Question about Cuisinart DTC-975 Coffee Maker
My cuisinart coffee maker won't work. There's power but the water won't run through. It started after I used CLR to clean it.
  • 85 Answers
SOURCE: self clean light keeps blinking
Hello guindonlm,
I recently had this similar problem. Try the following.
Your described problem may be one of two problems. Let's start with the easier solution first. In the DCC 1200 there is a filter "stick or column" in the left rear. Pull it out and remove the clogged carbon filter(s) that are in there. Shine a light into the receptacle and remove the debris in the bottom. It is likely that this is causing the problem with you machine needing to be started on multiple times. See if this solution works. If it does, you might run 8 cups of water and 4 cups of vinegar through to help decalcify the units plumbing. Do this once or twice and then rinse with at least one pot run-through of clean water. If this works then you are good to go.
Next, if this does not solve your problem we can do the following: unplug the unit and lay it on its back. You will need a #10 torx driver (hardware store if you don't have one) to remove the bottom cover plate. There are 4 torx screws holding it on. When removed, you will find 2 orange hoses. Carefully attempt to remove the left hose without splitting. I used a eyeglas screwdriver to loosen it up. If it splits, just cut off the split and stretch it to reconnect when time comes. As you look into the hose you will find a little black valve inside as well a some gunk. Clean it all out with a fine wire as best you can. Rinse well. Attempt to reconnect the hose back onto the pipe. Slip the pipe clamp back into place. Replace the cover and screws and you should be good to go again. This is not as daunting as it may seem. You can do it. :o) Good luck! If this answer helps, please leave positive feedback for me. Much appreciated. Regards, NormanZ
Posted on Jul 08, 2009
Noggin
  • 944 Answers
SOURCE: Self clean feature on coffee pot
here is the link to the manual http://www.cuisinart.com/share/man/25_man.pdf page 8 - looks like you have a calcium buildup - descale overnight using vinegar/water 50% if the self clean feature is not able to deal with the problem. hope this helps :)
Posted on Mar 10, 2007
  • 6 Answers
SOURCE: Water leaking from the base of the unit.
Water leaking in the DGB-600 is mainly caused by heated water escaping from its proper path. There is a rubber grommet on the underside of the upper part of the coffeemaker. (It contacts the lid over the filter basket when the front door is closed.) The design in this area is very poor; the grommet does not seat properly in the fixed part of the coffeemaker, and heated water seeps out. Also, the heated water tube that comes up through the cold water reservoir is actually in 2 pieces. One goes inside of the other, but there is no seal. It is a loose enough fit that some steam escapes, condenses on the inside top surface of the coffeemaker, and then finds its way down to add to the leaking. I completely disassembled my coffeemaker (3 of the screws in the upper compartment are hidden under small circular plugs that look like they are part of the plastic surface), and used high temperature automotive RTV sealer to help the rubber grommet seal better, and to seal the 2-piece hot water tube. Works great now! But I must say that I have seen better engineering in childs' toys!
Posted on Aug 12, 2008
  • 1011 Answers
SOURCE: My cuisinart carafeless coffee maker is not working..
dear,
read this comment and you will get what u want .
or if any confusion, read its manual keenly.
regards,
Posted on Aug 24, 2008
  • 4 Answers
SOURCE: Cuisinart DCC-2000 12-Cup Coffee Maker shuts off after brewing
Turn the function knob to Auto Off
Hold down the hour button til you see the clock display blinking
you can then use the Hour and Minute buttons to program how long you want the coffee maker to stay on.
You can choose from 0 minutes (seems to be what you have it set on now) to 4 hours.
Posted on Nov 15, 2008
How do you fix a keurig machine that produces only a half cup each time
Try de-liming it first. Use CLR and follow the instructions for a coffee maker. Then rinse with a vinegar and water solution. Then clean cold water. Let me know if it is fine or improves.
Aug 01, 2014 | Cuisinart Keurig B50 Single Cup Coffee...
Dcc-1200c- coffee
you can try CLR and hope for good results .
Jan 03, 2018 | Cuisinart Coffeemakers
My coffeepot worked fine yesterday and then when I ran it this morning the water was not soaking all of the grinds and came out like dishwater. It's only 7 months old and I'm ready to tear my hair out. ...
