here's some examples on LCD replacement, including one for your camera. Don't recommend that you try this yourself, unless you have some experience and are comfortable with electronics.
http://camerarepair.blogspot.com/2007/11/fixing-or-replacing-broken-lcd-screen.html
Otherwise, the cost of professional repair is beyond the value of this camera. A better option is to sell the camera on ebay for other repair hobbyists to replace the screen for themselves. You actually may get a good price for the camera IF it's still capable of taking pictures:
Posted on Oct 12, 2008
Vertical strip of flashing horizontal lines on Acer Aspire 7551G screen
More than likely it's the lcd screen and will have to be replaced. I could be the video card, but most likely the lcd screen especially when you can put pressure on the screen and cause changes. To isolate the problem try connecting another monitor to the computer. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the laptop. If the Borrowed monitor displays ok, then the problem is with your lcd screen and the video card is ok. If the Borrowed monitor displays the same as your lcd screen then the problem is with your video card inside the computer.
Plug in an external monitor and see if the display shows up on it. It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If so that proves your video card is ok. The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
Once you narrow it down to the lcd screen as being the problem you might try taking the lcd screen apart to reseat the lcd cable on the back at the top of the lcd. Just unplug it and plug it back into the connector. You can also try doing the same where the lcd cable plugs into the motherboard. Just pull it out and put it back.
May 31, 2012 | Computers & Internet
Sceptre 47inch flatscreen lcd has purple line vertical 2 inches from left through entire screen and all channels
is it solid lines or do they flicker, come and then go based on what colors are on the screen. Also does the interlace spread the horizontal line from top to bottom and bright colors?
Jun 20, 2010 | Televison & Video
Vertical white line near the left end of the screen.
Usually when there are colored lines on the LCD its because the screen is going bad. Quick way to verify this, try a different monitor on your computer and if the line goes away then you know for sure the monitor is bad.
If you try a different monitor and the line remains then you know that the video card is bad.
Jun 03, 2009 | Mitsubishi Power Adapter for DiamondPoint...
Screen turned black
your monitor got a hardware problem:
1) the LVDS controler board out of work, only change or repair it could be fixed.
2) if you can see some show like smaller signal detect windows in the centre of screen a very short time (bright flashing one time), this is inverter board damaged or worn lamps, thay all need repair or replace
hope give you some idea. please take a rating let me know how much helped you thanks!
May 20, 2009 | Dell E176FP 17" LCD Monitor
Screen shows blurry vertical lines instead of image
It is failure of ccd imager chip in your Sony DSC-T1 camera and Sony will repair it free of cost.
Click Sony CCD Imager Support for details.
May 20, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
Reddish tint on the screen
LG 700e
power suply is dad
resistanc is black not show it ohom
plz help
Dec 21, 2008 | LG Studioworks 700S 17" CRT Monitor
Black Line bottom of LCD Monitor
May be a manufacture defect or the Screen goes wiped out during transportation.
Call to the support for warranty issues immediately.
Regards
Ellin
Sep 26, 2008 | Samsung SyncMaster 204B 20.1" LCD Monitor
Occasional colored vertical lines on the screen at startup
base on our experience.... you are looking at a possible screen problem. Is it serious? yes as the screen replacement costs almost half of the total cost of the laptop.
but no harm trying this
1. remove the screws from the LCD bezel, remove the screen
2. detach the cable and reinsert them all both the inverter and the flex cable.
inverter is the circuit usually located at the bottom of the screen and the flex cable is the ribbon that runs from the laptop to the back of the lcd.
reseat them and see if your display improves
Apr 09, 2008 | Sony VAIO PCG-K23 Notebook
Dell lcd monitor with vertical lines
You have a filter problem, check power supply for bad capacitors.
Mar 24, 2007 | Dell E173FP 17" Flat Panel LCD Monitor
Cameras Logo
63 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
