Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer wont run
The problem is when the washer is on the tub will not spin.the motor just humms .i took the back panel off and checked the belt on the tub and it seemed fine i also was able to move the tub by hand and spin the belt from the back. it all seemed to be in place so i put it all back together and started a cycle the tub started to work and my wife said that it was working because when she tried to do a load the other day it did nothing. however when we put some clothes in it started out ok but nthen it stopped and we had the same problem it just stopped and started to humm so we shut it down and could really use some input on what may be wrong thanks
  • Whirlpool Master
  • 2,651 Answers
Sounds as if perhaps the hummm is coming form the drain pump not the motor, remove the front cover and you ll be able to acess the drain pump resivior, unscrew it and you find all sorts if things jammed into the pump preventing free spinning, 7 years servicing this unt never saw a bad motor, 1000's of pumps
Posted on Oct 12, 2008
Washer motor humms and won't spin after filing up with water
remove the water pump from the motor but not from the hoses and start the washer. if it starts then you have a sock or something caught inside the pump holding the motor. remove the object or replace the pump if needed. if the motor wont start then unplug the washer,remove the motor and turn by hand. if it feels hard replace motor. if it moves then leave motor out and move the gear case where the motor connects by hand. if it wont move then 2 things may happen. 1)gear case lockup or a piece of clothing caught between the tubs.
if the washer agitates but wont spin with the humming sound then I say the later. a piece of clothing caught between the tubs.
Feb 10, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
F30 error code...what is this problem?
F30 is a dispenser failure code on the Duet Sport washer.
It means the dispenser motor will not go to the proper position.
Remove the top of the washer and inspect the dispenser linkage to see if it is binding up.
Post back with what you find and we will check from there.
Nov 03, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washer wont spin ...motor runs but drum doesnt
If this is a Duet front loader, you need to check to see if the drive belt may have broken, or slipped off the drive pulley behind the wash tub.
To access and replace/reinstall the belt, the following link explains:
If you have any questions, or if the model washer you have is different, please post back and let me know. I hope this helps you.
Jun 20, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Frontload Duet. The tub will not spin, the belt
I am not an expert but I would suspect a failing bearing has seized up. Mine would spin one direction, but not the other. I worked it and got it to go both ways, but with a snapping sound. This is checked by spinning the pulley with the back panel off (machine unplugged of course).
Jun 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My Whirlpool GHW9100LW1 washer stopped working
be sure that the tub is moving around with out the outer tub moving....could be a motor controller problem.....but heres the part#s tub assembly#8181912 youll want to replace the seal too. seal#8181673
Jun 12, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
I have a Whirlpool LA6800XTWO washer. When I run it, it fills with water, but it does not spin, agitate, or pump the water out. When it gets to a point that it should do one of the above things all I...
sounds like a broken coupler, looking at your wiring diagram this unit would agitate with lid up right? then lid sw is not your problem, if it does not drain either then motor must be not turning over, so i would check the capacitor first. (it on the back panel behind the tub)
May 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirpool Duet Sport Front Loading Washer is making a funny noise
open top cover (two or three screws on rear and slide back) and look at rear of tub checking clearance to rear panel and nothing touching belt or pulley. whirlpools tend to have a high pitch low volume whine anytime motor operates.
you really dont want to replace that bearing. part of tub assm. $400 part plus labor
Mar 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Washer LSR7233BQ2 Buzzes/Humms during spin movement
No belt on your machine. Sounds like motor coupler that joins motor and transmission is broken. Very inexpensive part but a few steps involved in getting machine disassembled Look up YouTube video on replacing motor coupler on Whirlpool washer.
Sep 26, 2017 | Whirlpool LSR7333 Top Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
132 people viewed this question
Dan Webster
Dan Webster
Sal De
