Question about Xerox Phaser 8400 Laser Printer
Xerox 8400 light printing
We have a Xerox Phaser 8400 that is printing black on 1/2 of the page and a faded black to dark green on the other. If it is built the same as the 8200 series there are two halogen lights that heat the drum in the preheater unit. My opinion is without tearing this thing apart is that one light has gone out. Does this sound right or could there be another problem to consider.
DPC
    President:
  • 2,072 Answers
No, If one lamp goes out they both will not function. They do not have anything to do with print quality.
You may have a bad maintenance kit. but more than likely you have a bad print head.
Run the cleaning , eliminate stripes and eliminate smears modes. But more than likely the print head is bad. I would say a bad print head is about a 95 percent chance of causing your problem.
The halogen lamps only heat the drum, and if one was bad the machine would fault out with a 15,004 code.
Posted on Oct 12, 2008
Xerox black developer fade printing
Try this: http://www.fortwayneprinterrepair.com/wordpress/2014/03/17/xerox-phaser-6500-workcentre-6505-light-print-issues
Apr 25, 2014 | Xerox 6500/N Phaser Laser Printer
Xerox Phaser 8400 prints pdfs in half page
I've seen this issue on some of my other Xerox machines (not the 8400 specifically). 9 times out of 10 the solution is to update both the printer driver to the newest version, as well as updating Adobe Reader to the newest version.
Here are the links to each:
Xerox Phaser Drivers
Adobe Reader
May 04, 2011 | Xerox Phaser 8400 Laser Printer
Phaser 8400 problem
I would call xerox second level support. There has to be a problem with that driver . I have seen this problem more than a few times. call 1-800-835-6100 and see if they have an alternative. This is an obvious flaw in the driver.
Mar 08, 2010 | Xerox Phaser 8400 Laser Printer
Phaser 7300 - one color fading on diagnostics page
Are you using third party toner? That is one thing that causes that problem. Use only xerox toner.
The other thing is that your image unit could have come defected, if it was brand new. Try changing the image unit and that should fix that problem. Good luck. 016-1993-00 image unit & toner 016-1977-00
Oct 02, 2009 | Xerox Phaser 7300DN Laser Printer
I have a Xerox Phaser 8400 with image problems. After power up it prints a Startup Page - That page is black text which faded and slightly distorted in some areas and in areas that are in Color only...
What you are describing is a bad print head. You can try running the eliminate light stripes several times, and jet substitution, but most likely the print head will have to be replaced to remedy your problem.
You can try googling. Phaser printer print heads or phaser printheads.
There seems to be a secondary market appearing for those print heads. I can tell you from Xerox, if you have no maintenance agreement, they cost $750 per print head.
Honestly, having worked on about every type of color printer known to man, the new solid ink phaser printers, produce a dry ink image of 2400 x 2400 dpi with ink particles that align end to end. The resolution of those printers are remarkable and can be purchased for less than the price of one of those new print heads.
Now for reliable, albeit somewhat not as sharp a color image, but still exceptional, you really can not beat an HP.
The ink stick technology really no longer has the color vividness advantage it initially had. The inks that align end to end, have ended that advantage and are sure a lot cheaper to operate per page.
Feb 27, 2009 | Xerox Phaser 8400 Laser Printer
Dark streaks
Dark streaks are an indication of "burned" or overheated ink. This will occur when the printer sets for a long period of time and nothing is printed. The problem will usually disappear after 50 pages or so, unless the printhead is damaged.
If the print remains dark, the printhead will need replaced.
(Very expensive)
(Dark print can also be caused by using Non-Xerox ink)
Sep 10, 2008 | Xerox Phaser 8400 Laser Printer
Xerox Phaser 8400 Streaking
You can go into the trouble shooting menu and do the "eliminate Light stripes" procedure a few times.
Then you can do Jet substitution from the same menu.
If that does not work then most likely you need a new print head.
If you have used non xerox ink sticks that is your most likely cause of the problem. cheaper is not always better
May 28, 2008 | Xerox Phaser 8400 Laser Printer
Phaser 6250 black toner is super light
http://office.support.xerox.com/SRVS/CGI-BIN/WEBCGI.cgi/,/?St=842,E=0000000000019251353,K=6024,Sxi=13,Case=obj(19377)
Click on Knowledge base from this site , then in the search box enter poor black quality. Look under black is faded or missing
Apr 08, 2008 | Xerox Phaser 6250N Printer
Xerox Phaser 6250 started printing bad
That really sounds like the imaging unit cleaner has an issue.
If you have one try the imaging unit, I really suspect that is your problem.
Black is Faded or Missing Step 1 Clean the Laser Windows and Remove Excess Toner From the Imaging Unit Step 2 Check or Replace the Imaging Unit Gear Retaining Pin Step 3 Replace the Imaging Unit (installation instructions) ic-film.gif
See if this link works. Xerox is infameous for these not working.
Apr 08, 2008 | Xerox Phaser 6250DP Laser Printer
Xerox Phaser 8400 Laser Printer Logo
197 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
