Question about Hitachi TravelStar DK23EA Series DK23EA-30 (08K1292) 30 GB Hard Drive
Windows xp will not start due to "software problem"
I have an EI System laptop which recently has occasionaly given a message to say an error had occured and windows was shut down to protect the system. I used the system recovery disk to try and sort it as the system had also become very slow. The message popped up in the middle of the recovery program and now windows will not start up at all.
  • 538 Answers
Then start it from the recovery disk, and work through the re install from there..
Posted on Oct 13, 2008
My computer went to a blue screen and says fatal system error the initial session process terminated unexpectantly with a status of 0x00000000 (0x0000034 0x0010037c). The system shut down.
Dear Sir,
Please have the problem solved by having the system
repaired. This is actually being caused due to a corrupted
or missing system file. Please have the instructions to
having it repaired
Repairing Windows XP using CD installation
The CD installation for windows XP allow you to repair windows whenever there is file missing or corruption or improper function of Windows. This tips can be useful before you opt for a complete format to your computer.
Your first step is to boot the computer using the cd installation.
Below message will display:
Press Enter to setup Windows and accept the license agreement. Then select the XP installation you want to repair and then press R. 1wq9asrj-2-s-.png
Windows xp will copy necessary before reboot. You will be asked to press any key to boot to the CD. nzlmbj8t-2-s-.png
Do not press any key. Windows will boot to installation screen automatically and start installation.
After installation, enter the CD key (windows registration key) to finish repair.
You can now remove the cd from the cd drive and reboot the computer for appraisal
Jul 14, 2011 | Dell Inspiron 1525 Notebook
Error message at start up. Running windows xp. HP Pavilion a700N PC desktop. The message is: This application has failed to start because hpzjrd01.dllwas not found. re-installing the applicationmay fix...
To fix hpzjrd01.dll errors occurring due to corrupt or incomplete installation of HP printer software, uninstall your printer driver and reinstall it again.
To ensure the HP printer software is completely uninstalled from your system, we recommend you either use the built-in Add or Remove Programs utility or use the help of a third-party uninstaller, such as Perfect Uninstaller.
for more information and help click here hope this helps you.
Dec 18, 2010 | HP Pavilion A700N (PJ516AA) PC Desktop
When my laptop is turned on, it shows, We apologize for the inconvenience, but windows did not start successfully. A recent hardware or software change might have caused this. If your computer stopped...
You have corrupt or deleted windows files or possibly a hardware error. The first thing is to try a repair using a Windows XP CD that came with your system.
XP REPAIR INSTALL 1. Boot the computer using the XP CD. You may need to change the boot order in the system BIOS. Check your system documentation for steps to access the BIOS and change the boot order. 2. When you see the "Welcome To Setup" screen, you will see the options below. This portion of the Setup program prepares Microsoft Windows XP to run on your computer: To setup Windows XP now, press ENTER.
  • To repair a Windows XP installation using Recovery Console, press R.
  • To quit Setup without installing Windows XP, press F3.
3. Press Enter to start the Windows Setup: do not choose "To repair a Windows XP installation using the Recovery Console, press R", (you do not want to load Recovery Console). I repeat, do not choose "To repair a Windows XP installation using the Recovery Console, press R". 4. Accept the License Agreement and Windows will search for existing Windows installations. 5. Select the XP installation you want to repair from the list and press R to start the repair. 6. Setup will copy the necessary files to the hard drive and reboot. Do not press any key to boot from CD when the message appears. Setup will continue as if it were doing a clean install, but your applications and settings will remain intact. 7. You will need to apply Windows updates after this procedure.
Sep 21, 2010 | Dell Inspiron 1545 Notebook
The file <windows root>\system32\hal.dll.
Restart the PC. The hal.dll error could be a fluke.
Check for proper boot order in BIOS. You might see the hal.dll error if the boot order in BIOS is first looking at a hard drive other than your main hard drive.
Note: If you've recently changed your boot order or recently flashed your BIOS, this may be what's causing your problem.
