Question about E-Machines eMachines Monitor E15T4
My monitor works for a little while, then goes black.
My monitor works fine for a little while, then it just goes black. If I shut down and re-boot, it comes back on...but only for a little while and it goes black again.
  • PeggyHood Mar 13, 2009
    I'm having the same issue with an Emachines flat monitor model 568 eview 15L. What can I do to fix this?
  • garyr121234 Mar 17, 2009
    "My monitor, emachines E15T4 15" flat panel, works for a little while, then goes black." first note witht eh red green blue is "No Signal" then all black screen with white rectangle with note "Frequency out of range". If I shut down and re-boot the monitor works. Once I had bad color but that seems to have gone away. Once had ithe screen go into a weirdverticla streaky siver, grey, black affair. Is the problem with the monitor or the CPU? How do I, not tech savvy, determine which it is?
    Novelist:
  • 159 Answers
Your power-inverter board needs an overhaul.
Probably in need of the standard capacitor replacement.
OR
a bulb in the screen is bad (a bad bulb will usually show symptoms)
It will flicker, or will look pinkishish for a bit or dark in the middle top or bottom of the screen.
ebaysbammbammfran
Posted on Oct 12, 2008
My hp2009m monitor goes into sleep mode
Monitors are programmed to go to sleep when there is no input. If you shut it down on the other "tower" also it will do the same. You need to physically hit the power button on the monitor to actually shut it off.
Feb 15, 2010 | HP Computers & Internet
Monitor not turns on
first off check all the chords and make sure the monitor is turned on. as you have probably done this try to use a different monitor. borrow one for an hour or something. if the second monitor is black as well it is your video card in your PC and you will have to replace it. If it boots as normal that of coarse means that your Xerox monitor is broken and needs to be replaced/repaired. Hope your warranty is still good. Good Luck.
Aug 18, 2009 | Computers & Internet
Monitor goes black after running for a few minutes. Brand new 22 inch sceen.I prees the button to turn it on and it says Analog and goes black again. I have to shut down the computor to get it to come back...
Sounds like the computer is shutting it down and the monitor is fine. Check for viruses then check your settings in device manager for the screen saver and power down (screen off) options.
Aug 10, 2009 | Dell Computers & Internet
Monitor goes black............
try checking the cables first.
May 28, 2009 | Dell E176FP 17" LCD Monitor
Screen seems to be not working properly
try using a different monitor, borrow one if you have to, if the monitor works on your computer, then it simply means you need a new monitor. As far as the computer shutting down, it may be recording the bad monitor as an error in the loading process and automatically shutting down.
Mar 15, 2009 | HP TouchSmart IQ770 PC Desktop
Gateway 2" monitor won't display
blown capacitors this can be fixed I can help or advise you how to do it but it will require soldering internal components.
Mar 04, 2009 | Gateway FPD2275W LCD Monitor
My monitor comes on for one second then goes black. The green light stays on the whole time.
Check the cables, make sure it is secure on both ends. Also see if you pull up the Monitors on screen menu.
As long as the light is green, that means there is a signal. it could be a bad monitor. Shut off all the lights in the room, then grab a Flashlight and hold it against the LCD screen while it boots into windows. Can you see the desktop now, but very dimm? If you can see the desktop, then connect Your PC to another monitor (if u have one or a friends, perhaps) and boot it up, can you see the desktop on the other monitor fine?, then we just ruled out a Bad video card and narrowed it down to either a Bad Inverter in the Screen or LCD back light issue.
probally not worth fixing, because replacement LCD's arent cheap. nowadays at the right sale you can buy a Brand new LCD monitor for as little as $199
good luck,
djEnigma
Apr 01, 2008 | Computers & Internet
Thinkpad lcd wont come on
Hello, It may be the power is set wrong. Click start, control panel, power options. From here you can set the amount of time you want the monitor or hard drive/s to remain on until the shut down or go into hibernation. Hope this helps.
Mar 25, 2008 | Computers & Internet
Computer not recognizing moniter
Resolution set too high for display.
Attach TUBE monitor, Start Windows, change resolution to 1024x768 (MAX) and then hit APPLY/OK.
Also check refresh rate, it is listed in hertz (hz) in advanced settings. Should be 70-72khz not faster than either.
Shut down PC, Connect LCD, you should have a decent picture.
Dec 13, 2007 | Microtek C593 15" Flat Panel LCD Monitor
Monitor goes black
Sorry to have to tell you this, but this is common in LCD monitors. The reason that it is going black when it boots is for one of two reasons. You either have a bad power supply that powers your LCD or your LCD's backlight is blown. These can be repaired or you can purchase a new one. But if it goes black 9 times out of 10 is because the backlight is bad. These can be repaired!
Nov 26, 2007 | Acer AL1711 17" Flat Panel LCD Monitor
E-Machines eMachines Monitor E15T4 Logo
282 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
