Question about Toshiba Satellite A15-S157 Notebook
Install new hdd toshiba a15-s157
I bought a new western digital 160 gb 2.5 internal ide ultra 100 hdd. I think I know how to remove the old drive and install the new one but what di I need to kow about booting up and using the reinstall disc that came with the computer
  • Toshiba Master
  • 787 Answers
Not much, its all pretty automatic, just answer the questions.
After installing the WD, power up, open the tray, insert the reinstall disk and reboot.
One of 3 things will happen. It will boot to the CD and start installing, or press and key to boot from CD will appear (press any key quickly), or it will try to boot from the hard drive and fail. If you experience the last option it means that the hard drive is set to boot before CD. Yor system may have a boot menu option where you can select the boot device or you may have to go into the bios and change the boot order.
The follow link is to a Toshiba article that explains the boot menu and changing the boot sequence in the bios.
http://www.csd.toshiba.com/cgi-bin/tais/su/su_sc_dtlView.jsp?soid=403623&moi
What it does not explain is how to access the bios. On some Toshiba system you have to press ESC right after you hit the power button, on others it is F1, on newer systems you have to hold the ESC while you press the power button and hold it until it display System Check and then press F1 .
Posted on Oct 12, 2008
Turn into usb drive
USB 2.0 To SATA IDE 3.5 2.5 Hard Drive with an Adapter Cable http://www.youtube.com/watch?v=iE8t5IGr0e4
http://www.ebay.com.au/itm/USB-2-0-to-SATA-IDE-2-5-3-5-Hard-Drive-HDD-Adapter-/330612048804?pt=AU_Laptop_Accessories&hash=item4cfa0383a4
USB 2.0 to SATA IDE 2.5 3.5 Hard Drive HDD Adapter Kit
AU $8.09 free postage worldwide
You would have to remove the hard drive and use a usb sata ide kit
you will then have to connect it to your computer using a usb port
Aug 13, 2013 | Western Digital Caviar SE16 WD5000AAKB -...
Wd50000aakb make into a external usb
AU $8.10 free postage worldwide
Hdd is locked
http://stason.org/TULARC/pc/hard-drives-hdd/western-digital/AL-2200-CAVIAR-LITE-200MB-2-5-SL-IDE-AT.html
Password protection the same idea send it back to the manufacturer or use the correct password and then delete it from the device
Aug 23, 2010 | Western Digital Caviar SE WD1600AAJS 160...
Hi i have a WD1600 160 GB Hard Drive which recently failed ,brought a new casing however when ide cable is connected power is lost does this mean drive is dead?
May be but check your HDD power connection port pins. If there is an loose conn. you shouldn't afraid of it.
Think this is helpful !
Aug 11, 2010 | Western Digital Caviar WD1600 (1600YD) 160...
Toshiba hdd2171 has failed (no boot, very bad sounds coming from hard drive) any ideas what I can replace it with? Appears to be 2.5 inch, IDE 40gb, can i replace it with another toshiba ide hard drive,...
Yes, you can replace it with another Toshiba hdd 80GB or 120 GB. It doesn't have to be a Toshiba HDD. It can be any HDD that has an IDE interface for the ribbon cable to plug into. I prefer Western Digital hard drives myself, but Toshiba does make very good hard drives as well. There are several name brand HDDs out there. Just make sure you go with a name that you trust, I don't suggest going with some off-the-wall brand for a HDD. I've tried some "No Name" HDDs before and they have all failed within a 1-2 year period. You don't want to take the risk of an HDD crash and losing your data again within the next year.
Apr 12, 2010 | Toshiba (HDD2171) 40 GB Hard Drive
Toshiba satellite a15-s157 wifi problem
Your card has the correct drivers installed, but that's not enough Windows XP has native support for WiFi. Just visit
www.toshiba.com and go to Products & Services, select Portables and then on
the left hand side click Support, then choose Tech Support Center, choose
your model of laptop in the list boxes and voila, a list of all Toshiba
drivers, choose the WiFi software and install.
