Question about Asko Dryers
Runs but does not heat up and does not dry. The service man showed me the reset button. It was tripped for him but does not appear tripped now. We have had this problem intermittently for a year. Every time we think we should call, it starts to dry. Only when it stopped drying consistently, did we call and he reset the cleaned and machine.
  • 5 more comments
  • BobMurf Oct 11, 2008
    I just checked the dryer again. Now it appears to be heating. So it is an intermittent problem, the worst kind to reproduce.
    So it is getting power, the circuit breaker could not have been tripped, the heater wire must be connected but occasionally it runs but does not heat.
    Asko does have a resettable reset button which I pressed but did not feel any give or click which the service man said I would if that was the problem.
    Does a long time to reset mean a week?
    I have cleaned out the hose and the service people also checked the interior of the machine.
    What would cause the machine to work sometimes and not others?
    When it does not dry, it runs all night long.
    Thanks for trying but I do not think we are solved yet. Is there a way I can check the other thermal switch?
    Is there something I can do to test the solution?
    Regards,
    Bob
    Should I tell this advice to the service team? I have soldered but am not comfortable trying it on the Asko dryer. I would not even know where to start. Finally, what is a dry solder?
    Actually, are you saying that the dryer will appear to be heating up and then the thermal cutoff will kick in and the dryer will just run all night long because it will sense that the clothes are still wet?
    Thanks for your advice but I am still looking for a solution that I can use or give to the service team.
  • BobMurf Oct 12, 2008
    The Dryer is an Asko 7005, Type TD 70A, Capacity 5.0KG and Serial No. 9621-044693. So it would make sense that it was made in 1996 when we moved and has been used almost daily since. Do you think we have gotten our money out of it and should replace it? When it works, it does a great job.
    Thanks for your input. Let me know if you need more information.
    Regards,
    Bob
    FYI I started the dryer and tried to dry a towel which I had run under a faucet to get damp. The dryer seemed to be heating up. When I returned in 10 minutes, the dryer was running but luke warm air was coming out and the drum was also luke warm. Does this help?
    I will try again tonight once the dryer cools down and see if I can get heat.
    Regards,
    Bob
    I let it sit for 5 hours after it started to heat then went luke warm. It is heating now but I expect it to be luke warm when I go back in 15 minutes.
    Is this something I can fix or do I need to bring in a technician?
    I am in Boston, MA.
    Regards,
    Bob
  • BobMurf Oct 14, 2008
    I was asked for more information and replied that the Dryer is an ASKO 7005, Type TD 70 A, Capacity 5.0KG and Ser no 9621-044693.
    I have received no answer since and the technician is to arrive Wed. at 2 PM.
    Thank you for any additional guidance.
    Regards, Bob
    Master:
  • 538 Answers
Sounds like the tech will solve it forye..
Posted on Oct 14, 2008
    Top Expert:
  • Asko Master
  • 77,499 Answers
There is a temperture probe in the outgoing air stream that controls the dryer temp by sending a signal to the thermostat control to turn the heating element on and off or the gas, depending on which you have, this is the most common cause of your type of problem. Here is how you change it, the instructions are generic but work for almost any dryer.
GENERAL INSTRUCTION FOR REPLACING A DRYER THERMSTAT
Disconnect the power source to your dryer before you conduct this or any other repair. Either unplug the unit from the wall outlet, remove the appropriate fuse from the fuse box, or flip the appropriate breaker in the circuit breaker panel. Your dryer uses multiple thermostats to regulate its internal temperature. The cycle selected determines which thermostat is used. The cycling thermostat can be found somewhere in the path of air that is leaving the drum. So, it could be found on the blower wheel housing or inside the venting/exhaust system. Dryer thermostats are usually oval shaped and about an inch and a half in length. Also, there should be two wires leading to each thermostat. Label these wires before you remove them so that you are able to correctly reconnect them later.
The wires to the thermostat are connected using metal slip on connectors. Remove the wires by pulling on the connectors, and not the wires themselves. It may be a good idea to use a pair of needle nosed pliers to help you.
The thermostat itself is attached to the dryer with two screws. Remove both screws and discard faulty cycling thermostat. Install new thermostat, securing it in place with two screws. Reconnect the two wires, reassemble your clothes dryer, and restore power to the unit. Run your dryer through a cycle to make sure it is working properly
Posted on Oct 11, 2008
  • yadayada
    yadayada Oct 14, 2008
    I will bet the tech wants to change the thermostat.
