Question about RCA F32450 32" TV
Guide plus gold will NOT leave the screen. IT's a DEMO. Can't shut off
My RCA tv serial number 103612249 has a demo Guide Plus Gold that won't LEAVE the screen Have trouble accessing menu. When I Do I go to Guide Plus Setup and it won't shut off. No option to shut it off. Please advise another way.
  • jshearman Dec 17, 2008
    I have the same problem. It started after we installed a digital cable box. All was fine until the power went out. The demo continously runs. When you access the menu , press ) for exit and the guide demo goes away for about 10 minutes where I repeat the same procedure. I am going to disconnect the cable box and redo the setup of the tv and hop it will auto program the channels and the demo will stop.
    wish me luck.
  • Anonymous Jan 23, 2009
    I have the same problem with guide plus gold. None of the buttons will remove this from my rca tv..............so what good is direct tv. Maybe, we all should report this to the FCC. I am paying the price and can't even watch the TV. If you call Directv you will stay on the line an hour and the problem is still not resolved.
5 Suggested Answers
  • 17 Answers
SOURCE: Guide Plus Demo
I have serviced lots of these, and as far as I know the CTC203 chassis has nothing like this, nor did anything made by Thomson before or since, so I am mystified. Adjustments are made with the remote or the front panel buttons using software and there are no "pins," test connectors, switches, or anything similar present on it. Usually the Guide Plus stops working entirely (which is nice for most users, as it is just an annoyance). Now if you unplug your TV for long enough for its microprocessor to reset, it will start with the Guide Plus screen. This is by design and can't be stopped without modification. Corruption of the set's internal program causing something strange like this is possible, but unlikely. (It was a problem on earlier models). Leave your TV plugged in and see if this problem goes away. If this is not the cause, you will have to take it in for service. Any demo modes can be turned on or off with the remote or the buttons on the set.
Posted on Oct 19, 2007
  • 375 Answers
SOURCE: Rca guide plus gold 32'
pull the ac plug for about 5 min and start your set up again paying atention to the features you want and don;t.set the menu to suite your requirements.
Posted on Mar 20, 2008
bhur
  • 85 Answers
SOURCE: RCA Gold Plus+ Guide problem
go to menu and find the automatic set up of your channel
Posted on Jun 13, 2008
SOURCE: RCA TV GEMSTAR GUIDE PLUS GOLD
what is this TV's modle #?
Posted on Sep 08, 2008
Menu keeps popping up
If you have the guide plus feature go into the setup for it and when it asks if you have a cable box, indicate no, when it asks if you have a Vcr also indicate no. Last if it asks for the zip code enter all 9, This should rule the Guide feature out of service and you will know if it is your problem or not---it created a lot of problems in sets that had it, especially RCA or GE sets.
Dec 20, 2012 | RCA F36650 36" TV
Why does my rca guide plus gold gemstar tv have lines or bars flickering on the screen ?
are they horizontal or diagonal? if they are diagonal it could be you're brightness is turned up too high. try turning it down.
Aug 13, 2012 | RCA F36705 36" TV
Guide plus on my rca p52937 tv
You are right, the Guide Plus is transmitted to your tv over the air. If you have a cable company supplying your programs, your Guide Plus will not receive a signal to set up. You will need to get a two-way splitter. It has two connections on one side and one on the other. The side that has one connection goes to your tv. The side that has two connections will connect to your cable supplier and the other to a rabbit ear or outside antenna. Then the tv has to be off over night to restore your Guide Plus.
prs1c-2266633t98.jpg 2-Way Gold-Plated Bidirectional Splitter pixel.gif Model: 15-2587 | Catalog #: 15-2587 pixel.gif
Use this 2-way gold-plated bidirectional splitter to divide a signal to feed two devices, such as TV...
Jan 30, 2009 | RCA P46924 46" Rear Projection Television
May 27, 2008 | RCA 32F531T 32" TV
Jan 16, 2008 | RCA 32F531T 32" TV
Guide Plus Gold service on a 2000 Zenith TV
I have an RCA televison with Guide Plus Gold and it works great. I am not sure about the Zenith and how it works on it. When I turn on the TV with the remote the guide comes up on screen. I just have to press the guide button on the remote to remove that screen and watch the show. If I don't press anything it will go off after 2 minutes. If you have never set up the guide it will probably show up all the time. You will have to go through and program it so it will know if you have cable, over the air or satelite. I don't have satelite service so I don't know if it will reconize it. I know it works with over the air and cable.
Good luck
Nov 03, 2007 | Televison & Video
RCA F32450 TV
Question?
Whenever I turn on the television, the GUIDE Plus+™ or GUIDE Plus+ GOLD™ on-screen program guide automatically comes on.
Answer:
The GUIDE Plus+™ or GUIDE Plus+ GOLD™ on-screen program guide automatically comes up when you use the TV button on the remote to turn on the TV. There are several ways to turn off this function if you wish, depending on your model.
Option A:
Select the GUIDE Plus+™ Menu from the Main menu.
Select Setup.
Select Options.
Select Off.
Option B:
Select GUIDE Plus+™ Auto Display from the GUIDE Plus+ menu.
Select Off.
Option C:
Press GUIDE on your remote control.
Select the Menu bar.
Press the right arrow button to select Setup.
Choose Review Options.
Select Off.
I know Option C worked for me!!
Given the many TV models, it's possible that accessing control of this feature in the Program Guide menu may differ on your TV. For specific instructions for your model, see your owner's manual.
Oct 27, 2007 | RCA F32450 32" TV
RCA Guide plus gold gemstar T.V
I have a guide plus gold gemstar tv and I cant program my direct tv remote or Innovage jumbo remote to operate the tv, can anyone help?
Oct 22, 2007 | RCA F32450 32" TV
Guide Plus Demo
Feb 24, 2007 | RCA F27649 27" TV
RCA F32450 32" TV Logo
164 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
