Question about Coleman Powermate Powermate 5000W Generator
Coleman Generator powerbase 4000 model #PM0543800
I haven't used my generator in a long time... can't find the manual... having trouble starting it... not sure where the choke should be set. Can you help me, please?
  • cfa6094 Jan 22, 2009
    I have 2 comments:
    1. It's been over 3 months since I originally posted my issue. Although I appreciate that someone made an effort to offer a solution, the response was not very timely. There was a power outage in my area a few weeks ago and I had to go out and buy a new generator.
    2. I would think that someone who is supposed to have some sort of technical expertise in these matters would know how to spell carburetor (not carberator). Makes me wonder just how knowledgeable mrfixit really is.
I have to leave a comment for cfa6094. Your pretty good at flexing your cyber muscles. I am a service tech in the repair field and deal with people like you all the time. If you are the owner of the equipment you should properly maintain your equipment. Sounds like you are not very organized. Sound more like crises management to me. Is mrfixit the only person you asked about this problem? One more thing, sound like you are a bit of a procrastinator to me. LOOK AT ME NO SPELL CHECK!
Posted on Feb 07, 2009
Have you checked the oil yet?
It shuts the engine off or does not allow to start if it if low
Posted on Oct 02, 2009
GUARDIAN 40G generator crabks but won't run.
Is on/off switch in "on" position - set choke? fill with gas? Is switch on gas line to carb in "on" position.
If does not start then you either have a spark or fuel delivery issue and you need to trouble shoot the various systems.
Ig as was left in carb last time used, it is possible that the gas jelled and clogged up the carb and now the latter needs cleaning/overhaul.
Aug 31, 2015 | Guardian Electrical Supplies
3650 generator won't start!!
I assume that the spark plug are good and the gas line is clear. Try to adjust the gas line supply and default engine startup revolution settings try it full half and minimum back and forth it works. Other gen sets requires a mix of oil with its gas, please do it when it is required with exact proportion. Hope this helps. Goodluck.
Mar 18, 2014 | Husky 3650 Watt Generator with Subaru...
How to start the generator
Hi Joe, I had asked for a little clarification and have not received any information. I will answer this question based on the generator is in good working order and it is a recoil start. Open the petcock, (this is the fuel valve) and give it about a minute to fill the fuel bowl on the carburetor. If your generator has an engine an on/off kill switch, set to on. If the generator has an auto idle switch set it to off. If the engine has a throttle lever located under the carburetor, push it all the way down (full throttle). Pull the choke knob out completely, there is a detent on the choke for half choke, pull it past this for full choke. pull the recoil starter rapidly. As soon as the engine starts running push the choke knob to half choke, this will allow the engine to run smooth while it's warming up. Depending on the climate that you are in, warm up time will vary. After a minute or two in cold climates start pushing the choke knob in, if it starts to run poorly pull it back out too the half position and let it warm up some more. When you can posh the choke in without the engine faltering it is ready to go. In warmer climates you might be able to start the engine without the choke or in the halfway position. Robin Subaru makes some of the finest small engines available. I would choose a Robin over a Honda every time. I hope this gets your generator going, and once again this is based on the generator being in good working order. Good luck, Michael Burke.
Dec 03, 2011 | Coleman Powermate Subaru 5000W Portable...
My brand new UST 1200W generator engine start OK (single pull) when choke on but won't stay up when choke is off. I changed oil after the first 4 hrs of use. Has this to do with the gasline I used?
It is possible that it may be having trouble if you have some bad gas but I would be more inclined to check the float to make sure it is not hanging up and allowing to much gas to get to engine. I would adjust idle and fuel mix screw all the way shut and then start opening them up about 1/4 turn at a time and try to start and run between adjustments.Only try to start it once or twice in between adjustments to avoid flooding. If you can get it to run good then turn screws one more time or until engine starts missing a little then slowly close until it runs smoothly.Hope this helps you. Thank you.
