Question about Frigidaire 24 in. GLD2162RDC Stainless Steel Built-in Dishwasher
The middle spray arm has come off
We have a frigidaire diswasher that the middle spray arm came off
  • jsdproject Oct 11, 2008
    help, we have a frigidaire dishwasher that the middle spray arm came off. It does not look like it is can fit back on. How do you reinstall it?
  • Anonymous Jan 26, 2009
    The spray arm and tower came off & I can't find a position where it fits the bottom mechanism
    Problem Solver:
  • 9 Answers
If the arm does not appear to have broken parts, then it probably came unscrewed. The screw and washers may be in the bottom of the machine or instead of screw and washer it may be a plastic locking device. (depending on what model) Those screws or plastic locking device almost always screw in backwards. So, to but it back on, turn to the left as if you were loosening - but you are actually tightening.  Hope this helps ya.
Posted on Oct 11, 2008
There's a bit of a rattling noise when the diswasher is running, as if something is in the pump. I've removed the strainer to see if anything is in there, but nothing. How do I remove the sprayer...
There are some GE dishwashers where the middle spray arm tube vibrates as it washes. This middle spray arm is attached to the top rack. The end of this spray arm tube where it goes into the back wall is loose. There is an after market rubber washer from GE that goes there to prevent vibration and make a tighter seal. Or you can put a tie wrap around the tube end and rack to prevent vibration.
Mar 03, 2014 | GE Dishwashers
Frigidaire Model FDB780RCB0 I am getting water in the machine but it seems the arms are not turning what can I do to get that fixed?
The pump in the dishwasher is supposed to provide enough water pressure to turn the spray arms and make them rotate. The pump is faulty and not giving enough pressure or the arms are stuck.
Try spinning the arms, if they rotate smoothly, you will need to replace the pump.
Aug 03, 2008 | Frigidaire Dishwashers
Middle arm loose
Hello Mike Hilgers - There are two main reasons why the middle spray arm could possibly be loose. Either it is not installed properly or the bracket that mounts it to the bottom of the rack is broken or loose. Carefully remove rack, spray arm and reposition correctly with all rack wheels inside rack slides. If you have already done so, replacement parts may need to be ordered or it could possibly be a more serious issue coming from the interior dishwasher.
Mar 03, 2013 | Frigidaire FGHD2433KF Builtin Dishwasher
The middle spray arm isn't rotating
There is a pipe/tube that runs up the back of the inside of your dishwasher. This provides water for the top spray arm. The spray arm has a feeder tube that covers the pipe in the back. If for some reason the feeder tube has come dislodged, the water just drips back down into the dishwasher, never touching your upper shelf. My kids used to jam cutting boards and other large items into the lower shelf and in so doing, would dislodge the upper spray arm feeder tube. Just pull out the upper shelf and check to see that the tube is in the correct position. This should solve the problem.
If not, then the spray arm may have debris in it that keeps the water from being forced through the jets. You'll need to flush the arm with the spray attachment on your kitchen sink. I sometimes use tweezers or a toothpick to dislodge bits of peelings, paper, or bone that manage to get into the sprayer arm.
I hope one of these tips helps. If it does,please come back to fixya and rate my answer.
Jul 04, 2011 | Frigidaire Dishwashers
Middle spray arm clogged
no it cant to clean a dishwasher good the best thing you can do is run lemeshine often found at a publix or wallmart in the dishwasher detergant isles . if you try to sepperate the arms ther is a very good chance you will break the water tight seal and it cannot be fixed without replacement.
Jun 02, 2010 | Frigidaire 24 in. FDB1050RE Built-in...
Diswasher propelors not going round
I found a lot of stuff built up in the spray arms and replaced them...wife is happy again... :-)
Here is a tip that I wrote about your problem...
http://www.fixya.com/support/r4319937-dishwasher_maintenance
heatman101
Apr 20, 2010 | Dishwashers
The diswasher arm does not rotate or spray water
Check the small holes on the spray arm. They are most likely plugged. (candy wrappers, tooth picks, popcorn or watermelon seeds, you name it.) Sometimes you can clear the holes out, other times it is just as easy (and not very expensive) to replace the spray arm(s). List your model number if you need part numbers or instructions on removing spray arm.
May 14, 2009 | GE 24 in. GSD2000Z Built-in Dishwasher
Diswasher
Check your spray arm that nothing got stuck in its holes. make sure the spray arm is turning all the time when using the machine :
put the spray arm in 90 degree position, turn the unit on , check that the spray arm move...
make sure your seal of the door is clean and nothing prevent it to close evenly the door...
good luck 911servicetoday . com
Jun 19, 2008 | KitchenAid KUDS01FKSS Dishwasher
Top rack not cleaning
load 4 cups right side up in all four corners of top rack, move all wash arms to a known positon(pointing foward just want to check there rotaiton). start diswasher, when you hear it start washing give it 30 sec or so andpop it open try to focus on middle spray arm when opening, shlould be turning quite well. and glasses sould be starting to fill. at least thats how it SHOULD operate
Feb 25, 2008 | Dishwashers
Top rack not cleaning and spray arm possibly not moving
I removed the lower arm, the strainer, and three screws (Torx, but I used small allen wrench). I took of the pump cover, and found a small white ball blocking the tube that goes to the top rack sprayer. I put everything back except the ball. It has worked well ever since.
Nov 03, 2007 | Frigidaire 24 in. FDB1050RE Built-in...
Open Questions:
Frigidaire 24 in. GLD2162RDC Stainless Steel Built-in Dishwasher Logo
123 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
