Question about Palm Treo 650 Handheld
Treo 650 blank screen
Ok ok my 650 i have already replaced the screen once, and now i thought the screen went out on me again. So i swapped screens and still the same thing my screens works on another 650 but the other screen does not work on mine... heres the real kicker i can still use the touch screen to answer calls, to call people, and to get on realplayer.I've tried resets without any luck i'm starting to think that its the mother board or something.. any ideas please let me know
SOURCE: Touch screen doesnt work
try to open the case, clean the screen and the small frame carefully, reinstall and... good luck, mine worked this way.
Posted on Oct 06, 2007
  • 537 Answers
SOURCE: Receiving MMS on Treo 650
This device should be compatible with MMS.
I found this thread which might help you set up MMS on your Treo 650. Look at the 2nd entry:
1. Start, Settings, Connections, and then tap the Connections Icon
2. Under "My Work Network" tap Add a New Modem Connection
3. Name it Picture Messaging and under Select a modem select (GPRS,3G)
4. Under Access Point Name type: wap.voicestream.com
5. Username, Password, and Domain is left blank and then click Finish
6. Now, go into Proxy Settings and check "This network connects to the Internet" and check "This network uses a proxy server to connect to the internet"
7. Under the Proxy Server box type: 216.155.165.050
8. Tap the advanced button and tap on the HTTP line. Make sure the HTTP settings shows 216.155.165.050:8080. If not, change it.
9. Click the OK button a few times to get out of the settings completely.
10.Now go to Start, Messaging, Menu, then Options, Advance, then Click Manual, and then the Edit button
11. Message center number +12063130004
12. Email center number is 500
13. MMS gateway address is 216.155.165.050:8080
14. MMS URL is http://216.155.174.84/servlets/mms
15. Finally under Network Profile select: My Work Network and then click ok.
Posted on Dec 13, 2007
SOURCE: Treo 650 "Dead Screen"
Try plugging in your Treo as if you were charging it.
Then click the reset button in the back.
This should reset the charging mechanism inside.
See if the Treo starts to charge again after that by letting it sit for 1-2hrs.
Posted on Jan 04, 2008
SOURCE: lost speaker on my Treo 650
This problem usually occurs when the headset jack is busted. If there is sound through the headset but none when you plug it out, then a busted or faulty headset jack is definitely the culprit.
Posted on Apr 29, 2008
SOURCE: Palm Treo 650 Unlock Code.
do u have a unlock code for your treo 650?can u share me a code so that i can unlock my treo 650 here is my messenger and email account respetadong_pogi@yahoo.com i hope you can help me too.
Posted on Aug 16, 2008
Is there a way I can revert my Palm Treo 650 back to original factory settings
Factory Reset for Treo 700p and 680 smartphones
If you've set a password on your smartphone, any hard reset will automatically become a Factory Reset. With this method, you'll enter a password and then perform a hard reset.
On your smartphone, launch the Security application.
2.If the Password box says "Unassigned," tap the box and create a password for your smartphone.
3.Once the password has been set, disconnect your smartphone from the AC charger and take off the battery cover. Do not remove the battery yet.
4.Hold down Power/End .
5.While holding down Power/End , remove the battery. Then insert it again.
6.While still holding Power/End , the screen will show the Palm logo and a progress bar. Then the circular Palm Powered logo will appear. Release the power button when you see the Palm Powered logo.
Keep holding the Power button during this screen. When you see this screen, you can release the Power button.
7.A message will appear warning that you are about to erase all the data stored on your smartphone. Press UP.
8.If you performed this reset correctly, the screen will go blank after several minutes, and you will not be able to turn on your device. The charging LED will not light up. (any other activity - such as the Palm OS logo and then the Applications launcher appearing - means the reset was performed incorrectly; try again) 9.Your device will appear "dead." To wake up your smartphone, perform a soft reset.
if u like plz comment
Mar 11, 2010 | Palm Treo 650 Handheld
Treo 650 suddenly went to a palmone boot up screen then to a palmone powered screen and just keeps repeating without fully going to the normal screen mode for the phone.
When the first screen flashes, as the bar is loading, hold up. Let go once the bar finishes. If that doesn't work you may need to hard reset. Just google how to give it a hard reset and remember that you will lose everything that isn't backed up if you do.
Feb 12, 2010 | Palm Treo 650 Smartphone
Old Treo 650, with slight deterioration to screen.
I believe that serial numbers are different for everything and that only model numbers stay the same. Most likely, the screen will work.
Jan 20, 2010 | Palm Treo 650 Smartphone
Treo 650
Try a Zero Reset - but you will loose all your data
Sep 25, 2008 | Palm Treo 650 Handheld
Call your service provider.
Jul 16, 2008 | Palm Treo 650 Handheld
Treo 650
my treo 650 just turned of the light of the screen.thought it was only battery.i pulled out the battery then put it back again,the light is on and say palmOne with a bar loading.then the light was gone again.try to sign on but nothing does
Jun 24, 2008 | Palm Treo 650 Handheld
Frequent hanging of my new palm treo650
If it's new, it's under warranty, get a new one.
Also, if you have tons of add-ons, this can cause frequent hangs. Uninstall some of them.
May 25, 2008 | Palm Treo 650 Handheld
Jan 04, 2008 | Palm Treo 650 Handheld
Treo 650 microphone turns off when screen goes blank
Hi
Have you gone under Preferences -> and disabling the auto keygaurd
there are 2 options
incoming calls received +
on a call
try disabling both these options and let me know what happens
Nov 20, 2007 | Palm Treo 650 Handheld
Palm treo 700w
I was able to find many parts for my 700w on ebay including keyboards. You should be able to find what you need too and the keyboard is a sinch to remove and replace onew you have the two needed tools to open your phone, the T-6 screw driver and a cover removal tool that help unsnap the cover which is a bear to do without the tool. Do an ebay search to "Treo Cover tools" or "Touch screens for Treo 650" and you should find all you need.
Robert R.
Nov 03, 2007 | Palm Treo 700w Smartphone
Palm Treo 650 Handheld Logo
Top Palm Computers & Internet Experts
Michael Vincent Cruz
Raj Patel
Andrew Taylor
Andrew Taylor
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
