Question about HP Wireless Optical Mouse
Cant get it back together
My wireless mouse quit working and I figured the batteries were the problem. I took the screws out and took it apart. Could not get to the batteries to remove them and when I turned the electrical pad over the tiny parts fell out of place. I dont know where the tiny spring with the black box go. I know where the other two parts go but not the spring.
My mouse is about 6 weeks old.
Thanks,
Kathryn
thekingdom@sbcglobal.net
Thanks for this posting. I didn't even think it would be the battery and was nervous to pull everything apart, but it was easy thanks to the information from Solution #1.
Posted on Nov 04, 2008
I put together what I knew where it went, the put the whole thing together and looked at it before putting in the screws. I saw a hole and remembered a "button" there that moved sideways with a spring pushing it back into the original place. I reopened and after examining the part put it in that slot. I then put it together and it worked. I put the screws back in then and all is well
Thank you for the reply.
Glad I found your site. I will keep it if I ever need any help.
Kathryn
Posted on Oct 12, 2008
Where is the receiver or usb device in a GE wireless optical mouse 98763
There isn't one on a wireless mouse.You get the sender with the mouse that goes into your USB port on computer.Put it back together and find the little USB sender in the blister pack,put a battery in the mouse,and your good to go.All i use is wireless mice.
Nov 08, 2013 | GE Optical Mini Wireless Mouse 98793
Ryobi CS26 Trimmer/Edger: how to replace the pull cord. I cant get it back together. I took it apart and cant get the front section to go back together and get the bolts back in. Something is not aligned...
There is a screw hole on the bottom of the recoil spring. It needs to be lined up with the same hole on the bottom of the gray plastic casing.
Jun 20, 2011 | Garden
I have a Logitech LX-6 cordless optical mouse. Lately it's been double clicking when I press the left button - not always, but often enough that it's irritating. I'd like to take it apart and clean the...
Quite often there is a label on the bottom and this hides a screw which holds the mouse together. If there is a label on the bottom, try rubbing your finger over it to see if you can feel a hole underneath. Also on the bottom are plastic glide pads which help the mouse to move freely. If there is a large one towards the back then it may also hide a screw. Use a thin blade to lift off the glide pad and hopefully the sticky layer will remain sticky to make it easier to put back.
Feb 25, 2011 | Logitech Cordless Mouse
The scroll button on my mouse is stuck, will not turn.
If the scroll button is sticky, take a q-tip and clean the wheel off on the outside and as much in the inside as possible. Dampen the q-tip with water.
If that doesnt' work, look for screws that hold the mouse together, unscrew the screws and take the mouse apart. At that point clean the scroll button and then put everything back together.
If the mouse still doesn't work properly then at that point, you'll need to get a new mouse.
Jan 01, 2010 | Microsoft Wireless Laser Mouse 5000
I took the mouse apart and I can't put it back
Make sure the circuit board and wires are all in place correctly so they aren't preventing the case from snapping/connecting back together.
Most of the time, it's just a small piece of wire or something that is getting in the way and preventing you from closing it back up.
Devices are made so small these days that they don't leave much room in them for loose wires and all.
I hope this helps :)
Best Regards,
James Trageser
Jul 29, 2009 | Logitech Labtec Wireless Laser Mouse
Dell mouse
Buy a new wireless .. a lot cheaper than worrying about putting it together.
Oct 23, 2008 | Dell USB Scroll Mouse (x04-91624)
Bracket and spring location to reassemble mouse
just buy new mouse, usb or wireless
for $8
or just use it.
2 choices.
10000s of mouse designs there are, good luck finding that level of information.
Nov 13, 2017 | HP Wireless Optical Mouse
Microsoft Wireless Optical mouse 2.0 Sticky central wheel
I just took mine apart to fix same problem, works much better but not sure for how long.
Quite simple to dismantle the unit.
Take the battery cover off, remove batteries.
There is a small screw in the middle of the battery cavity, you will need a very small Phillips head screwdriver.
Gently ease the base (holding circuit board) from the top shell
The wheel unit can be gently eased out of its cradle, use the small screwdriver to pop it out, watch out for the small spring between base and wheel unit, don't lose it
You can disconnect the wheel unit from the circuit board by unhooking the small plug connector
Now defluff, then clean the wheel - I used a tiny amount of turps on a cloth, anything similar should work. If you look closely the reason the wheel won't roll smoothly is that the gel ring on the wheel is too close and rubs at the front and back of the cradle. Once grime builds up, this problem makes the wheel unusable. Roll the wheel back and forth along a clean surface once cleaned, should start rolling freely again.
I also unscrewed the top shell from the mouse buttons (all one piece, pinch the plastic pegs in the centre of the shell together to release) and cleaned the whole unit up before putting it back together
Don't forget the spring when putting the wheel unit back. When screwing the base to the top shell make sure there is no play between the two parts before you put the batteries back in, mine was a bit tricky to get tight again but worked fine second attempt
Sep 07, 2008 | Microsoft Standard Wireless Optical Mouse
Wireless mouse quit working
plz check the batteries of your wireless mouse. try reinserting them or may be you can try a new set of batteries.also try to reset the connection on your mouse by pressing the connect button under the mouse and on the reciever together and releasing both together
Jan 21, 2008 | Computers & Internet
Dell optical mouse quit working
This might sound very obvious, but have you replaced the battery?
Have you tried resetting the mouse and the USB receiver?
Jan 03, 2008 | Dell Wireless Keyboard Optical Mouse w0147
HP Wireless Optical Mouse Logo
248 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