Nov 27, 2009 | Toshiba Satellite A15-S157 Notebook
I want to make an internal western digital 160GB drive from my imac g5 20" into an external drive and need to figure out what enclosure and cables i will need
You need the following
http://cgi.ebay.co.uk/External-USB-2-0-2-5-SATA-HDD-Hard-Disk-Case-Enclosure_W0QQitemZ320419271720QQcmdZViewItemQQptZUK_Collectables_HardDriveEnclosures_RL?hash=item4a9a7a1428&_trksid=p3286.c0.m14
http://cgi.ebay.co.uk/3-5-IDE-Aluminum-Hard-Drive-HDD-HD-External-Enclosure_W0QQitemZ400070866376QQcmdZViewItemQQptZLH_DefaultDomain_3?hash=item5d2614f5c8&_trksid=p3286.c0.m14
http://cgi.ebay.co.uk/New-3-5-USB-2-0-External-Hard-Drive-Case-HDD-Enclosure_W0QQitemZ170377549189QQcmdZViewItemQQptZUK_Collectables_HardDriveEnclosures_RL?hash=item27ab4b1585&_trksid=p3286.c0.m14
Please note the links are an example only.
Sep 02, 2009 | Western Digital Caviar WD1600 (1600YD) 160...
Cloned 40 gb hard drive to a 160 gb for toshiba A15-S157 model
I'm guessing that your question is why does my new 160G hard drive only show up as a 40G. When you use Norton Ghost to make an image of your hard drive, there were several questions it asked. One was whether you wanted to make an image of the whole partition. When this is selected Ghost acts like a camera and takes a picture of your old drive, partitions and all. When you put this image on a new drive it puts on exactly that a picture of your old (40G) drive. I have never been successful a trying to expand an image. As long as the old drive is still good you could start the process over and make an image of just your data, then format the 160G drive, reinstall Windows and place the data image on the new drive. You will have to reinstall the applications.
Mar 23, 2009 | Toshiba Satellite A15-S157 Notebook
How to upgrde sony pcv-rx470ds desk top hard drive; what is the max gb?
Looks like this unit is a couple of years old by the specs.
160 to 200 GB would ba a good size to install in the unit.
It is easy to replace the hard drive. Just remove the old one and install the new by reversing the procedure. Just make sure that the jumper is set to master( which is how the new ones come jumpered)
  • Intel® Pentium® 4 processor 1.50 GHz (2)
  • 128 MB PC-800 RDRAM (expandable to 512 MB)
  • 400 MHz Front Side Bus
  • 60 GB (3) Ultra ATA/100 hard drive
  • 16X max. DVD-ROM/40X max. CD-ROM
  • 12X8X32X max. CD-RW Drive
  • High-speed Internet ready with 10 Base-T/100Base-TX Fast Ethernet
  • 4X AGP 3D Graphics Hardware Acceleration (NVIDIA® GeForce2 MXTM )
  • 32 MB Video Memory (SDRAM)
  • i.LINK® (IEEE 1394) chipset on motherboard (1)
  • Front accessible i.LINK (IEEE 1394) interface and USB connections (1)
  • Programmable VAIO SmartTM Keyboard
  • V.90 compatible data/fax modem
  • Wheel mouse
  • External stereo speakers
  • If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
    Thanks, Joe
    Feb 20, 2009 | Sony VAIO PCV-RX470DS PC Desktop
    Hard drives!
    your harddrive is standard 30 gb on ide connection and u can ad a new hard drive on your notebook up to 250 gb ide but u will have to format the system brandnew
    Jan 01, 2009 | Toshiba Satellite A15-S127 Notebook
    Toshiba Satellite A15-S157 Notebook Logo
    281 people viewed this question
    Top Toshiba Computers & Internet Experts
    Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