    Guru:
  • 558 Answers
It is the heating element circuit which need to be checked, since the problem is intermittent and happen any time, it concludes that its coil after heats breakup the circuit.
Reset Button is not causing this problem, as it is heating and then stops suddenly, or heating low.
Let me know more about the dryer so I can investigate further.
  • Puneet Jain
    Puneet Jain Oct 15, 2008
    You need to check and if required go to replace for the dryer belt, Thermal cut out, Heating element and sealing.  Let me know if these are required to change and then vote the solution accordingly.
    Sergeant:
  • 399 Answers
If this dryer heats sometimes and does not heat sometimes.that means every thing is proper in the dryer.the simple problem is when the inter nal circuit gets heated the unit stops heating.so you have to just open your device and do a dry solder to the dryers circuit and the soldering joints will become firm.and then check it will work.leave it off for some time so to get the board dry after dry solder then on the dryer.it will work.
thanks.
  • masterexpert Oct 12, 2008
    yes exactly the circuit gets cut off after it gets heated.
    and dry solder is a soldering machine which blows hot air and from that hot air the soldering on the machine gets firm if some where it is loose or becomes loose after getting heated.
    and the repair person will understand what is dry solder.try this.
    feel free for any further queries.
    thanks,
  • 958 Answers
Could be a problem with the thermal cut off . it is two pieces when you buy them, one is the non resettable type, ( the smaller one ) and the other one is automatically resets itself ( the bigger one ). this could be the problem, it takes a long time to reset.
normally, you replace both of the them.
tnx 4 using fixya,
drcool
  • francis rivero Oct 11, 2008
    you can check it by using a multi meter to check for continuity. check all sensors for continuity. but if it is intermittent, then do the test when it is not heating, other wise you will not find the faulty component.
    open the back cabinet and check all sensors that you will find. you will find about 4 sensors there.
    tnx again, drcool
  • francis rivero Oct 12, 2008
    that would be the best time to test those thermal cutoffs. when it is no longer heating up.
    tnx for the update Bob,
    drcool
    Genius:
  • 3,422 Answers
HI,
If your dryer doesn't heat, check these:
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
How to reset a service interval indicator on a 2003 mini one
Resetting Oil Service Light on your 2002 - 2006 Cooper and Cooper S Hatchbacks, and 2005 - 2008 Cooper and Cooper S Convertibles:
1) Press and hold the trip button
2) Insert key and turn to position 1
3) Watch for RESET to appear
4) Release the button, then press & hold it again
5) Wait for the RESET to flash
6) Release the button, and then press & release (once only)
7) Service interval should then be reset to next interval
If that didn't work, try this:
1. Push the Trip Button
2. Turn ignition key to position 1 and 51A will appear to left of mileage
3. Release trip button
4. Wait 3 seconds
5. Push trip button
6. Wait (5-8 seconds) for RST to appear in left corner
7. Release trip button
8. Push trip button
9. 15000 will appear as new service interval
10. Release trip button
Or this:
1. Press and hold the trip odometer button.
2. Insert car key and turn it to the fi rst position (not the second position).
3. You will see 51A come up in the trip odometer area.
4. Release, then press and hold again.
5. Watch for the word "RST" to appear on the Odometer indicator.
6. Release, then press and hold again.
7. Wait for the "RST" message to fl ash.
8. Release, and then press & release (once only).
Jul 01, 2014 | 2004 Mini One
My new omega washing mashine shows an E2 error code 5 miniutes into the wash how do I fix this?
Manufactured by omega washing mashine have an electronic controlpanel that must be unlocked in order to set or make changes to your washingcycle.
E2 indicates a water leak. When a leak occurs, it trips thefloat device by dumping water into the dishwasher's base. The incoming watervalve will be switched off, and the drain pump will turn on until the sump isempty
However, if an error light is blinking on your dishwasher'scontrol panel, the panel must be reset before you can gain access. Blinkinglights on your washer control panel may signal a mechanical problem that needsto be repaired. If the lights continue to blink after you've reset the controlpanel, contact Sears to service omega washing mashine or considertroubleshooting the appliance yourself carefully.Instructions
1 Press and hold the "Heated Dry" button onyour omega washing mashine for four seconds to unlock the dishwasher controlpanel.
2 Press the "Heated Dry," "Normal Wash,""Heated Dry" and "Normal Wash" buttons one after theother, in fairly quick succession.
3 Wait for the washer to run a short diagnostic test.
4 Press the "Cancel/Drain" button at the endof the diagnostic test cycle. This should reset the control panel on your omegawashing mashine. Thankfor using fixya.
