Question about Whirlpool Calypso GVW9959K Top Load Washer
Calypso waher drain problem...
My washer will not drain and finish the cycle. I try to start it over again, (in the rinse and spin cycle) and it will make a loud squealing sound, starts to do the rinse cycle and then it stops and will not finish the cycle. I tried to balance it and it does not help it. The washer is about 3 years old and have had no problems until now. The out of balance error code came up but I tried to balance it, so I don't know if I am doing it the right way. Any help would be very helpful. Thank you very much.
Jason
  • lando75 Oct 14, 2008
    I have one that had the same problem yesterday. Need help!!!! Please
  • 2snafu Oct 16, 2008
    Washer won't empty last load. restart buttons turn on but machine makes screaching sounds shows error codes and then shuts off.
These machines must have all been programmed to fail at the same time!! I've been having the same problem problem as you guys -- this all seemed to have started when my machine tried to eat a tablecloth. I had a local appliance repair guy out here today who said he thinks that the pump has gone bad, but after reading some of the other posts here and on other sites I think the pump may just be clogged and I'm going to investigate in that direction a little further before replacing the pump. Take a look at this site which explains how an 'average joe' can unclog the pump:
http://www.associatedcontent.com/article/817667/how_to_clean_the_clogged_pump_of_a.html?cat=6
Posted on Oct 17, 2008
  • 94 Answers
Ebay item number 200262803398 is a cheap PDF repair manual for that model.
prem
Posted on Oct 14, 2008
  • 958 Answers
Could be just a simple case of loose belt and it is slipping that is why you heard a squealing noise. or a major problem with the gear box.
the unit reverses its rotation when in the spinning cycle. when there is problem with your gear box, the motor can not turn it in the reverse rotation.
tnx 4 using fixya,
drcool
Posted on Oct 11, 2008
The washer off and on on the rinse and spin
there prob coins blocking drain pipe and cant 100% empty.
i had it with mine
Apr 15, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
My washer stops before the rinse cycle because it can't seem to drain enough to start the spin cycle. I just had the drain motor replaced one month ago. I get the error code nd. I can sto the cycle and...
I'd love to say yes! The machine is stopping because it will not drain. This is what the nd code means. Therefore, it will not rinse (add more water) or spin because the water level is already too high and to try to "spin it out" would put too much pressure on the machine with that much water in it. Drain out the water by putting the drain hose below the level of the washer (this takes forever) and call your repair man back!
Feb 18, 2010 | Maytag MAH8700A Front Load Washer
Waher will not start
IF YOU DONT HAVE THE RIGHT TOOLS TO BREAK IT APART AND PUT IT BACK TOGETHER AND THE EXPERIENCE IS CHEPEAR FOR YOU TO CALL A TECHNICIAN OR BUY A NEW ONE!!!
TO FIX THIS PROBLEM IS A LITTLE TO HARD!!! NEEDS TO HAVE EXPERIENCE!!! SORRY!!
Oct 05, 2009 | LG WM0642H Front Load
Frigidaire front loading washer stopped at rinse cycle. 3 beeps
When in doubt check the easiest thing to check. The pump can cause a number of errors to come up. Since the unit stopped in rinse I would start but checking to make sure there is nothing obstructing the pump before going to the expensive parts.
Feb 22, 2009 | Frigidaire ATF6000ES Front Load Washer
Whirlpool calypso model GVW9959K-0 leaking during rinse cycle
hi my name is joyce
Sounds like your pump is leaking. if it is leaking when you are on a spin cycle.
now if it is stuck on f1 cycle and wont drain unplug and let stay unpluged for 60 seconds and replug and see if you can restart on drain and spin cycle. let me know if I can help with any other problems.
thanks
joyce
Feb 06, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Washing machine will not spin
If this is a Whirlpool washer, you have a broken motor coupler
Jan 23, 2009 | Washing Machines
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Whirlpool Calypso GVW9959K Top Load Washer Logo
126 people viewed this question
Dan Webster
Dan Webster
Sal De
