My pc monitor is stating monitor going to sleep and then it goes totally blank, how do i fx this
  • 31 Answers
The prolem could be with the connection,unplug and plug back the cable that connects cpu and monitor.even then if the problem persists,the problem must be with the display drivers.
Posted on Oct 12, 2008
Monitor is going to sleep
If you mean it goes off or blank after a specific time of use--look in settings for something like the screen saver option being set too short.
There is a difference between sleep and it just failing in some way--got another monitor you can borrow or try to see if monitor or the desktop?
Jun 15, 2012 | HP Computers & Internet
The monitor will go into sleep mode, and when first booted up will not register anything and goes to sleep. Have tried re-booting, checking the chords, plugging and unplugging them in. To no avail it...
No pc stated just monitor. (not even desktop or laptop) stated.
no OS stated, ether.
so ill answer in wide generic ways....
all computer are a problem, since days of Mr. Allen Turning to now.
ive done 43years of them just puters.(and other big systems MIL)
no person on earth can answer that common question
gee no pc stated,! nor can we lay blame until its fixed can we. ever.
3+billions of transistors. mine here typing now.
4,800,000,000, and friends, lots of other things to fail even LCD
its not a toaster or 4 banger calculator, at all.
its COMPLEX but 1 of those 2 boxs or cable are bad. sure.
(viewed in the MACRO)
sleep? how do you know it is sleep.
the screen showed that. text said SPEEP?
is the screen totally dead. (that is not sleep if true)
is the screens OSD button dead?,
the only clue i have here is one word, REGISTER (good word just too few)
so the screen never ever shows any text or HP logo ever
booting with monitor on for 5min. power on PC, see words?
no text ever...so.
then push the monitors.
Select menu buttons on front of monitors. and the OSD pops does it , it must....!!! see image below (mine is Viewsonic, near new)
there are many simple tests here.
  • try you monitor on any other PC
  • or try you pc on any other monitor
easy no.?, just 1 or 2 tests and bam, who's bad.
called the process of elimination..
but OSD is first. no matter what,.
if the screen tests ok,, (display tests and its buttons)
then the PC is problematic, (1/2 the battle won)
the first thing to do (tell me what pC) but turn off all sleep
modes in the CONTROL PANEL + POWER SETTINGS>
do that first. if you can even get the screen to work.
A pc never boots to sleep so.....
the PC can have 2 VGA jacks on the rear.
the PC can have DVI jacks, using those are you
try them all yet?
if you test the PC and it works and the screen works the cable is bad.
omg that screen is new, its even sold now at walmart.
not cheap either, too much, kinda
this is a modern 22" screen, LED>
and do not just go bad, is the power pack there and correct?
if the OSD screen is dead, check power first.
this is the Monitors brain, it works even with the PC dead.
the button is marked menu or select. this is test1.
osd-1z31dkbg41o2owghj0fas5br-1-0.jpg on my monitor ,heck all 2004 up
it tells you SLeep mode when the PC goes to sleep mode
or shows Power saver mode. live on the screen.
screen power on first sure.
all ways to go black done here.
http://pcdied.com/black-screen.html
Jul 20, 2017 | HP w2207 Monitor
Why does my HP vs17 monitor screen keep going to blank black screen like it turned off but did'nt.....blue power button light is still on? Everything is running but no picture.....keeps happening everytime...
this old monitor has 2 issues.
1: it has CCFL tubes that love to burn out (backlamps)
most this old are long go, yell,dim.,blinking or DEAD.
2: push the menu button on front of mon. turn off power saver.
3: if the PC goes to sleep, or hibernete mode (parked)
then that is 100% normal
if you dont like feature then go to windows control panel
click power, ICON and turn off all monitor sleep /hibernate modes.
that assumes windows, no OS stated.
if the lamps are dead,
use flash light pointed to sceen, see data. ? bingo for bad CCFT tubes.
as seen here
http://www.pcdied.com/monitors.html#flashlighttest
Jan 12, 2018 | HP Vs17 17" LCD Flat Panel Monitor
I am getting a message traveling across my screen that says, "Input Signal Out of Range." Then, after about 1 minute I get a "going to Sleep" message, and the screen goes into sleep mode. I keep having to...
that message means, you have the unstated PC, set to a super high resolution, that is totally ******* on this old screen,
buy a newer screen,
or change the resolution.
no PC stated , at all. model , is it HP?
no OS stated, if XP hit F8 and run safe mode and lower the resolution to 1024x768.
only these work,,never higher.
1024 x 768 / 60 Hz
1024 x 768 / 70 Hz
1024 x 768 / 75 Hz
800 x 600 / 60 Hz
800 x 600 / 72 Hz
800 x 600 / 75 Hz
640 x 480 / 60 Hz
640 x 480 / 72 Hz
640 x 480 / 75 Hz
832 x 624 / 75 Hz
720 x 400 / 70 Hz
Aug 28, 2017 | Compaq FP 5017 15" Flat Panel LCD Monitor
My monitor will not stay on, it goes on sleep mode
Your problem may be due to the sleep button in your keyboard may got struct into when you cleaned your keyboard.
Try to resolve the struct in the keys, if any.
Restart your system and if still your problem persists, then remove your keyboard and restart your computer and try with some other keyboard if possible. Once if you find out that the problem is with your keyboard, then replace the keyboard / service the existing one.'
I hope this is helpful to you. Please provide your ratings.
Thanks
Apr 05, 2010 | E-Machines eMachines Monitor E15T4
My LG 2353 monitor screen goes blank by itself. Sometimes it will go into sleep mode or sometimes my screen just blanks out and the power light stays solid red without flickering to indicate whether or not...
shaylane_195, Good description of problem! But you left out one or two key things to tell me. Age of monitor? Approximate total "ON" hours of use? Is unit covered by LG (Lucky Goldstar) warranty? You and only you can tell me if the screen is really BLANK, or is it only BLACK? Do flashlight test to determine true state of screen! Can you see very, very faint image of WIN-desktop holding bright flashlight near your black screen? This monitor works!!! You just need to fix the possible (1) "cold, frosty looking, thermally intermittant solder connection on the "internal switch-mode-power-supply/CCFL inverter board. Yes, your monitor along with many other CCFL back-lit LCD units of all brands also could have some BAD, swollen, leaky electrolytic filter capacitors installed on the SMPS/CCFL inverter board which will need to be replaced with new ones of higher quality. Get back to me, lmistyrel on aim. or do additional comment on fixya, after you do some reading in my and other fixya tech's profiles to discover all options you as consumer/user have open to you. Bye for now. 12fixlouie
Mar 04, 2010 | LG W2353V-PF 23' LCD Monitor
Monitor goes into sleep mode after a few seconds
This is normaly cause by incorrect power management settings.
check power management setting in both windows and your computers bios
you will not need to worry about the power management settings of the bios when an operating system such as windows is loaded.
Loch Hiam
Az.
Sep 18, 2008 | HP Pavilion a620n (PC028A) PC Desktop
Monito going to sleep
I have the same problem. Monitor states going to sleep and the pc goes dead
Jul 03, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
Going to Sleep
got the same issue
hp pavilion 1723
Nov 01, 2007 | HP Pavilion F1903 19" Flat Panel LCD...
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
