Question about Compaq Presario 700 470024-192 Notebook
Screen still faint after changing module and screen
I Hp compaq presario 700 with a faint screen, i check it with external monitor, it displayed well, so i change the module and the screen but i still like that. pls how can i solve this problem, is it on board? what is the solution
  • olisa01 Oct 13, 2008
    What is inverter board, where is the position onboard, is it and ic and how can it be repaired
  • Compaq Master
  • 4,338 Answers
Which "module" did you change. The Inverter board is causing the "faintness" Replacing the screen will not fix it.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Oct 12, 2008
  • JDTec
    JDTec Oct 13, 2008
    The inverter board is just below the actual screen. It is a board about 6" by 1/2" It cost about $40.
Right clicking on desktop, no graphic option for external monitor is coming up on presario 700c win7
Just right clicking does not always call up the second monitor option.
You should select "screen resolution" after right clicking
Then ensure there are two moinitors available.
If not check all connections to the second monitor inc the cables.
Make sure that the multiple display option is set correctly too eg extend these displays,
OR duplicate and NOT show desktop on display 1 (or 2)
Also check you have the latest drivers installed for that model.
DO NOT RELY ON THE MICROSOFT DRIVER UPDATE !
Go to the Compaq site and get them from there !
Feb 06, 2011 | Compaq Presario 700 470024-192 Notebook
I have a Compaq CQ50-210. Problem with the HP COMPAQ Presario CQ50-210US NoteBook AMD Athlon X2 QL-62 15.4' Wide XGA 2GB Memory 160GB HDD... I have a Compaq CQ50-210. When I try to boot it, the screen...
Power up the external monitor first and then boot up the laptop, the video info will automatically divert to the external monitor.
If you do not see a Windows image on the external monitor then it is definitely a motherboard issue, because the video card is built in on the motherboard.
The Video card uses shared RAM (part of the RAM module/s ), try re-seating the RAM modules, also test the RAM modules.
You can test the hard drive by removing the hard drive and connecting it to an USB hard drive adapter, then connect the adapter into a working computer's USB port. If the hard drive is OK, this computer will see it as an external storage device and you can open the various folders and files on the hard drive.
Dec 12, 2010 | HP Compaq Presario CQ50-210US Notebook
Display very faint. external monitor no display.
A very faint laptop display is the result of a burned out CCFL light in your LCD panel. It is a mostly non-replaceable part. (very difficult repair). To use an external monitor right click on your desktop then go to the settings tab and change your display properties to dual display mode.
Jun 22, 2010 | Compaq Presario 700 470024-192 Notebook
Compaq presario 700 monitor off
Hi
Maybe, depending on the problem. Laptop monitor problems fall into three categories. 1. Screen electronics or lamp. 2. Inverter. 3. Laptop video chip. I've been repairing latops ever since they arrived on the market. First connect an external monitor to the laptop - this will show you whether or not the laptop motherboard is working correctly. If it is then you'll need to replace either the screen or the inverter. So as not to waste alot of money, at this point I would suugest going to a reputable repair person or check my website www.micromendllc.com
Jun 05, 2010 | Compaq Presario 700 470024-192 Notebook
Periodically the screen is captured by horizontal lines completely across the screen. Cannot access programs or even shut down properly. Any suggestions. Presario 700 laptop using Windows Vista. Thanks
This issue is due to the malfunctioning of the screen or due to any other internal hardware malfunctioning of the notebook.
To further isolate the issue, I request you to connect the external monitor and check.
Once after connecting the external monitor, please tsp Fn+F3 Switch between the display and external monitor in the following order:
Display
External monitor
Display and external monitor
If the external display is fine then the issue either could be due the malfunctioning of the display cable connector between the screen of the notebook and motherboard or due to the malfunctioning of the screen.
As this the hardware issue, Please contact the nearest repair center to get it resolved.
May 29, 2010 | Compaq Presario 700 470024-192 Notebook
Compaq presario v3000 display problem
the problem might be from the screen or the screen bulb.
Connect your laptop to an external monitor and see if any display will come up.
If there is a display, then the problem is either from your screen or from the screen board, or screen bulb.
I would advice that you take your laptop to a repairer so that the fault can be rectified.
Good luck.
Mar 15, 2010 | HP Compaq Presario v3000z Notebook
Monitor on Compaq F500 doesn't power up.
check whether the display is coming on monitor or not through the vga port, if the display is there then its the problem of display panel, if not then the fault is in motherboard of the laptop
Sep 14, 2009 | Compaq Presario 700 470024-192 Notebook
FS050UA , COMPAQ PRESARIO NOTEBOOK PC CQ50-210US the screen has lines and a black spot
Turn on the notebook and press F10 to get into BIOS screen. Even if the lines and the black spot appears then the issue is with the internal hardware of the notebook.
To check further connect an external monitor to the notebook and press Fn and F4 keys on the keyboard to get the display on external monitor. If the external monitor display is fine then the issue is with the LCD screen or else the issue is with the Video card of the notebook.
Jul 31, 2009 | HP Compaq Presario CQ50-210US Notebook
I turn it on i get white blank screen. same when external is hooked up
Seems it is the Video card which has gone bad, If in case your system shows Compaq on your screen, os in that case need to install windows in the system again.But if it does not , Please get your system's Video card again.
May 25, 2009 | Compaq Presario 700 470024-192 Notebook
Monitor
When you said "Monitor", does it means internal LCD screen or external monitor?
Have you checked the "Power Options" in the "Control Panel"?
Nov 19, 2008 | Compaq Presario 700 470024-192 Notebook
Compaq Presario 700 470024-192 Notebook Logo
157 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
