Question about RIM BlackBerry 7290
My blackberry 7290 wont charge with the wall charger or the usb cable wat should i do
  • Anonymous Feb 22, 2009
    BB 7290 will not charge with any power source connected.
    On close scrutiny, I found pin 1 of the USB Mini AB receptacle (the charge/data port) pushed back and lodged up against the rear of the connector shell. Without making contact with the mating pin of the cable, it is impossible to charge the 7290 with anything that plugs into the port.
    Unfortunately, I have not yet been able to find a source for the USB Mini AB receptacle that is mounted on the motherboard of the phone. If anyone knows where to buy them I can repair any 7290 that has the same problem so please let me know..
    Sergeant:
  • 291 Answers
Sounds like the charging port has gone bad. Try CPR in New York City. They are faster than the manufacturer, and cheaper! They have a usual turnaround of 1-2 business days. And if you become a fan on their facebook page, mention it and you will get a 10% discount.
Here is the link to their facebook page, it has all the info you need.
http://www.facebook.com/pages/New-York-NY/Cell-Phone-Repair-NYC/312054784441
Hope it helps!
Posted on Apr 13, 2010
    Master:
  • 441 Answers
Have you tried changing the battery?
Posted on Sep 07, 2009
    Problem Solver:
  • 10 Answers
Honestly, bring the phone, battery, and both the home-charger and USB-cable into a Storefront location that has a technician (call-ahead) and plan on dropping off your phone for a few hours. They will test the battery, phone and charger and let you know which, if any are defective and replace under warranty if you are still under warranty. Don't forget to take advantage of any upgrade offers, as this is an older model and you may be much happier with a store-representative matching-you with a device that fits your needs and is problem-free! (Usually it's the battery on this model - probably around $30-$40 for a new one - the batteries do degrade slowly over the months and years.)
Posted on Sep 02, 2009
Blackberry curve 8350i wont charge
Won't charge with wall charger or won't charge from USB cable.?
Sep 25, 2010 | Blackberry Curve 8350i
My blackberry 8820 won't charge
What are you using to charge it -- the AC adapter (wall charger) or the car charger? Try using the other one and see if it will charge that way -- if it will, the problem is whichever adapter won't charge it. If neither will, then maybe you have a problem with the battery.
If you don't have a car charger, you can also try charging it from your computer by using a USB cable.
Aug 05, 2010 | RIM BlackBerry 8820 Smartphone
My blackberry phone wont power up or charge
It probably wont power up because it wont charge. the USB port may be bad preventing it from charging. I assume you have tried both the wall charger and the computer connection and have not had any luck with either one. Its probably the USB port has stopped working. common problem if the USB cable had been yanked or severely stressed while plugged in to the phone
Feb 16, 2010 | RIM BlackBerry Curve 8310 Smartphone
My blackberry is not switching on
Open the back cover and clean the contacts with DRY CLOTH.
Make sure the BB and battery contacts are all line up.
Close the cover.
Use the wall charger to charge the BB for 2+ hours.
DO NOT use the USB data cable to charge your Blackberry.
When the PC/Laptop/Mac go to power saving/SLEEP mode it will cut off the charge to the Blackberry.
Plug the power pack in a different wall socket and it the Blackberry charge.
Nov 11, 2009 | Cell Phones
I need the drivers for rim blackberry 7290 for connecting with my laptop . how i can do that ?
if you have a computer charger for your blackberry just use the charging cables.
Oct 22, 2009 | RIM BlackBerry 7290
Blabkberry wont charge or turn on.
That usually means dirty power. Make sure you are using a good cable to charge the phone, not all micro-usb chargers work...for example some of the motorola chargers. Make sure there isn't a short in the charger cable. See if the same problem occurs when you attach to the computer USB.
Oct 09, 2009 | RIM BlackBerry 7290
Why will my phone not power on? The let stays solid while charging but will not power on
are you trying to charge the phone with the wall charger or the USB cable. if it is the USB cable then chk if the USB port both on the laptop and the hand held is faulty or not, then chk if the USB cable is faulty or not. if you are to charge through the wall charger then check if the charge is faulty if every thing this is fine then get chk the battery.
Aug 07, 2009 | RIM BlackBerry 8800
Blackberry world edition, will not charge...
What you can do is use the usb cable that came with your phone and hook it up to the computer to charge this will work unless there is something wrong with the phone itself the second option you could do is buy yourself a travel charger you can plug into the wall :).
Jun 22, 2009 | RIM BlackBerry Bold Smartphone
My Blackberry Wont charge?!
look at the 6 pins on the phones charge port and see if one is higher than the others (usually on the end). if the pins is too far up the lower half doesnt connect to the charger. If your usb port will charge on via usb "DOCK" then more than likely the charger itself (which is way more simple to fix)
1.) if one of the pins on the phones charge port is pushed up, grab a sewing needle and GENTLY push the pin back into place,
2.) if the charging dock is working and is a usb charger like your wall charger, buy a new wall charger at your local electronics store.
hope this helps!
Jun 12, 2009 | RIM BlackBerry Pearl 8100
RIM BlackBerry 7290 Logo
97 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
David
Martin Murray
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
