Question about Cooktops
Thermador Cook 'n' Vent Stove with stuck vent (model # SGCS304RS)
The vent to my cook 'n' vent stove is stuck. I came home yesterday after my housekeeper cleaned and I'm assuming it got stuck after she cleaned it. Assuming some of the cleaners dripped down. What should I do?
  • joeyndoug Oct 22, 2008
    i have the same issue....is there a resent button?
I just had a similar problem. The switch knob, and backer for the blower got jambed in the housing. After pulling it all apart I called the parts center at Thermador and ordered a new switch. If you can hear the motor the raises the unit run, then that could be your problem.
Posted on Nov 08, 2008
Why is stove top displaying symbols not recognizing pots? Had stove 6 weeks, pots are correct and been used on this stove. Displaying on all 3 cooking areas.Can I correct it or is it faulty?
lets review this
please advise readers
maker of cook top so they can find the user manual
model or how old helps also
its not a gas cook top
you have the right type of designed pots for that cook top
but you get no heat radiating to the pot base
when pot is in contact with the heat area
Aug 17, 2016 | Cooktops
Venting codes for a pro style Dacor stove top
what need for the code as long as you it safe for your family.. and accesible for yu its okay..
Mar 03, 2008 | Cooktops
How to remove the stove top on frigidaire stove model FFGS3025PS
IF you open the door to the stove, you will see screws under the lip of the cook top, take those out, check the back of the stove for screws and then lift the cook to. On some models you may have to remove the sides of the stove too.
Mar 13, 2016 | Frigidaire Stove/Oven/Range Cooktop -...
Burner shuts itself off after 10 0r s minutes of working normally
this unit has a gas coil controling the valve . and wen it gets hot it is failing and cannot keep the gas on . replace the valve coil // mm
Jul 12, 2010 | Thermador PC366BS Stainless Steel Gas...
The Grill side on my electric cooktop doesnt seem heat up enough
I had the same problem with the 45" Jenn Air downdraft cook top. The installation of the ductwork from the stove to the outside of the house was not properly installed. The stove is appr 18' from an outside wall and the flow of air was hampered by
too great a bend in the ductwork at the point below the stove on the underside of the house and the pipe going to the outside wall. I believe that was corrected with more curve in the vent work, making for a smoother flow of air. Make sense?
Jan 07, 2010 | Jenn-Air JED8230 Electric Cooktop
What is a bottom vented cooktop
There is a fan that sucks DOWN like a Jenn-Air cook top. There is no hood usually over such a stove. Usually the suction for the vent is between the burners. I think the air can be exhausted through a filter back into the room or to the out of doors.
The salesman didnt explain this to you???
I hpe this answers your question
Oct 05, 2009 | Jenn-Air Cooktops
Broke glass on electric genn-air
Please do not use the stove if the element is viable because of broken glass, this could become a danger to yourself.
Look at the cost of a new stove, you should be able to get one for
around 400.00. One of my customers had a glass top with 4 burners,
they had the same thing happen, the cost to replace the top was
1,200.00. So I would assume that you can get a new stove with 4
burners less then it would cost to replace the part on a stove you don't like. Maybe there is a LOWES around you to look at stoves,
they seem to be everywhere,like death and taxes.
As for putting a 4 burner top on a stove that has 2 with grill, I don't think it can be done without the extra cost of adding the parts to run the other 2 burners, so like I said in the long run,it just might be cheaper to but a new stove. It should not be a big deal to remove the exhaust from the grill part of the stove.
I looked at the model# you put down,and it does not have a grill,
from what I see, there are 4 burners and a downdraft vent in between the 4 burners, there are 6 models with this part # and none have a grill,only the downdraft vent.
If the model# is right, the cost would be around 300.00 for the glass, and then the cost of having it replaced. So I would say over
400.00, In which case for the same amount you could have a new one, but you must weigh the difference for yourself and see what you think is the best way to go.
If you have any more questions,please post back and everyone is more than willing to help you. I hope I have helped a little.
Mar 24, 2009 | Jenn-Air JED8430 Electric Cooktop
Thermador Electric Cook Top Circa 1957-58 Model #
SU4-D is your model number. This is a very old cook top. Older units have a catalog number and not a model number. SU4-D stands for surface unit 4 burners.
Jan 28, 2009 | Cooktops
Gas cooktop vent code
planning to install a 30" stovetop natural gas.need to know if i need a vent to the outside, it has 4 burners
Nov 07, 2007 | Cooktops
Cooktops Logo
417 people viewed this question
Top Cooktops Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
