Question about Bissell 1425 Little Green ProHeat Handheld Steam Vacuum
Cleaning the bissell little green
How can I clean the bissell little green steam cleaner. I puts out a funny odor when I turn it on.
  • 3 Answers
Bissell 1425 works great, but today will not ****! Spray is fine....just no suction, even without any attatchments.
Posted on Oct 19, 2009
We took off the hose by pushing in the 2 white pins on either side of the hose at the end near the base.BE CAREFUL NOT TO PULL ON THE HOSE ITSELF but on the plastic where the hose connects.Flush water thru the hose to clear out all the mildew and junk thats caught up in the hose. Reconnect the hose by pushing back on and locking the pins back in. It'll start smelling better immediately.
Posted on Apr 22, 2009
How can I download Bissell Little Green Clean Machine manual?
direct
https://canada.bissell.com/support
or the first link has it, also videos
  • BISSELL LITTLE GREEN 1400 SERIES USER MANUAL Pdf ...
    www.manualslib.com > ... > Vacuum Cleaner > Little Green 1400 SERIES
    Bissell LITTLE GREEN 1400 SERIES User Manual. ... Vacuum Cleaner Bissell Little Green 1400 SERIES User ... Rcvd a used bissell little green machine w stagnant ...
  • Bissell Little Green Machine ' Walmart.ca
    www.walmart.ca > Walmart.ca > Appliances > Vacuums > Steamers
    • 4.1/5
    • 185 REVIEWS
    • $99.96
    Bissell Little Green Machine for sale at Walmart Canada. ... Powerful suction lifts stains and spots with water or any of the Bissell cleaning solutions.
  • Little Green® Portable Carpet Cleaner ' BISSELL®
    www.bissell.com > ... > Browse By Type > Carpet Cleaners > Portable
    The Little Green® portable carpet cleaner is produced with a minimum of 50 ... Coupon code for purchases on bissell.com: ... (including all accessories and manuals) ...
  • BISSELL LITTLE GREEN CLEAN MACHINE PDF - fenbook.me
    fenbook.me/get-it-free/b/bissell-little-green-clean-machine-manual.pdf · PDF file
    Get Free Read Online Ebook PDF Bissell Little Green Clean Machine at our Ebook Library. Get Bissell Little Green Clean Machine PDF file for free from our online library
  • Bissell Little Green Owners Manual ; Bissell Little Green ...
    www.youtube.com/watch?v=PpQji8obNz4
    • BY BOTHSHOOP
    • 4 MIN
    • 11K VIEWS
    2012-11-07 · Video embedded · Bissell Little Green Owners Manual ; ... Bissell Little Green Owners Manual ; Bissell Little Green Machine ... How to fix a Bissell Carpet
  • Bissell LITTLE GREEN 1400 SERIES User Manual
    May 24, 2016 | Bissell Vacuums
    Www bissell com
    Hi Therese. The Little Green doesn't create steam. It uses hot tap water and BISSELL Formula to clean your carpet.
    Aug 14, 2013 | Bissell 1425 Little Green ProHeat Handheld...
    Bissell pro heat steam carpet cleaner, not releasing water.
    That means that you need to replace the pump belt. Here is the belt you need and a manual you can view:
    Bissell 7901 Belt and Manual
    Mar 01, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
    Bissell steam cleaner model 9300 not putting out soap
    Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
    Bissell Proheat Upright Wet/Dry Vacuum Problems
    heatman101
    ,b..,
    May 14, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
    take the jugs off the sides and wash the base. out with bleach water,also fill the solution tank with bleach water and shake well to remove the mildew and dirt from the tanks
    Apr 27, 2009 | Bissell 1400 Little Green Pro Canister...
    Does the cleaner solution go in small tank. Should the little tube be down in solution?
    http://www.bissell.com/Product_Search.aspx?Criteria=1699
    Above is a link to bissell.com where you can get the full user manual. But to answer your questions, the cleaning solution does go into the small tank with the tube, the tube should be arched and go to the bottom corner of the small tank. Clean hot (not boiling) tap water goes into the inner bladder of the big tank. Fill it till you can see the water near the top.
    Oct 04, 2008 | Bissell 1699 ProHeat Clear View Upright...
    Bissell little green steam machine
    There is a small pump inside the unit that may be bad.
    Dec 19, 2007 | Bissell 1200B Handheld Steam Vacuum
    Bissell 1425 Little Green ProHeat Handheld Steam Vacuum Logo
    914 people viewed this question
    Top Bissell Vacuums Experts
    Jim Thurston
    Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
