Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Washer will won't run cold water cycle
My washer will only run hot water cycles. If it is put on a cold or warm cycle it will only run hot water.
  • macodonnell Feb 17, 2009
    washer will not run on cold cycle. It will run on hot or warm/cold - only fills with hot water. I checked the hoses and they run clear.
    President:
  • 2,712 Answers
Some washing machines allow cold water to enter only during certain cycles. Others intermittently allow hot and cold to enter, to temper the temperature of the water. Consult your owner's manual if you are unsure about whether the machine is acting abnormally.
If you're sure the machine is not working the way it used to--or should--check the following.
  • Is the cold water turned on? If not, turn it on.
  • Is the washer getting hot water but no cold water? If so, check to see if the control panel settings are correct.
  • Is there cold water coming through the proper hose? If not, check to see if the screen inside the water-inlet valve is clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If it's clean, you probably have a defective water-inlet valve. If so, you need to replace the valve.
  • Hope that helps! Should you have any further questions, please feel free to post them here.
    P.S. – I would greatly appreciate a FixYa! rating if the solution I provided fixed or helped you fix your problem.
    Thank you for using FIXYA!
    Cheers!
    IrishDruid
    Posted on Oct 12, 2008
    Cold/cold cyle wash water not cold
    try to do cold cycle first without doing warm cycle first
    Apr 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
    Hot/cold cycle stops before filling up
    Your washer has a set amount of time to fill. If the flow is low and the time runs out, then all you will get is the amount of water that was able to fill. Check your lines to be sure that they all fully opened.
    Aug 12, 2012 | Admiral 32 cu. ft. Washer
    Warm water filling up washer, with no hot water hooked up to wash
    exactly
    it will maintain 60 degrees but cycling hot cold
    thermistor
    Sep 29, 2009 | Maytag Performa PAV2200
    Getting only cold water to my washer; hot water is not there
    Hot water solenoid valve on washer not working. Test resistance across connectors. No resistance equals bad solenoid. Their not expensive and easy to install.
    Mar 29, 2009 | Kenmore 20722
    Washer only fills with hot water
    Probably a bad water inlet valve. To verify, you would have to check continuity at the valve.
    http://tclaundryrepair.com/home
    Feb 19, 2009 | Fisher and Paykel GWL11 Top Load Washer
    Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
    1,196 people viewed this question
    Dan Webster
    Dan Webster
    Sal DeAngelo