Run Windows XP System Restore from a command prompt. If this doesn't work or you're receiving the hal.dll error message before you're able to complete this process, move on to the next step.
Repair or replace the boot.ini file. This will work if the cause of the problem is actually Windows XP's boot.ini file and not the hal.dll file, which is often times the case.
Note: If repairing the boot.ini does correct the hal.dll issue but the problem reappears after a reboot and you've recently installed Internet Explorer 8 in Windows XP, uninstall IE8. In this specific situation, IE8 could be the root cause of your hal.dll problem.
Write a new partition boot sector to the Windows XP system partition. If the partition boot sector has become corrupt or isn't properly configured, you may receive the hal.dll error.
Recover data from any bad sectors on your hard drive. If the physical part of your hard drive that stores any part of the hal.dll file has been damaged, you're likely to see errors like this.
Restore the hal.dll file from the Windows XP CD. If the hal.dll file is truly the cause of the problem, restoring it from the original Windows XP CD may do the trick.
Perform a repair installation of Windows XP. This type of installation should replace any missing or corrupt files. Continue troubleshooting if this does not resolve the issue.
Perform a clean installation of Windows XP. This type of installation will completely remove Windows XP from your PC and install it again from scratch.
Note: While this will almost certainly resolve any hal.dll errors, it is a time consuming process due to the fact that all of your data must be backed up and then later restored.
Feb 15, 2010 | Dell Latitude E5500 Laptop
My Dell Inspiron 1521 laptop recently shutdown and would not reboot due to a Windows Vista error. After recovering my files, I decided to install Windows XP. Obvisouly, the product code is not compatabile...
You might find it difficult to get hold of windows XP keys since Microsoft stopped selling it.
If you get on google and search for something called TinyXP (rev09). I think that this willl solve your problem.
May 18, 2009 | Dell Creative AWE64 Value Sound Card
My pc won't install I Spy Junior.
You have given no information on your PC hardware, what OS you use, or if it is 32 or 64 bit.
Here is the link to the Tech Support site:
Apr 25, 2009 | Scholastic I Spy Junior for Windows
I am trying restore windows vista on my ACER Aspire 5100 but a message keep coming up saying that Windows cannot open the required file D:SourcesInstall.wim. It also says the file does not exist and to...
This error is due to....
  • The default security provider in Windows XP, or
  • the System drive letter
  • To solve dis issue.. try one of the methods
    1)Reset Windows XP Default Security Provider
    1. Open Start menu, select Run, type regedit and then press Enter.
    2. In the Registry Editor window, locate and delete the following registry keys:
      HKEY_USERS\.DEFAULT\Software\Microsoft\Cryptograp hy\Providers
      HKEY_USERS\S-1-5-20\Software\Microsoft\Cryptograp hy\Providers
    3. Exit the Registry Editor and restart your PC
    2)Reset The System Drive Letter
    1. Start your computer in Safe Mode-turn on the PC, and press F8 during startup. Next, when the Windows Advanced Options menu is displayed, scroll down and select Safe Mode.
    2. Open Start menu, select Run, type regedit and then press Enter.
    3. In the Registry Editor window, locate the following registry keys:
    4. Edit this key to change the value of the system drive.
    5. Exit the Registry Editor and then restart your PC
    Mar 20, 2009 | Computers & Internet
    After installing windows xp my ei systems laptop has no sound
    after installing xp your laptop what?
    dont tell me already know ...
    you cant find wifi,no drivers for vga and no blutooth.
    you need to install the software for these devices separatly.
    all the drivers can be found via net.
    download free.
    once drivers downloaded and installed system will detect new devices and install them.
    Jan 30, 2009 | ASUS Eee PC 900 Notebook
    Laptop wont start
    Dear customer
    your system OS is please installed oprating system newly XP or VISTA.try this
    Jul 25, 2008 | HP Pavilion ze4145 Notebook
    Hitachi TravelStar DK23EA Series DK23EA-30 (08K1292) 30 GB Hard Drive Logo
    200 people viewed this question
    Top Hitachi Computers & Internet Experts
    Alun Cox
    Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
