Question about Samsung CLX 3160fn All-In-One Printer
Samsung CLX3160FN: scanner stays locked
Just bought this machine. Cannot get the scanner unlocked. Whatever we do, the scanner stays locked!
  • djuka069 Oct 17, 2008
    And when i return it in unlocked position it do not work again...
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 188 Answers
Hi Stijntje,
The scanner lock is actually a physical locking mechinism. It is not a control panel option.
the scanner is locked in a safe position before they ship the unit to prevent damage to the scanner.
I believe that this sliding latch can be located ( while looking straight at the unit ) on the under side of the scanner, above the area where the paper comes out, more to the left hand side.
locate the latch and slide it from the locked position to the unlock position.
Press stop/clear button to clear the error and try again.
Good luck,
Posted on Oct 11, 2008
Samsung sl-m2875fw says scanner locked
Try unlocking the scanner!
On the underside of the scanner assembly is a LOCK, it has two positions LOCK and UNLOCK.
May 29, 2014 | Samsung Office Equipment & Supplies
The glass on my samsung clx3160fn has fogged up on the inside how do I clean it
I don,t really know to well this model but with some patience and screw drivers start by take apart the top of the printer scanner.If you are lucky to do it you can access the bottom of the glass.
Dec 06, 2010 | Samsung CLX 3160fn All-In-One Printer
My smasung clx3160fn scanner locked
There is a green slider located where the paper exits the machine. It is mounted on the bottom of the scanner. Pull the slider towards the front of the machine to unlock the scanner.
Nov 23, 2010 | Samsung CLX 3160fn All-In-One Printer
Scanner locked scx4521f
Turn the machine off. Look for a locking mechanism right above the area that copies exit out. There is usually a plastic knob that can be set to "lock' or "unlock". Rotate the knob to select "unlock" and this will release the scanner. You will have to look below the top frame and above the paper exit area.
Nov 08, 2009 | Samsung SCX-5115 Fax Machines
Samsung scx 5114
Are you sure it's not "unlock scanner", or similar? There is often a scanner lock located under the document feeder cover, usually on the left side of the contact glass, that you can engage for moving the machine. Check to see if it is locked.
Jun 08, 2009 | Samsung SCX-5115 Fax Machines
Scanner locked on samsung 3160fn- how do I unlock it?
I think you have to call the service. They will change the hole Scanner. Because you can't unlock the scanner by any buttons or mechanical trick!
Mar 23, 2009 | Samsung CLX-3160 All-In-One Laser Printer
Samsung "scanner locked"
I went through the same thing! It drove me nuts, and I even calls CS, which is great by the way. The sweet girl on the other line couldn't figure it out, but I finally Googled it.
In the opening where the printed pages come out, if you put your hand in there, on the top left is a lever.
This is the scanner lock. Once you flip the lever and hit the stop/clear button, it should be all better. At least that is what worked for me!
Nov 06, 2008 | Samsung CLX 3160fn All-In-One Printer
Samsung clx-3160fn color laser
the lock is on the underside of the scanner deck, you can see it through the glass.  Reach underneath and slide to unlock.
Dec 28, 2007 | Samsung Office Equipment & Supplies
Samsung CLX-2160N Sanner Locked
Same problem thanks for ignoring guys!
Dec 11, 2007 | Samsung CLX-2160N All-In-One Printer
Samsung CLX-3160FN "scanner locked"
Every Samsung multifunctional device has a scanner lock underneath the glass. This is to prevent scanner damage during shipment. Th user's manual in the CD and the unpacking sheet clearly illustrate where this lock is. If you open the top lid and look to the lower left corner of the glass, you will see a small lock-open/lock-closed symbol. Underneath that symbol you will find the lock. I'm including a small visual reference of a similar model. Just remember to turn off and on the unit after the lock is removed.
Sep 28, 2007 | Samsung CLX 3160fn All-In-One Printer
Samsung CLX 3160fn All-In-One Printer Logo
410 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
