Bought a Sansui lcd tv/dvd combo today. Get a blue screen (about 2 seconds) when changing channels. Is this normal or is there a way to get rid of that? Thanks !! Karen
    Genius:
  • 2,920 Answers
Its normal
Posted on Oct 11, 2008
Image disappear, loud, high pitch noise
It is likely that your Sansui TV has a power supply problem.
Jan 17, 2014 | Sansui 22"" HD LCD/DVD Combo TV
Sansui TV/VCR/DVD combo
This solution is provided by one of our experts premtech
Child Lock
Combos
--Should have original remote. Press and hold the power button for 6 to 10 seconds
Combo Model T25208, V-Chip Forgotten Password
If you forget your password, simultaneously press VOLUME down on the TV/VCR front panel and the 0 number button on the remote for a few seconds. This resets the password and you can enter a new one.
Combo Model 13TVR62, V-Chip Forgotten Password
If you forget your password, press STOP/EJECT on the TV/VCR front panel and MENU on the remote simultaneously. This resets the password, but not the limits you’ve set.
Televisions with Parental Lock Feature
If you forgot your password for this feature, press the following buttons on the remote, one at a time. (Note: You must be in the password entry screen) Press, Mute, Display,Clear and Reset, this unlocks parental controls and you can now re-enter a new password.
OR TRY THIS..
Press and hold Menu on the TV AND volume down on the remote for 3 seconds. Nothing will appear on the screen, and the Parental Controls will unlock, and you can re-enter a new password with the LOCK PARENTAL CONTROLS
CTC169AU
Channels that have been locked can be viewed only when the PARENTAL CTRL function is set to OFF. This can only be done with the remote control-it can not be changed with the buttons on the front of the TV.
Therefore, after you turn on PARENTAL CTRL, you simply hide the remote control so that your children can not watch the locked channels. The locked-out channels will remain unviewable even if the TV is unplugged or the channels are autoprogrammed again. The only way to view locked channels is to use the supplied remote control to set the PARENTAL CTRL function to OFF.
The PARENTAL CTRL and the CHAN CTRL functions work hand-in-hand. The instructions below will first tell you how to turn parental control on or off with the PARENTAL CTRL function and then how to lock desired channels with the CHAN CTRL function.
1. Repeatedly press MENU to select SETUP MENU, and then press + or - to display setup functions. Repeatedly press MENU to select the PARENTAL CTRL function. . When this function is set to ON, PARENTAL CTRL is activated and any channels you locked with the CHAN CTRL function will not be viewable. . When this function is set to OFF, PARENTAL CTRL is deactivated and all channels are viewable.
2. To lock channels, press the MENU button to select the CHAN CTRL function. Select a channel you want to lock by pressing CHANNEL up or down. Then press +. The CHAN CTRL setting will change from NORMAL to LOCKED when that channel is locked. To return the channel to NORMAL, press the - button. Repeat step 2 for each channel you want to lock. If the PARENTAL CTRL function is set to ON while you are locking out channels, each channel will go blank as you lock it. When the PARENTAL CTRL function is set to ON and a channel which has been locked out is tuned, the TV will display the words PARENTAL CONTROL to let your kids know you have locked it.
CTC185's
If the front panel function buttons don't work, (menu, ch up/dn etc.) but the functions work normal with the remote, enter the "Channel" menu with the remote and turn "Parental Control" off.
CTC203's
In the event you have forgotten your password, perform the following procedure:
Press and hold for 3 seconds the TV button on the remote while pressing the menu button on the TV.
This procedure will turn off the parental lock and erase the previous password .
Another Possibility To Try For Various Models: If TV's in the Parental mode and askes for a password that's forgotten, Press menu on the TV, select Parental Lock #4 on menu, then with the remote press Mute, Display, Clear, and Reset buttons in sequence.
TX808 Chassis
If Parental Controls have been set and you don't know the password, do this:
Press and hold the volume down and the channel up buttons at the same time for 5 seconds.
Now you can reset the password to 0000, and using that password you can now access the V-Chip menus.
TV's (Made by Daewoo or possibly Apex, ie. GE model 24GP653)
The factory default pass code of 6688 is also the override code, in case the owner forgets their pass code. If that doesn't work, another place in the owners manual says to push Function and Mute on the remote at the same time. Function is the top right button.
Jun 28, 2008 | Sansui DTV2760 27" TV
Why does my LCD HDTV go to a blue screen when changing channels
if using a box it may be normal but not nice, I would suspect the set is a bit slow reacting to signal change. I remember some nasty JVC sets that when going up or down a channel the screen would blank for about two seconds and come on, normal since all those had that feature(no channel surfing)>
Sep 03, 2012 | Vizio 42 in. LCD TV
TV is connected to cable; when we have a picture it is terrific. There are several times during the day when we have audio but screen is black. Unplugging and waiting an hour or more sometimes helps but...
Return it to Amazon.com.Get a replacement tv.This tv have problems with it 1 or 2 long LCD inverter boards,it dying going to be dead.That why u have only a flashes of a picture only a few second,than died,just black screen lelf and have sound.Or talk to Amazon.com customer serviced to get ur tv a warrenty repair.
Nov 14, 2010 | Sansui HDLCDVD325 32 in. LCD TV/DVD Combo
Subtitles keep coming on
Hiya, have bought an Alba 26" LCD TV myself today. If you go into the menu and then into subtitles change it from English to Dutch. This should solve the problem. :-)
Dec 13, 2009 | Televison & Video
TV/DVD Combo will not switch back to live TV when DVD is ejected.
I had the same problem with the same unit when I first bought it a few months ago.
First up remove the DVD. If the TV stations do not appear within a couple of seconds press the "TV" button (top, second from left) on your remote control.
Let me know if this doesn't work.
Apr 28, 2009 | LG 26LG30 26 in. LCD TV
Black rectangle in the middle of my screen
Turn off the text box function of the closed captioning.
Aug 31, 2008 | Sansui LCDWDVD320 32 in. TV/DVD Combo
Apex 32" TV - Blue Screen & Channels keeping running/changing
blue screen indicares that there is a problem in blue cathode circuit. please check 1 blue video output supply. 2 blue video ckt defective 3 signal from chroma ic to blue cathode missing. 4 loose connector 5 crt base loose. 6 chroma ic defective. I think sound will be ok .
Sep 22, 2007 | Apex Digital PF3230 32" TV
When I turn TV O
When i open it screen takes 15-20 minutes to be displayed complete.sound & other things are ok.So i request to have sansui tv service dealer in Mumbai/Navi Mumbai/Thane India No; to contact. Regards M.w.Ahmed
Mar 02, 2007 | Sansui LCDVD200 20 in. TV/DVD Combo
Televison & Video Logo
Top Televison & Video Experts
