Question about Mamiya Cameras
Just got a 645= shutter "release jammed:, I put in new battery and also missing the crank arm, must have had a motor handle before. its like new, meter in prism works new battery,have old 645 J to takeoff handle but HOW TO GET IT OFF???so I can try it on this goodlooking unit?
  • 2 more comments
  • rentalshoe Oct 11, 2008
    i have a FILM 645 mamiya, not a digital as the 1st response solution refered toso my quandry still exists.
    no movement so far. how can i take off the film advance lever from the old 645 to put on the one I just got that has none, maybe this would complete a cycle that would unjam the shutter, the mirror is stuck on the ceiling of the body. must have had a automatic handle advance before I got it.
  • rentalshoe Oct 12, 2008
    My 645 has a stuck shutter, I need to put a film advance handle on it to see if that is problem, how can I take a film advance handle off my old 645 for this newer one to see if I can activate the shutter, my newer one must have had apower handle and it came bare. surely its simple to remove a handle,hasselblad is simple but this mamyia stumps me.
    wonderful,happy camper here, I knew that this jammed shutter could be released, all I need was the diagram from "anaanymous" directions, thank you.
    Old guy loved film and good cameras; had to save this one. don
    Sergeant:
  • 352 Answers
Mamiya doesn't offer a downloadable pdf file, however, the manual in its entirety can be read here:
http://www.mamiya.com/assets/pdfs/645/645_Pro_TL_v8.pdf
This may contain the views and diagrams to assist to you in your camera surgery.
anaanymous
Posted on Oct 11, 2008
    Sergeant:
    Champion:
  • 435 Answers
Hi, You could try this:
Try1: Remove the film, and reload the insert with an empty spool only. Then try winding to frame 1 and shoot. Sometime there is a  odd chance that something (film/ insert) related was jamming somewhere.
Try 2: Set the camera to Multi-mode to fire without film. Set the shutter to "B" on the body (Doesn't need a battery) and see if it works.
:) found these in photo.net
    Genius:
  • 1,124 Answers
Set the camera to Multi-mode to fire without film. Set the shutter to "B" on the body (Doesn't need a battery) and see if that does the trick.
    Sergeant:
  • 399 Answers
If the shutter is jammed just off the device,and slightly pull the shutter door with your hand 3-4 times.apply a drop of oil on both the sides.and then on the device.and check it will work.
and for the replacement off the handle you will have to check on the old device that where are locks in the back you just have to remove that locks,also check for the hidden screws in the centre or back of the handle.which may be blocking it to be removed easily.
thanks.
I have a kitchenaid KUDS01DJSS0 DISHWASHER THAT WAS MAKING LOUD WHINE NOISE..
you are better off getting a new dishwasher which is more water and elelectricity efficient. around 10 years is a good life and it will be putting good money aftger bad.
Jul 18, 2012 | KitchenAid Dishwashers
Wont turn on after having brand new batteries put in
The non-functioning of the camera can be a fault in the shutter, zoom or auto focus sections and may be due to the failure of the Main control system or the drive. A simple was is to reset and we can try by removing the battery and card for some time. Now replace only the battery and while switching power ON, tap the lens hood on the palm of your hands so as to disengage any dirt or mechanism being struck.
Use some air to blow between the lens to dislodge any sand particles struck inside. Unless you are familiar with handling of small devices must the camera be opened. If so check the voltage on the motor drive, check the auto focus and Zoom drives, it must be free with manual movement. If jammed the motor can be removed and released. If none of these works then you can think of taking consensus with the service centre.
Get estimate before you decide. It will be good to have it checked at the authorised service as you do not have to run around for spares.
Thank You for using Fixya
Sep 06, 2011 | Olympus SP-510 UZ Digital Camera
My camera wont turn on and i have put new batteries in it
The non functioning of the camera can be a fault in the shutter, zoom or auto focus sections and may be due to the failure of the Main control system or the drive.
Sep 02, 2011 | Pentax Optio M20 Digital Camera
What are "lens error" fixes 4, 5, and 7 ?
The fault of a lens error be it in the shutter, zoom or auto focus is due to failure of the Main control system or the drive. A simple was is to reset and we can try by removing the battery and card for some time. Now replace only the battery and while switching power ON, tap the lens hood on the palm of your hands so as to disengage any dirt or mechanism being struck.
Aug 08, 2011 | Canon Cameras
No shutter
The shutter can fail to failure of the control system. You can remove battery and card replace battery and while switching on tap the lens hood on your hands so as to disengage any dirt or mechanism being struck.
Use some air to blow between the lens to dislodge any sand particles struck inside. Unless you are familiar with handling of small devices must the camera be opened.The shutter motor/mechanism can be jammed , manually try and release if not check voltage on the motor to confirm the fault.
Jul 28, 2011 | Samsung L110 red Including Charger,...
My 645 1000s shutter buttons wont pop back up.this is my 1st mamiya
You might want to check and make sure the battery is still good. If you purchased the camera used and didn't change the battery then this might be the case.
But in the mean time this is what you need to do:
1st-make sure that the shutter speed dial is set to any shutter speed other than the red circle w/red ring. If your camera is set to that it will drain your battery when not in use since it is designed to be an automatic setting. I set mine to 1/125th to do this push in the circular dial on the side and at the same time turn the knob.
2nd- locate the 2 levers on the opposite side of the shutter speed dial. Once you found them then position the back lever all the way forward towards the setting for "MULTI" and position the lever towards the front straight up.
3rd- then wind the film crank till it won't wind anymore and depress the shutter, if it is wound and the shutter release is still stuck then skip to the fourth step, if something happened and you heard a click then still proceed to the next step because no the shutter release will be temporarily stuck.
4th-Once both of these levers are in this position there should be a red button just behind the shutter release button on the top right side of the camera.... drum roll please...."Push the red button" what you should hear is a rather loud click, this click is the mirror releasing allowing you to: 1 wind the film crank and take another picture and 2 this also now allows you to see through the lens again (assuming that you have a lens on the camera).
In Conclusion: without a battery that is fully functional in the camera this is how the camera will operate once you get a battery for your camera then reposition the levers on the side of the camera opposite of what I suggested (this will be the normal operating mode for the camera with a battery) then when you wind the film crank and depress the shutter everything will function normally.
Jul 12, 2011 | Mamiya Photography
My GE downdraft (ZVB36) does not function. I had to unplug it because it make a continuous humming sound. I have looked for a reset button & could not find one.
The crank arm which raises and lowers the hood has jammed most likely against the vertical bearing guide in the center of the box.
Fix is:
a. If the hood is up, support it somehow so it doesn't crash down. Unplug the whole unit.
b. Pull off the box covering the motor and electricals.
c. Pull off the motor/gearbox assembly. Careful here, as this will release the crank arm which may still be under some load, causing the gearbox assembly to rotate on you.
d. Bend everything back into shape.
e. You may need a new crank arm or gearbox if the shaft to the crank arm is bent.
f. Reassemble. This is most easiy done if the hood is held up by someone or something.
Aug 21, 2010 | GE Monogram ZVB36 36" Downdraft Kitchen...
Pentax P30 - shutter jammed after flat batteries, no lights
Common problem.
Shutter motor needs replacement.
Mar 19, 2009 | Photography
Cameras Logo
120 people viewed this question
Top Mamiya Cameras Experts
Tony Parsons
Tony Parsons
Are you a Mamiya Camera Expert? Answer questions, earn points and help others
