Question about Microsoft Xbox 360 Console
My xbox 360 cd drive keeps on opening and closing.
Can someone help me. My xbox360 cd drive keeps on opening and closing. It wont stop opening and closing.
  • 4 more comments
  • iamperryman Oct 27, 2008
    360 drive tray opening and closing at random, it will even turn itself on and eject the tray. still reads disks fine just wont stop opening and closing even with dvd drive not connected in dash it shows opening tray and closing
  • javonty Nov 02, 2008
    my xbox 360 cd drive keeps opening and closing
  • Anonymous Nov 04, 2008
    mbmm
  • snorkie232 Nov 09, 2008
    Same problem here but it made a horrible noise just before it started doing this. Wont read any disks at all and flat refuses to let the drive stay closed.
  • Anonymous Jan 25, 2009
    I had the same exact probleme as snorkie
  • sniperkris28 May 11, 2010
    xboxmodshop, would this also work if the dvd drive keeps getting stuck?
Your having a dvd drive problem Im taking a guess but i have fixed many like this before. What you need to do is take your xbox360 apart. You can find a video how to do this on our site http://www.xboxmodshop.com next you want to remove your dvd drive take out the four screws on the bottom and remove the top cover. Now make sure your looking at the spindle where the game rest in the middle of your spindle you will normally find two magnets, but in your case your probably wont. Yours are probably stuck to the top of your drive cover. You need to remove them and superglue or epoxy them back in the middle of your spindle.After completely dry put everything back together it should play normal.I recommend a inter-cooler so this wont happen again.
Thanks http://www.xboxmodshop.com
Posted on Oct 13, 2008
Thx it workes
I switched disk drive from 360 to 360 and now it wont play dvds someone please help!!
the issue is with in the swapping. The system inbedded a security code that is only identify by that single xbox360. In order for your system to recongize your disk drive in another xbox360 is if 1. the diskdrive is replica of the one swaped then only the chip under the drive is needed from that system or 2. flashing the disk drive. **BOTH ARE ILLEGAL**
you can manage either one by googling flashing xbox360 diskdrive ______ <--- the type of diskdrive you swaped out.
Mar 17, 2011 | Microsoft Xbox 360 Console
XBOX 360
Your Xbox 360 laser needs to be cleaned or it needs to be replaced. Sometimes even the spindle will lock up and needs to be replaced. If you need this repaired, contact us for a free quote.
- You've been helped by a Wired Extreme technician.
Apr 16, 2010 | Microsoft Xbox 360 Console
My xbox360 thing that reads the games wont stay closed
all it is ur lens isnt in the correct starting position however its a little annoying when everytime u what a go of the xbox it takes about 20mins to get it to work but now iv fixed it properly well all i did is open the xbox comnpletly and get 2 dvd drive open it up i was shocked wen i opened up mine there was a dog on the lensand all over the whole grease on the bars were coverd in hairs i pulled the lens to the correct starting position and clean the dvd drive a best as i could amnd now it work perfect
this will fix it because over time this method will take longer and longer trust me 3rd xbox
Mar 19, 2010 | Microsoft Xbox 360 Console
My xbox 360 keeps saying reading reading reading then says open tray what do i do
okay that sounds like the magnet in the cd case is stuck.open your xbox360 and access your cd drive.search on the internet if u cant.when you do,on the drive there is a circle pry it off with a flathead screwdriver and you should see a circle looking thing that moves around freely when you move it.okay cut out a circular piece of index card or thick paper that could fit on the circle and place the big metal circle you pryed off back on the drive.reassemble the xbox.it should read now.if that doesnt work then it could be the placement of the laser.dissassemble your xbox again or do this also before you reassembled it.open your cd drive by removing the 4 screws holding it together.{if its a hitachi lite(H-L} drive it will be 6} and remove the top cover there should be a lense thing that moves back and forth when it reads the games move it as close as you can to the {spinner} make sure there is no dust or hair on the rails and reassemle your xbox360.there ya go.oh if you here a buzz when u play the game dont worry about it its not gonna blow up lol.
Dec 22, 2009 | Microsoft Xbox 360 Console
Everytime i put in a new game my xbox360 disk wont close it takes 4 or 5 times of opening and closing it for it finally to stya close and read my disk. Can someone please help me ?
Get in touch with Microsoft for a replacement or repair.
I believe it is still in guarantee.
You could also try to remove the front cover case of the xbox to see if something is blocking the closure mechanism.
Hope it helped.
Nov 12, 2009 | Microsoft Xbox 360 Console
Xbox360 disc drive
Hi, it sounds like you have the" open tray" error that is very common with the 360s. How you fix this is you take your DVD drive apart and look at the laser assembly, there are 2 screws on the side of it, look at the one on the left. Turn this screw to the left a VERY little bit at a time and keep checking it every time you turn it until it stops the open tray error.
Aug 17, 2009 | Microsoft Xbox 360 Console
The disk drive wont shut on my xbox360
Your disk drive shutdown, you will have to open up the xbox, unplug the disk drive then plug it back in.
Jul 16, 2009 | Microsoft Xbox 360 Console
Xbox360 tray ejects itself
The only thing i can think of is that something is stuck in the tray. Sorry about your luck
Apr 30, 2009 | Microsoft Premium System for Xbox 360
My Xbox 360 stopped spinning the CD and playing the games.
i myself have the same problem and currently working on it. go to youtube and type in "how to fix a broken xbox360 dvd disk drive" this guy is amazing and helped me out with the red rings of death. all u have to do is buy a new disk drive for about $50 and take some parts apart.
Mar 14, 2009 | Microsoft Xbox 360 Console
Xbox360 drive wont close
It is probable that the cd drive motor is fryed. If it is still in warranty you should return it.
Aug 23, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
3,724 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
