Question about Dell Inspiron 6000 Notebook
Power Problem My inspiron 6000 cannot come on, when i open it, i noticed that a small capacitor burnt by the chrging port side. the system refuse to charge. when pluged it switches the power adapter off. it goes off immidiately you plug to the computer. how do i make the system to charge again so that i can put it on again
  • Dell Master
  • 4,338 Answers
Some thing shorted out that capacitor, you will have to find the source . It could be you adapter or it could be that the power connector is loose and the pins shorted. Really sounds like a new system board.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Oct 11, 2008
Battery won?t charge and AC adaptor not recognized
I have a Dell Inspiron 6000 that just turned two years old.
After one year, my dell 6-cell battery started to falter, so Ipurchased a new 9-cell battery. This worked fine until a couple ofmonths ago when I noticed that my 65W adaptor was frayed. I bought anew 65W Dell Inspiron 6000 ac adapter andit worked well for about a week until I noticed that my battery wasn’tcharging at times. If I was patient, or unplugged the adapter andplugged it back in, the battery began charging and all was saved.
This lasted only a short time until my Dell Inspiron 6000 batterywouldn’t charge at all for long periods of time, and sometimes thecomputer wouldn’t turn on, even if plugged into the wall. I thought itmight still be the adaptor, so I borrowed a fully functioning 90W Delladapter from a family member to test the system. This worked better,but still not great.
When I removed the battery and started only fromAC power, the functionality was also intermittent. Usually, if thecomputer actually started, I received the start-up error “The Inspiron 6000 AC AdapterType could not be determined, etc. etc. etc.” After pressing F1, thecomputer booted, but if the battery wasn’t in, the computer didn’tusually last long before shutting off. Unsure if maybe the battery wasthe problem, I put the 6-cell Inspiron 6000 batteryback in, and it too wouldn’t charge, although (together with the 90Wadapter) my computer would at least start more consistently if pluggedin. The error remained however, and sometimes the system stopsrecognizing power and switches to my ever dwindling battery power untilthe adapter is recognized again.
The problem is with the jack on the motherboard inside our Inspiron 6000’s. This is the jack you plug your power plug into on the back of the laptop.
Somehow the jack gets worn and does not make correct contact withthe laptop so the Laptop does not see the power supply as a legit Dellbrand. So the powersupply will not charge the laptop battery and run the laptop at the same time.
DC power jack repair guide. Do-it-yourself instructions.
Modern laptops are all sold with built-in wireless laptop ac adapter.Some power notebooks used by corporate road warriors will have powerfulcellular adapters that connect the laptop to the Internet via the cellphone infrastructure
A bad connection between DC-IN power jack on the system board and the system board is a very common problem with dell pa 12,dell e1505 and Dell Inspiron 6000notebooks. If your laptop is out of warranty, then you can fix theproblem by resoldering DC-IN jack on the system board. If it’s stillunder warranty, it would be fixed at no charge to you. Problem symptoms:
  • Laptop randomly shuts down without any warning.
  • Power LED and battery charge LED start flickering when you wigglethe power cord or the AC adapter tip on the back or your laptop.
  • The battery will not get charged.
  • When you plug ac adapter for laptop, the laptop appears to be dead and there is no LED * activity at all (DC-IN jack on the system board is broken).
To fix the problem, you have to take your laptop apart, remove the system board to resoleder or replace the DC-IN jack. dell pa 12 and Dell Inspiron 6000 disassembly guides will help you to remove the system board. Take a closer look at the power jack on the system laptop board witha magnifying glass. In most cases you get the power problem because ofa bad connection between the DC jack and the system board, you’ll see acrack between the DC jack connector and the system board.
on Jan 22, 2010 | Computers & Internet
My Inspiron 6000 would stay on for only a few minutes. Even with the charger attached. I poked around the port where the charger plugs in with a small screwdriver trying to make sure the metal inside the...
Poking about when the power was connected was not advised....
I think you may have blown the main laptop mobo fuse. If you are confident, you can take the thing apart and fix the fuse (about an hours work), however, you could have also damaged the charging circuit
Jan 18, 2011 | Dell Inspiron 6000 Notebook
Motherboard power problem
Those must be the jumpers they were the ones responsible for the connectors on your motherboard . If that had spark chances are the motherboard might be affected.
