Question about Lavazza Espresso Point Capsule Machine
Lavazza Espresso Point not working, lights but not functioning.
I got an Espresso Point machine from a friend who said it stopped working and was wondering if anyone has had a similar problem. When plugged in and switched on, only the red power light in the top left corner comes on steady. If I lower the water level float the "Don't Brew" light under it flashes. No other lights on the right work. The counter is only at 001542, I have one spent coffee cartridge with it and it doesn't make any difference it in the machine or not. Also, when I push the coffee cartridge through and it pops down into the drawer, is the counter supposed to go up another number? Mine doesn't. I have taken the machine apart a little as I have worked on some espresso machines myself like my Gaggia Classic. When turned on with the red power light on the tank does not get warm. Is there a failure on the pc board inside? Is there a reset procedure somehow?
Thanks in advance to anyone with any suggestions.
CoffeeLoverZ
  • 33 Answers
SOURCE: When I try to brew
You a have a blockage in the spouts. This is caused by a number of things:
  • You used the wrong grind coarseness in the pre-grind
  • you used the wrong cleaning table for the machine (this is the most common)
  • you have an insect in the spout
  • The plumbing system has a fault, where the switch that re-routes the water is stuck
Try the following:
  • Take a paper clip and bend it open
  • Then that the point of the bent open peice, and insert in each one of the spouts and check if there is a blockage
  • if you feel something or something comes out, see if the rinse works, try a few times
If that does not solve the problem then you may need to get a service tech to look at it
Posted on Oct 31, 2010
z34aga
  • 137 Answers
SOURCE: Gaggia Carezza Espresso Machine burned out
as i understand from your decriptition, you had temperatire rising in extreme point. termofuse should worked but it didnt, i advice you to change all 3 and some seals:
  1. Thermofuse
  2. Thermostat water L=107C
  3. Thermostat steam L=145C
  4. Gaggia gasket 6-pc. Kit (during changing them you can clean boiler too)
here is the link for diagram:
http://www.partsguru.com/user/Carezza%20diagram%20and%20parts%20list.pdf
here is the link for parts:
http://www.partsguru.com/GaggiaCarezzaespresso.html
Posted on Apr 04, 2009
SOURCE: cold espresso
it may be the the back fuses not working or the two thermostat are not working good, or the worst possibility can be the electronic card.
Posted on Apr 29, 2009
  • 10 Answers
SOURCE: Lavazza point espresso machine no steam
Sounds like a clogged steam pipe or a jammed two-way valve. First, I would try unfolding a small paper clip and then stick it up the spout of the steam pipe. if this does not free up the steaming arm then it is most likely a clogged two way valve. Should you need service you can call 781-393-2929. we are an authorized lavazza distributor and service center
Posted on Aug 25, 2009
EsWorld
  • 1618 Answers
SOURCE: Gaggia baby espresso machine-Steam button is stuck
The only thing that comes to mind is that the machine is in steam/hot water mode. Unless you replace the switch and turn off the steam light so that it sends the water to the correct location. Also you might want to remove the shower screen and make sure it is clean.
Posted on Nov 26, 2009
Testimonial: "Thank you very much for your quick response. I've ordered the steam switch. "
Lavazza 2100
You could avoid this problem by flashing water out without any capsule in. In anycase is a simple problem, you need to disasemble the machine and remove the head shower and wash it from dry coffee liquid which is blocked all the showers holes.
Jun 22, 2012 | Lavazza Espresso Point Capsule Machine
Need a canadian supplier for lavazza espresso point capsules
Lavazza Products may be ordered online in Canada from the following site:
http://www.espressocoffeeitaliano.com/ourproducts.php
Contact Information:
Espresso Coffee Italiano of Canada Ltd.
(authorized distributor of the Lavazza Espresso Point System)
201 Drumlin Circle, Unit #3, Concord, ON
L4K 3E7, Canad
Tel: 905-907-5049
Fax: 905-760-5606
Email: info@espressocoffeeitaliano.com
Dec 13, 2011 | Lavazza Espresso Point Capsule Machine
Lavazza coffee machine will not heat up the coffee
For Lavazza A Modo Mio only call 0800 599 9200 -they can help over the phone or if still no solution they will refer you to Lavazza UK who have the answers for AMM.
Feb 05, 2010 | Lavazza Espresso Point Capsule Machine
Lavazza expresso machine
Is the machine blowing fuses? Your electronic keypad, or circuit card may be damaged.
If you need service you can call 781-393-2929
we are an authorized lavazza distributor and repair center.
Jun 02, 2009 | Lavazza Espresso Point Capsule Machine
Heating element on an lavazza expresso machine
you can call this number they will help you with your problem
1-866-526-6204
Apr 15, 2009 | Lavazza Espresso Point Capsule Machine
Cold espresso
Mar 19, 2009 | Lavazza Espresso Point Capsule Machine
LAVAZZA ESPRESSO POINT CAPSULE MACHINE WON'T GO ON
There are two ten amp small bus fuses in the back of the machine directly next to the iec power cord. Should you need service you can call 781-393-2929. We are an authorized lavazza distributor and repair center.
Jun 19, 2008 | Lavazza Espresso Point Capsule Machine
Lavazza espresso point
Did you fill it with water? are any of the lights blinking?
Jan 02, 2008 | Lavazza Espresso Point Capsule Machine
Lavazza Espresso Point Capsule Machine Logo
392 people viewed this question
Top Lavazza Coffee Makers & Espresso Machines Experts
ray gallant
nikolay nikolov
Tom Chichester
Are you a Lavazza Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