Jul 30, 2011 | Washing Machines
2005 toyota camry service light is on how do i
Turn the key on,but don't start it,and make sure the odometer is showing the actual mileage,not trip A or B.Turn the key back to the off position,then press and hold the trip/reset button.Continue to hold it down and turn the key to the on position.Continue holding the trip/reset button while the mileage flashes rows of zeros until the actual mileage appears again.Release the button,because you are finishedthumb_up.gif .
Jul 12, 2010 | 2006 Toyota Camry
Hi How do i reset my service light on my 2004
press and hold trip meter reset button with ignition off. switch on ignition while holding button. release button when ignition is on and then turn clock setting button to the right and hold for a few seconds until service light resets.
May 14, 2010 | 2004 Volkswagen Passat
I need to reset the b service on my clk550. How
1.- Insert key into ignition, switch to position "1"
2.- Press the menu buttons repeatly until the mileage is displayed within the multifunction display.
3.- Press the cluster illumination button (trip reset button) 3 times in short succession. The battery voltage will be displayed and an audible signal will sound.
4.- Turn key in ignition to position "2"
5.- Press the Up and Down Arrow buttons until service menu appears.
6.- Press cluster illumination button (trip reset button) once. The oil type menu is displayed.
7.- Use the + and - buttons to select the oil used for service.
8.- Press the Up and Down buttons to confirm. The display will show : "Reset Oil Confirmation. Push Illumination button for 3 seconds".
9.- Press and hold the cluster illimination button for 3 seconds. The message "Service confirmed" is displayed.
Mar 01, 2010 | 2007 Mercedes-Benz CLK550 Convertible
My Fisher Paykel dryer runs normally but does not have heat to dry the clothes
the coments above are typical but not for this brand of dryer. I am not a Service technician but Very Handy. You can access the service summary (or Diagnostic Mode) by:
1)Turn on power to unit
2)Press & hold down the Auto Dry button, while you momentarily press the Power button.
3)Press the Auto Dry UP button 3 times to read the "Last Fault Option". Different combinations of LEDs has a specific value(refer to the WIRING DIAGRAM located under the control panel)
***The entire dryer can be disassembled with only 6 Philips head screws. In my situation, I had the same issue listed above (No Heat). Start by making sure your ductwork exhaust has no blockage or kinks. Take a Shopvac and vacume every bit of lint up inside and out of the Dryer.
Turns out that my problem was nothing but a Manual Reset button located by the Heater Coil Box (Located lower front and right)
***This is an overload arrestor that tripped due to a build up of Lint!
The button clicks when it has been reset, then it works fine. Once again, make sure your Dryer is spotless before you close it up, (unless this is a part of your routine maintenance, haha).
Nov 22, 2009 | Fisher and Paykel DEGX1 Electric Dryer
How do i reset my kilometer gauge after changing oil or does it reset to 0 automaticly
Resetting Oil Service Light on your 2002 - 2006 MINI Cooper and Cooper S, and 2007 - 2008 MINI Convertibles:
4. Wait 3 seconds
5. Push trip button
8. Push trip button
Or this:
5. Watch for the word “RST” to appear on the Odometer indicator.
7. Wait for the “RST” message to fl ash.
Apr 12, 2009 | 2003 Mini Cooper
Mini dash
4. Wait 3 seconds
5. Push trip button
8. Push trip button
Or this:
backbutton0001.gif Article Date: Jan 02, 2007
Car Accociations: NEW_MINI
Hits: 16731
Jan 13, 2009 | 2002 Mini Cooper
Not heating
The reset button needs to be replaced.  Once it has tripped, it loses it's setting and will trip at a much lower temperature.  This is a standard procedure that LG is telling all their techs to do.
Mar 24, 2008 | LG DLE2532W Electric Dryer
No heat
mcwilliams if you pull the over off the front of the dryer at the bottom you can see the gas burner assy. Put the dryer on time dry and start the dryer, you should see a glow from the ignitor, then hear a click, then the heat come on. In the auto dry mode, the timer advances along with the dryness level. No heat, No timer advancing. If you don't see a glow, there should be a thermosat on the heater can, see if it is tripped. If so if it is resetable, reset then try again. You may have a bad ignitor.
Feb 03, 2008 | Estate TGDX640JQ Gas Dryer
Dryers Logo
130 people viewed this question
Top Asko Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Asko Dryer Expert? Answer questions, earn points and help others
