Question about Kenmore 43142 Front Load Washer
Clicking noise while spinning the drum
I hear a clicking noise when the drum spins. There must be something stuck on the top. How do I access that part of the washer? Thank you
  • 1 more comment
  • enzinol Oct 12, 2008
    Thanks for the suggestion. It came out to be a piece of metal stuck from the inside which I was able to extract easily from the inside as well; it was very visible when I opened the top part of the washer!
  • jgood811 May 12, 2009
    so taking apart the whole thing isnt recommended? it sounds like something horrible is going on in mine when the drum is spinning.
  • Anonymous May 19, 2009
    According to my Sears Repair guy, after about 1.5 years on water, the basket support rusts out and causes it to not support th ebasket any longer. He said if it is bad enough, plastic dust will get on your clothes when they are washed. It is about $1000 worth of parts to be replaced and $200 labor. Good thing I bought the extended, extended warranty. BTW, my machine is about 4 years old now. 1st time this has happened.
    President:
  • Kenmore Master
  • 2,651 Answers
Really no good way to acess the inbtween portions of the tub, with any luck you can remove the lower drain hose and fish whatever is stuck out from there
Posted on Oct 12, 2008
On spin cycle sounds like change or rocks spinning around in drum.
Could be a bad bearing or something loose on the drum that doesn't rattle until you get up to spin speed. Look for something like pins, nails or screws stuck in the holes of the drum, or possibly under the protuberances (fins) inside the drum. Does the sound occur all through the spin cycle or only at top speed?
Jul 08, 2015 | Washing Machines
Clicking noise
More than likely a bra wire stuck,,,get a torch,stick ur head inside drum & have a look,,,pulled hundreds out over the years
Jun 16, 2013 | Maytag Washing Machines
LG gas dryer DLG0452W drum makes a clicking noise
one of the dry drum baffle screw might be lose are there might be something caught inbetween the dry drum front seal are rear
Apr 24, 2010 | LG DLG0452W Gas Dryer
When in fast spin there is a loud rattling sound as though there are stones in the drum
You could have something fast between the inner and outer drum, or one or more of the drum paddles is loose..
Remove lower rear panel of washer, remove the belt, and from the front spin the drum by hand, this this will show if the drum bearings are o/k.
There should be little or no noise from the drum.
If it is rumbling, or feels rough, then the main bearings have failed.
If ther is something caught, then you will hear it catching or clicking.
Hope this helps.
Dec 10, 2009 | Hotpoint Aquarius WMA56 Front Load Washer
Maytag Atlantis screeches @ end of spin cycle,
may be something stuck in the drum or a segment raised on the motor. to test either remove the belt and spin the drum if no noise then the motor is faulty. if a noise then there may be a bra wire between the drum/tub.
Mar 16, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Washer makes loud knocking noise
I think that the drum bearings have gone on the machine..
To open the door and spin the empty drum quickly by hand and you should hear the noise or say a less amplifed one.. You can also move the inner drum up and down to see if there is something wrong with it..
Sep 28, 2008 | Roper RAS6233KQ Top Load Washer
Ge profile WNSB8060BWW VERYYYYYY LOUD
Rear ball bearing broken change half drum or buy new washer ????????????
the super tech
Sep 04, 2017 | GE WNSB8060BWW Top Load Washer
Kenmore 43142 Front Load Washer Logo
Sal De
fordexpert
Robert Rankin