Advised contact the technical support if the warranty is still up but that might void the warranty if they asked why did you open it . If its out of warranty asked tech support for the part number and asked them to connect you to spare parts dept.
Disclaimer of Endorsement: If the recomendation works for you just refer others to visit this site and let us know your feedback about this. Recomendations on this were purely based on authors experience and trainings.
Feb 04, 2010 | Dell Inspiron 6400 Notebook
New aftermarket Inspiron 6000 battery will not power the Laptop
I would say that the power management portion of the system board is probably faulty if it behaves the same with both the factory battery and the aftermarket.
Many systems have the charge controller and battery interface on a separate board but unfortunately on the Inspiron 6000 it's integrated.
FYI, Here's a copy of the service manual for that system:
Jan 21, 2010 | Dell Inspiron 6000 Notebook
How do I open my Dell Inspiron 6000 laptop to install more memory?
Hi: You have a small plastic access panel on the bottom side of your laptop that has one or two small phillips head screws holding it down. Power down your laptop, remove the battery, close the lid, and lay the laptop upsidedown on a towel. open the memory door covern and you can release the old memory by gently spreading the metal tabs on the side of the memory sticks outward.
Nov 18, 2009 | Office Equipment & Supplies
My Dell Inspiron 6000 works fine on AC, but will not charge
As a first step, Try reseating the battery on the laptop and see if the problem is resolved.
If not working, then try flashing the BIOS on the laptop.
You can find the latest BIOS for your system in the website.
1. GO to
2. Click on "Drivers & Downloads"
3. Either select your System model or enter your the service tag of the computer.
4. Under the "BIOS" section., you will find an option to download the BIOS.
5. Save it to your system., and just double click it, to install.
-> Make sure that the system is not turned off while Updating the BIOS...
Have a nice day
Oct 07, 2009 | Dell Inspiron 6000 Notebook
When the lap top logs off front light stays on
Do you still have the power cord plugged in? There are indicator light s for Battery operation, power on, hard drive activity. If you just logged off but the laptop is stillpowered on, then there will be a light indicating that. If you powered off the laptop but left it plugged into a wall outlet, then there is a chrging indicator that will stay lit.
Sep 11, 2009 | Dell Inspiron 6000 Notebook
Dell 6000 laptop screen blanks out - bought new screen
ManualsBack to Contents Page
Display Assembly and Display LatchDell Inspiron™ 6000 Service Manual
Display Assembly
Display Bezel
Display Panel
Display Latch
Display AssemblyRemoving the Display AssemblyCAUTION: Before you perform the following procedures, see the safety instructions in the Product Information Guide.NOTICE: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as the back panel) on the computer.NOTICE: To avoid damaging the system board, you must remove the main battery before you begin working inside the computer.
  1. Follow the instructions in "Preparing to Work Inside the Computer."
  2. Remove the hinge cover.
  3. Remove the keyboard.
  4. Open the display all the way (180 degrees) so that it lies flat against your work surface.
  5. Remove the four M2.5 x 5-mm screws (two on each side) that connect the display assembly to the computer.
  6. Loosen the screw that connects the grounding wire to the system board.
  7. Use the pull-tab to disconnect the display cable from the system board.
  8. If a wireless Mini PCI card is installed, disconnect the antenna cables from the card.
  9. Lift the display assembly from the computer.
Apr 06, 2009 | Dell Inspiron 6000 Notebook
We have an Inspirion 6000 with this problem and we've discovered if you pull the power cord out very slightly and lift it upwards, the charging icon appears in the system tray.
my friend has a latitude d600 that has the power port messed up in the back of the computer. i got him this thing, some people call it a docking station some people call it a port replicator, but you dock the computer to it and then you plug your power into the docking station and it charges it that way. you get extra usb ports and stuff like that and there is no repair involved. i dont know if you would want to try something like that maybe.
Jan 23, 2009 | Dell Inspiron 6000 Notebook
Dell Inspiron 6000 Notebook Logo
Alun Cox
