Question about Thermador DW44Z Built-in Dishwasher
Water does not go in
The dishwasher is going through the whole cycle but water does not go in.
    Problem Solver:
  • 9 Answers
First make sure that there is nothing on the bottom of the dishwasher tub where the float switch is located. Different machines locate them in different places on the bottom of the dishwasher tub below the bottom rack. If you pull the bottom rack out and find a plastic float and move it gently up and down you will probably hear a clicking sound. That is the switch inside the float. if that works and nothing is hindering it then go under the sink or where ever your water to the dishwasher is getting its supply and make sure the the valve is turned on and there are not leaking problems there. It these things do not work then I would start thinking on the pump being bad or the control panel for the cycles not working properly. Would need make and model number to help with that one... Hope this helps ya.
Posted on Oct 11, 2008
Dishwasher won't drain at the end of the cycle
Whenever an appliance does operate its pumps/valves heaters correctly for part of a cycle then doesnt at another point, it is a problem with the controller of the sequence in the cycle.. On older devices this can be a rotating knob that slowly runs to end of cycle triggering events as it turns, by tripping blade switches near the rotating item. On these the switch trigger points can be inspected and sometimes repaired. On newer items the cycle is controlled electronically, and you have to replace the whole control unit, which is usually a large expensive part that includes the display and all buttons. Try getting a used control unit from Ebay and swapping it out, or consider replacing the whole appliance.
Dec 14, 2013 | GE Dishwashers
Theres no water. i start it on pots and pans theres no water but the timer runs it into the next cycle so basicaly it will go thru the whole cycle with no water heat dry and all
Check under your kitchen sink and make sure the water is turned on to the dishwasher. Next Check the overflow float and make sure there isn't a build up of soap around it. This would give a false reading telling the dishwasher water is in the unit.
Have a great day!
Dec 10, 2010 | Dishwashers
Dishwasher fills with water, then empties, fills then empties, and repeats this cycle a few times - then decides to work. then part way through cycle - it repeats this frustrating cycle, making the whole...
Hi, Your dishwasher may pre-heat the water. If so, and if the water entering the dishwasher is cool, the heater may take up to half an hour to heat the water. To avoid the wait, increase the incoming water temperature before turning on the dishwasher. Do that by running the kitchen sink faucet until the water runs hot. Or increase the temperature of the hot water to the entire house at the hot water heater.
Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
Apr 18, 2010 | Fisher and Paykel DS605I Built-in...
Dishwasher arm is plugged with scale. Very hard
It might but you probably want to invest in a whole house water softener.
Jan 25, 2010 | Dishwashers
Bosch dishwasher
i know this sounds daft but --
turn off water. disconnect fill hose from water supply. wait 5 seconds and reconnect fill hose then try it out
Oct 14, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Whirpool 1100TXP Dishwasher.
is your water temp set at 120 degrees
Apr 07, 2008 | Whirlpool 24 in. DU1100XTP Built-in...
Older portable dishwasher
nothing it needs a switching kit or drain solenoid kit rather
Dec 30, 2007 | GE 25 in. Nautilus GSC3400J Free-standing...
Bosch SHU9915UC Dishwasher - wash cycle won't happen
hi there your dishwasher has gone into flood protection mode ie. water has leaked into the base and activated the float switch.
to try and locate the leak tip your d/w back to drain the water from the base then remove both side panels and start a program to see if you can see where the water is leaking from, being careful not to touch anything while the d/w is running as live parts are exposed
hope this is of some help
Dec 15, 2007 | Bosch SHU9915UC Dishwasher
Thermador DW44Z Built-in Dishwasher Logo
285 people viewed this question
Top Thermador Dishwashers Experts
Starnley Johnwells
Starnley Johnwells
DROPNDEAL
DROPNDEAL
Are you a Thermador Dishwasher Expert? Answer questions, earn points and help others
