Question about Whirlpool Duet 3.8 cu. ft. Front Load Washer
Whirlpool washer hi, i know you said to call for help about my washer, but do you know how to open my washer up so i can check if i have some change or somthing in there?
    Scholar:
  • 64 Answers
Ok due to the bread crumbs I get from the top of this post (All Products > Whirlpool > Duet 3.8 cu. ft. Capacity Front Load Washer > Troubleshooting > Problem > Solution) I’m going to assume that you have a Whirlpool Duet 3.8 cu. ft. capacity front load washer....If that is the case you will need to first remove the front cover below the loading door... there will be 3 Phillips screws on the very bottom of this cover. You will see a white cap in the very center bottom. You are going to need a bowl to catch some water and probably some debris when you remove it....Make sure you get all the debris (coins wrappers...ect...) out before you put the cap back on the drain...Then try to run a normal cycle again. You can always run the diagnostic program that is found in the manual which is also located behind that front bottom cover.....please make sure the washer is unplugged before you remove any covers......let me know if this helped...
cbinny1
Posted on Oct 20, 2008
    Sergeant:
  • 409 Answers
if you can supply me with the full model #, i will send you the exploded view diagram to make this easier.
Posted on Oct 12, 2008
Is 10194450 the model # of my whirlpool washer
Hi Adrian, no this number is not a model number for a Whirlpool Washer. If you have a top loading Washer, you can locate the model/serial number by looking just under the lid around the tubs rim. If you have a front loading Washer, the model/serial number can be found by opening the door and looking around the opening of the Washer. The model number will begin with letters, usually with the letter W. We hope this helps.
Apr 05, 2017 | Whirlpool Washing Machines
Whirlpool LSL9345eq0
Hi i dont think it is a train smash, Whirlpool normally have a cartridge fuse in the wiring harness. You will need to open the top panel and look inside the cover and you will see the fuse assembly. Open it and confirm the faulty fuse. Replace and test. Make sure no water is present on retest.
Jun 23, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool front loader cant open the door the display just blinks
To open the door you need to remove the panel below the door (three screws at bottom of machine) then reach up by the door lock and there will be a plastic tab hanging down, that will be the manual release for the door, just pull it down. Wile you're in there see if the technicians packet is taped to the inside wall of the washer, it helps to explain the workings of your machine. If the display is blinking, is it blinking a code? like F11 or FdL? Knowing the code will help in troubleshooting the problem. Good luck.
Feb 24, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool washer doesn't unlock the door at the
Hi There
I have found this for you to read. it's door unlock error. Hope this helpful and let me know how it goes.
F/dU Door Unlock Error
A Door Unlock Error occurs if the door cannot be unlocked. It will try to unlock the door 6 times before displaying the error.
  • Door Lock Mechanism broken.
  • Check Door Lock/Switch Assembly for foreign objects
  • Check Wire Harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
  • Door Lock/Switch Assembly Failure
Thank you for writing to fix ya.
Best Regards Richard
Dec 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool duet washer is filling with water when it is off. it only drips, but two days in a row it was filled up above the bottom of the door openeing and spilled on the floor,
This problem is either attributed to a defective water inlet valve, or defective pressure switch. An easy way to determine which one may be causing the problem is to unplug the washer, but leave the water taps on. If the washer continues to fill, you have a defective water inlet valve. If the water stops, I would recommend changing your pressure switch.
Post back and let me know if you require further assistance. I hope this helps you.
Sep 06, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I cannot remove the basket from the tub.
i am a maintenance man at U OF I and need to change the tube seal on this washer but dont know how to remove the ajatator btoolmanA illicom.net
May 12, 2009 | Whirlpool LCR7244H Top Load Washer
Washing Machines Logo
149 people viewed this question
Dan Webster
Dan Webster
Sal De GO PATS