Aug 29, 2011 | Gentron 1000w rated 1200w peak portable...
When I start my generator it just lugs and shakes and will not get going. I have a UST 2300w generator modle GG2300. thanks jeffery
OK, you have a hard to find info on model. My first thought is that your choke is still on.
Does it have a manually activated choke? If so you know what to do, after she kicks, turn it off.
If it is one of the new Auto-choke units you may need to find the choke linkage and disengage
it that way. I have asked for a manual for your from UTS. We will see what they send, or dont!
As with all engines, if left in storage for long periods of time, use fuel stabilizer and try and start
the engine every 30 days and let it run for 10-15 minutes just to warm up and keep everything moving.
Mar 29, 2011 | UST GG2300 Portable Gas Powered Generator
How to start a gas generator (should the choke be in or out, to the right or the left before starting
Most Generac generators have a lever for the choke that pulls out. So if the generator is being started for the first use or cold you should choke when starting . Let it run for 30-45 sec. then push it in . Once the engine has been run or warm you dont need to choke every time when starting .
Nov 04, 2010 | Generac Power Systems Generac 0057890 3250...
Hi my honda generator runs for a couple of min then turns off this seems to happen more when its cold but happens when warm just not as much anyone have a idea of what it is
First off, Jason, what is the model number of your generator? It helps to know what product you're having trouble with so the correct information can be provided to you to help you solve your problem.
It sounds like the choke is staying on after starting. If you have an automatic choke, check for free movement of the choke spring and lever assembly (behind the carb). If it's a manual choke, remember to push it in once the engine is running smoothly (after 20 seconds).
It could be a fouled sparkplug or clogged air filter element too, but, again, without the model number it is very difficult to solve your problem.
You need to go to the Honda website and download a copy of the owner's manual for your specific generator and follow the step-by-step instructions for operating and troubleshooting your generator.
Here's the link to get your free online owners manual:
http://www.hondapowerequipment.com/products/manuals/
Hope you find this info Very Helpful and best regards!
The following helpful basic steps are from Honda:
To start your generator:
  1. Review your owner's manual to ensure familiarity with your generator's controls and operation.
  2. Move the generator outside.
  3. Check the fuel level and add more fuel if necessary.
  4. Check the oil level and add oil if necessary.
  5. Check the air filter and clean if necessary.
  6. Turn the circuit breaker off.
  7. Turn the fuel valve on.
  8. Start the generator.
  9. Allow the generator the warm up for a few moments before turning the circuit breaker on.
  10. Connect the appliances or the transfer switch if applicable.
Aug 20, 2009 | Electrical Supplies
Runs rough when choke pushed all the way to run position
Where can i obtain a manual for the 5500 gas generator
Dec 26, 2008 | Coleman Powermate Powermate 5000W...
I have a Yamaha EF1000is Inverter/Generator. I am having trouble with the idle speed when the choke is all the way in. It chokes itself out. What can be done?
Not sure exactly what you mean but here is what I know:
1 - You shouldn't have to use any choke at all once the engine has started and warmed up, if you have to apply some choke to get the engine to run correctly then you have a carb problem. Clean and service the carb and see if that makes it all better.
2 - The idle speed is set by a small screw on the body of the carb itself, if it's set too low the engine can shut off rather than idle. Make small adjustments until you get it right.
3 - Dirty air cleaners can cause problems with idle
4 - fouled and/or misgapped spark plugs can cause idle problems
Please rank this answer,
Carl
Dec 02, 2008 | Yamaha 2500 Watt Industrial Inverter...
McCulloch generator stops after about a minute
Have Generator McCullough FG 6000 was running fine motor still running fine than NO power output, any suggestions ?? Can you get replacement parts and repair diagram off the interent ??
Sep 30, 2008 | McCulloch 13HP 338 Cc Portable Generator #...
Coleman Powermate Powermate 5000W Generator Logo
1,577 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
