Question about JVC TV-20F243 20 in. TV/VCR Combo
TV/VCR combo will only change from channel 3, 4, line. Do not have original remote
I have this tv/vcr combo. I can not change the channels I only get 3, 4, and line. I do not have the orginal remote. Will a universal remote work? If I have cable do I have to have a cable box to get channels higher than 125.
MikeNJ1964
  • 398 Answers
SOURCE: Remote lost: My TV/VCR Combo only displays 12 channels
Go to http://www.jvcremotes.com/ or any similar site and order the original remote. That way you are sure to get a remote capable of doing whatever you need. The alternative is to keep buying universals until you get lucky and find one that works all functions on that set.
Posted on Aug 07, 2007
SOURCE: DAEWOO TV/VCR COMBO DVQ 14H1FC LOST REMOTE
Hi, Sometimes the universal remotes are tricky.  If you don't purchase one that is specifically recommended by the manufacturer, you won't get full functionality.  Here is a generic that is "replacement" for that remote: http://www.daewoo.newremotecontrol.com/catalog_item.php?catnum=48B4139A02
Here is another place that has the replacement and an alternative: http://www.remotes.com/remotes/servlet/rs?a=gmi&uuid=12257602513440&smodel=48B4139A02&brand_pn=DAEWOO_48B4139A02
Hope this was helpful, have a great day!
Posted on Nov 04, 2008
  • 76 Answers
SOURCE: can't find aux channel to view vcr/dvd
use vid 1 or vid 2 input on remote should do that if not then use a differ code in your universl for your tv that makes it work or type 00 should get u there another way go to channel 1 and then down arrow it will go into it if not go into your add channel menu and add them then down arrow
Posted on Dec 03, 2008
freetek
  • 5568 Answers
SOURCE: programming cable channels for emerson tv vcr dvd combo
To see RCA's code list you probably need their website but Emerson is one of several names now owned and built by Funai, who also builds Symphonic & Sylvania.
You might want to try those codes with your set.
Posted on Dec 18, 2008
SOURCE: i have a rca dvd recorder+vcr combo drc8320n i want to set up watching/changing cabletv channels on the dvd remote. i have tried buying universal remotes cheap& expensive but they no longer work on my
With cable input connected to "RF in"on rear of unit make sure vidoe input is set to "Tuner". This will show up on the TV screen. Change channels numerically or using up/down arrow keys on DVR remote. Note there is a slight pause between changing channels.You probably will have to "autoscan" for channel setup/etc. If you say your TV set is old; it probabaly is equiped with coax
connection only/set TV channel to "3" or "4". when yot opt to play vcr/dvd it will override your
cable channel selected. Hope this helps!
Posted on May 09, 2009
Panasonic omnivision TV VCR combo connected to cable box unable to change channels with either remote . When up or down channel buttons are pressed it goes to "line" when channel numbers are pressed it...
cable box needs connected to the antenna in on the vcr..the setup is ..cable box..vcr combo ..tv ..unless your tv has multiple inputs like ours..most of the new ones require a digital signal..it may reqiure a converter box..
Jan 11, 2014 | Televison & Video
My sharp13vtn100 tv/vcr is coming on only manually but not by original remote. gives me only channel 2,18 and vcr mode manually. how can i get the channel search ?
the remote could be bad get a unversil look up vcr codes not tv found thoses to work for combo unites give that a try or go to ebay for the right remote
Dec 24, 2013 | Sharp 13VT-N100 Combo
Magnavox 20MC4304 20" TV/DVD/VCR Combo Remote:
A universal remote should solve your problem. You should be able to find one on ebay. You may even be able to find one for your particular TV on ebay as well.
Dec 03, 2017 | Magnavox NE206UD TV/VCR/DVD Combo Remote...
Phillips 19 inch TV/VCR combo --no remote--can't change channels
I cannot be sure of the exact model but... Press and hold the TV's volume up and volume down buttons simultaneously. On many older televisions, this opens the device menu without the use of a remote. Otherwise, use the menu button, which you can navigate in a similar fashion.
Also, somewhere should be an input button. Press it multiple times times to switch between various inputs (the input must match whatever input you are using). Usually after these menus are opened you can use vol up vol down to change things.
Jul 13, 2017 | Philips CCC193AT 19 in. TV/VCR Combo
Need to know what channel my TV needs to be on to watch DVD/VCR
The channel you use depends on how you have the vcr/dvd player wired to it. If you used a co-axial wire, then your tv should be on channel 3. If you used RCA wires, then you will have a button, either on the front of the tv, on the remote, or both that says "input" or "source". Pressing this will change the TV to the rca connectors. Try this and let me know if it helps :)
May 16, 2009 | RCA B27TF680 27 in. TV/VCR/DVD Combo
Daewoo DVN-14F6N
Same problem...Went to Goodwill Store, they usually have a large basket of remotes. I found a Daewoo remote for a TV only, HOWEVER on the bottom it has a AIR/CABLE button. The remote doesn't say Daewoo on it only..."Remote Controller R-25B03". The rest of the button of course work with the TV portion of the DVN-14F6N.
Sep 17, 2008 | Daewoo DVN-14F6N 13" TV
Connecting VCR/DVD combo
If you are able to you can connect to the RF connector (F Type Conncetor) on the TV. This should work. The layout is from the VCR (RF to TV) to the TV antenna F type connector from your Cable box to the Antenna in of the VCR that way you have cable through the VCR, and access to you VCR and DVD all controlled by the Cable and VCR remotes (set TV to Channel 3, set VCR to Channel 3) and use the Cable box as the tuner, Use the TV remote to switch between Cable and VCR inputs then use the VCR remote to switch between the VCR and DVD input.
Sep 20, 2007 | GE 25GT516 TV
How can I turn to AV without a remote control (Samsung TV/VCR 19in Combo)
I had this problem with my TV/VCR combo unit (Samsung CXC1972) after losing the remote while in the dorms. I tried a few different universal remotes and dozens of codes before I tried the Philips 3 device universal remote as pictured below with code 037 programmed into the VCR/DVD button. I can't change the volume with this code but the input key switches between line in and tv. You can also change the channel, access the menu and operate the VCR functions with the code. I bought the remote for less than $10 at Walmart so it might be worth a try, and if it doesn't work you can always bring it back. Hope this helps.98fe8a9.jpg
Feb 18, 2007 | Samsung CXJ1964 19 in. TV/VCR Combo
JVC TV-20F243 20 in. TV/VCR Combo Logo
91 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