I'd start by cleaning it. Simple white vingar will work, but what I have found works even better is CLR (calcium, lime, rust). I usually put in a cup of CLR and 5 cups of water, turn the coffeemaker on for a minute to get the water started into the machine and then turn it off for 15 minutes, then turn it back on and let it run. Put a filter in the basket and you'll be surprised what comes out.
Then I would run a pot of water and vinegar, about 50/50 and then flush it with 2 pots of just water..
Dec 03, 2010 | Cuisinart Grind and Brew 10 Cup Coffee...
It is getting increasingly difficult to clean the coffeemaker when the clean light comes on. vinegar doesn't touch it. This morning I used a whole bottle of CLR over 5 attempts which finally got the...
This is my solution and so far it's worked great. I use "Dip It" coffee maker cleaner, following the instructions on the dip it bottle. I use the clean cycle and run the 5 cups of water and 1/2 bottle of dip it. Once it runs through, I run two cycles of clean cold water. I unplug the coffee maker and let it sit over night. I get up, reset my clock and "presto" the light doesn't come on. I run 2-3 pots of coffee daily so I end up cleaning it as soon as the light comes on haven't had any problems since I started doing my cleaning this way. Before that, I was about to scream! I hope this works for you.
Nov 27, 2010 | Cuisinart DCC-1200 Coffee Maker
Cooks coffee maker ...lits up but does not go thru the coffee making cycle...about a year old...never has been cleaned...this coffee maker does not need a paper filter...how do i clean it?? i have no inst....
If it does run some water throught you can try to de-calcify the coffee maker by running a cup of CLR (brand name) through the cycle a couple of times. This will clear most of the water mineral deposits that often clog the coffee making system. After the CLR treatment, run clean water through the system at least twice to clear any remaining CLR. Hopefully this will allow you to enjoy coffee again.
You should clean the coffee maker at least every 30-45 brewing cycles depending upon the hardness of your local water. Regular cleaning by running a cup of white vinegar should work with the more aggressive CLR treatment if you have very hard water.
Hope this clear the problem. Thanks.
Nov 22, 2010 | Cook's Essentials CEFB2B
Where is the clean button on the coffee maker?
There is no clean button.
To clean the scale buildup in the water system, you need to run a couple of cups of clear vinegar throught the system, run 24 cups of water (2 brew cycles) through the system to flush.
If the buildup is severe, you can substitue a calcium cleaner like CLR (Calcium-Lime-Rust) cleaner in place of the vinegar for a more aggressive cleaning.
Depending upon the hardness of your water, you need to do the cleaning every 30-45 pots of coffee.
Let me know if you have any other questions. Thanks.
Sep 06, 2010 | Cuisinart DCC-1200 Coffee Maker
Cuisinart DCC2000 quits brewing after 1or 2 cups
Finally, I got my coffee pot to run through without stopping several times. To fix it I had to run vinegar through eight times! Never before has it taken so many cycles to clean out a pot. It is still spluttering a bit so today I am going to get more vinegar or maybe even CLR and run it through a few more times.
Nov 18, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Cuisinart Coffe Maker has no power
vinegar is not the best thing descaler vinegar remove calciumin little piece that might block thr rest of machine descaler produit melt calcium 1 part solution 1 part water fill the water tank start machine leave it running for few second turn off for 15 minute and repeat untill empty dont forget to rince the machine very good that stuff is very corosif but does the jobs thanks for using fixya pierre
Feb 09, 2008 | Cuisinart DCC-1200 Coffee Maker
Leaking cuisinart grind and brew
Our Cuisinart grind and brew was leaving a puddle under it after making a pot of coffee. I called Cuisinart this week and it turns out the handle of the carafe has to be lined up in the middle of the opening for the carafe. It will be under the word Cuisinart, in the middle.
We have now made several pots with NO residual puddle of water or coffee. It also seems to be making the pots quicker.
Before trying this I had run 2 pots of water with 1/2 cup white vinegar in it also. But it still puddled until we lined up the carafe as noted above.
Nov 30, 2007 | Cuisinart Coffeemakers
Mar 10, 2007 | Cuisinart DCC-1200 Coffee Maker
Cuisinart DTC-975 Coffee Maker Logo
2,941 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
