Question about Optoma EP719 XGA DLP PROJECTOR 2000L 2500:1 CONT DVI-D WITH HDCP Multimedia Projector
Optoma projector We are having problems with our projector. The screen (or light bulb) flickers. We have had it just a little over a year and first the colors got funky so we replaced the bulb. Now when we try to watch it(we use ours as a television), the screen flickers. Not quite sure what all to try. We have tried the resync button and that does not fix it. Any suggestions would be great!! i just replaced the bulb in my optoma ep719, thinking that that was the problem since i've used it for movies and gaming for aprox. 1700 hrs. .......and it does the same thing after about 10 min. or so the picture flickers a bit with a reddish hue and then the colors bleed together in a weird way almost cartoonish looking. I havnt took the whole thing apart yet but am capable, i am a tv repair tech. and work on lcd t.v.'s ....just looking for a jump on the problem so i can get it back up and running propper again......thanks
4 Suggested Answers
SOURCE: optoma projector
u need to open the 4 screws on the sides
then there is one screw in the center at the bottom
the u also need to unscrew the nut screws on the vga connector.once done
press the top of the panel near the keypad & the front cover will come off
similar is the procedure for the back cover.
when you try to lift the top cover make sure not be hasty, open slowly s there is a film connector for the keypad that is connected to the main board,take care not to damge it
once you have acess to the main board
loosen 2 screws on the mainboard & then press the outer side of the main board.there is a 100 pin connector that connects the main board to the dlp engine.this is the cause of the problem that you mentioned.this should fix your prob
Posted on Feb 09, 2009
  • 5 Answers
SOURCE: optoma ep719
There is a stuffed 10v 3300uf capacitor on the power board. You need to replace it.
Bellow you can check in the picture where the capacitor is located.
Notice that in this picture I have already took the bad capacitor out and replaced with two small cords to reach the bottom and test the new capacitor.
To reach this place is not fast, several layers of plastic and metal must be removed, but is not a hard task to take the capacitor out and replace it for another.
It works just great! Now it is back on track with awesome image.
Posted on Oct 03, 2009
SOURCE: my projector optoma ep719 has a blue screen went
removed hdmi cable from xbox360 put in a scart with the hd cables attached and the svideo als on attached £ 15 FROM MAPLAN . i used the scart in abox then put the red & white &yellow an then the svideo into my optoma moviemaker.success . its al has to do with the hdmi cable ( you then set your projector to svideo or composite) note the one from maplan has a switch at the scart end you may have to switch it over to get the picture on hope you get success paul
Posted on Dec 05, 2010
Just replaced my optoma hd65 lamp with an original optoma lamp and the picture color is great but there is flashing/flickering of the colors on the screen periodically, sometimes more often. I reset the...
Try putting the bulb into normal (rather than eco) setting.
Check the bulb is seated correctly.
If this does not help you may have to contact your bulb supplier to see if they can swap bulb for you.
Please dont forget to vote this answer was helpful
Many thanks
Feb 18, 2011 | Optoma HD65 DLP Projector
Optoma hd65 projector new bulb wont turn on...cant reset timer!
I think it's a lamp driver issue from what I've seen others have gone through. I also read that if you go through the sequence of unplugging, plug back in, wait 20 seconds and try to turn on, multiple times, it will finally kick on and work. I just got mine to turn back on by doing this and waiting through the fan cycling without the light turning on. After the 4th sequence the light flickered. After the 7th sequence it finally turned on and is working. Now I can watch the Super Bowl and will look into replacing soon.
Jan 31, 2010 | Optoma HD65 DLP Projector
Blotchy colors on optoma hd80
i had, have the same problem i also replaced the bulb then shortly after the power went out no standby light or anything. From what i've read so far it seems like a power supply issue so i ordered two power supplys from optoma 1 for lamp 1 for the unit waiting on delivery from CA they were $ 99 each if this work i'll be one happy camper. Three years no problems it's a great machine with incredible picture using 106" screen
Dec 22, 2009 | Optoma HD80 Projector
I have an Optoma EP716 projector. It has run for
either the lamp has/is going to expire, or the ballast is bad. if the lamp has bulges or black spots on the inside, replace the lamp and clean out your projector with canned air. too much dust keeps in the heat and makes a 2000 hour lamp go in 1100 hours.
Oct 22, 2009 | Optoma EP716 Multimedia Projector
New Bulb (30 hrs). Screen flickers after 10 minutes, color changes with green tint, then bulb shuts off.
Hi, I had a similar problem - the screen flicked through blue, green and red sometimes with a slight ticking noise. The problem seems to be that the colour-wheel is getting stuck - the first time this happened I sent it back to optoma who gave it a clean - it has happened again since thouegh and I just took the case off (you'll be able to see the colour wheel under a black plastic flap - remove the flap) I then used a cotton bud (q-tip) and turned the colour wheel whilst lightly pressing the cotton bud against the wheel - I also gave everything a blast with a can of air. My HD72i is ceiling mounted - optoma suggested putting the hoover pipe across the vents every now and then to keep the dust down. Essentially it's dust that is stopping the movement of the colour wheel.
Hope this helps.
Jonathan
Oct 21, 2009 | Optoma HD72 Multimedia Projector
Optoma projector
Feb 09, 2009 | Optoma EP716 Multimedia Projector
Optoma HD65 bulb only 108 hrs old having difficulty starting up
Use the warranty! since you anly had it for 8 weeks, and the waaranty last for one year, go back with it and get it repaired or get a new bulb. A buld last at least 2500 hours, in eco mode it last for over 3000 hours.
Good luck to you
Dec 17, 2008 | Optoma H30 Multimedia Projector
Blending Colors/Flickering Display
Hi SmartMex
This in not a lamp problem , but rather a Mainboard issue.
You will have to take it to a Service Centre to either be repaired or replaced.
Apr 17, 2008 | Optoma EzPro 739 Multimedia Projector
Optoma projector
DONT THROW AWAY YOUR BULB JUST YET!!! IT MAY BE THE COLOR WHEEL!
I have an optoma hd70 and was having the same problems. I also tried the "dust blob" tutorial, but unfortunately it did not work for me (and I ended up getting dust on the lens I couldn't get off myself). I started searching on the net for more answers and found some information regarding the angling of the projector. Apparently, if you tilt the projector with the back raised too high, the ventilation system does not work properly and this increased amount of heat damages the color wheel inside (this causes the wheel not to spin correctly and display a flickering effect...and that's also why it works for a few minutes on start-up but then gets too hot and the wheel skips and creates the flicker).
Luckily, I have a very extended warranty and was fortunate enough to send it in and have the dust removed & color wheel repaired/replaced. Now, I've lowered the stand for the projector to not have it tilting at such a high angle and haven't had any problems yet...but it does take awhile to get effected (had mine for about 1 & 1/2 years)
I know I should have probably just sent it for repairs in the first place...but who wants to miss out on having a projector for two weeks when a tutorial says I could've fixed it in like 20 miutes?!?! Oh well. Hope this helps someone...good luck;)
Apr 05, 2007 | Optoma H30 Multimedia Projector
42 people viewed this question
Top Optoma Office Equipment & Supplies Experts
color wheel light...
Electro Med Services...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
