Question about Refrigerators
The fridge/freezer(Hoover Contour frost-free)doesn't go at all. It used to work Ok for about 10 years.
  • maree270 Nov 27, 2008
    I have a hoover contour refrigerator - model number HE430TF. Both long drink shelves in door have broken and the company tells me they are no longer available. Fridge is 11 1/2 years old and otherwise running fine. Can anyone help?
5 Suggested Answers
  • 212 Answers
SOURCE: hoover classic fridge/freezer frost free - fridge
check your vents for good air flow
Posted on Jun 21, 2009
kel1guy2002
  • 3740 Answers
SOURCE: Fridge part now working
Hi and welcome to FixYa. I am Kelly.
What your describing is a result of either an automatic defrosting problem or an Air Damper problem.
Here is what you can do to determine if it is a defrost issue or an Air Damper issue.
1. Unplug the unit
2. Empty the freezer section ONLY contents
3. Place a fan blowing into the freezer section for a little over 2 hours. NOTE: This will make a water mess so be prepared.
4. After the manual defrosting session with the fan re-load the freezer contents and plug the unit back in.
5. Check food section temps in about 4 hours.
NORMAL temps you have an automatic defrost problem
WARM temps you have an Air Damper Problem.
Either of the above will require further troubleshooting or service. At least you will know where to start or... what to tell a service person.
Thanks for using FixYa.
Kelly
Posted on Apr 13, 2010
SOURCE: Hoover Contour HE423UFL fridge freezer continually frosts over?
I am on my fourth timer for this problem. Seems to fix the problem each time. You must remove the big chunk of ice covering the drain hole before you operate the fridge with the new timer. The contacts in the timer get burnt due to arcing inside the switch. The heating element seems to always work ok, but if the element is no good the fridge will not defrost.
Posted on May 11, 2010
heatman101
  • 43501 Answers
SOURCE: hoover a class, fridge freezer,
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Oct 22, 2010
I have a hoover frost free fridge freezer, fridge part on the top half, and the fridge keeps icing right up, it got so bad it was over an inch thick over the back wall of the fridge and all my food ke
Check you've not accidentally put it on fast freeze, and the thermostat setting is not too high. Next check condenser is clear and clean. Lastly, check any fans are still working ok.
Apr 28, 2012 | Refrigerators
I have a Hoover upright fridge freezer which is not cooling in either fridge or freezer unit, the thermostat control does not click when turned up or down. the appliance is 4.5 years old. model no....
IF THIS IS FROST FREE IT DOES NOT USE THERMOSTAT BUT A CONTROL BOARD. LISTEN TO COMPRESSOR ,IF RUNNING THEN GAS IS LOW(R600a) LOOK FOR YELLOW TRIANGLE ON COMPRESSOR. IF IT RUNS TOO LONG LIKE THIS COMPRESSOR WILL RUN BUT NOT PUSH. ONLY WAY TO TELL IS TO PAY FOR AN ENGINEER TO COME,FIT A VALVE AND CHECK IT. JON THE FRIDGE DOC.
Mar 07, 2010 | Hoover HMA280K Bottom Freezer Refrigerator
Jan 31, 2010 | Refrigerators
Hoover contour fridge leaking
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Aug 30, 2009 | Refrigerators
Candy frost free fridge freezer .freezer working ok
The thermostat might be turned up too high or is faulty. It should click when turned up and down from the setpoint.
May 12, 2009 | Freezers
Frostfree hoover fridgefreezer
If its freezing at the back that indicates refrigeration is good. it sounds like you have a thermostat control problem. Replace the thermostat.
Jan 12, 2009 | Engel Freezer 22 Qt. Fridge/Freezer
I have a hoover frost free fridge freezer,the freezer seems ok but the bottom of the fridge is freezing all the goods,can you help
you could have set the temperature too low.
adjust the tempearature in the middle section and if it would still freezes the bottom part, use the minimum setting and see if it will make a difference.
tnx 4 using fixya,
drcool
Oct 24, 2008 | Refrigerators
Hotpoint Mistral Frost Free Fridge freezer - fridge not getting cold
We have just had to call out an engineer to get our 1 1/2 year old Hotpoint Graphite Frost Free Fridge Freezer repaired. The fridge had almost entitely stopped cooling even when on high. I was amazed at how easily the problem was sorted. The engineer removed all the basktes from the freezer to access the screws on the inside backpanel of the freezer. Once this panel was removed it was clear that the so called Frost Free doesn't really mean what it says. The ice need to be melted with a bit of simple care. It is obvious that with a bit of care it is easliy a diy job BUT PLEASE BE CAREFUL AND READ THE NEXT PART BEFORE YOU BEGIN TO REMOVE THE ICE> The ice forms around variouys pipes etc and he usecd a screwdriver to help release the ice quicker than waiting for it to defrost and he also used a simple hairdryer to help speed up the process. He had a ntowel and a basin to take care of the water. Next time I would have no problem doing this myself but I would need to leave it a little while to defrost and NOT USE A SCREWDRIVER as I am sure somehow I would puncture a pipe or the wall of the freezer itself and I am quite used to doing the odd bit of DIY. On a difficulkty scale of 1 to 10 with 10 being difficult I would rate the job as about a 3. Hope this helps anyone who reads this about £70.
Mar 30, 2008 | Hotpoint FFA90 Bottom Freezer Refrigerator
Refrigerators Logo
217 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
