Thread bunches on back of fabric after only a few stitches.
I just solved this problem with much persistence and a few possible causes. Mkae sure the thread is good quality and cant shred, at least until problem is fiwed. Unscrew plate behind bibbin and check if there is any caught thread, this happens after bottom thread has been looping. Remove any and replace, wind down the needle to check it goes in the centre of hole.
And probably the most important fix it; the tension;
Have your tension set to zero, thread the machine, and when the foot is DOWN, make sure it is very hard to pull the thread. It should be easy to pull the thread when the foot is UP. If the thread is easy both ways it has not caught correctly in the tension plates, thread it again (and again) until this happens. It shouldn't be possible to thread the machine without it going in the right place, but it is. And make sure when you rethread that the foot is UP until you thread the needle-
Another problem maker I also had to fix; ever so slightly bent needle.
i seem to have done everything humanlt possible, have taken it in for repair and it still happens
