Question about Gateway FPD1975W 19" LCD Monitor
Graphics are "Smeared"
My Gateway 19" FPD1975W monitor is not displaying graphics properly. First it started with the icons having blurry lines beneath them and the mouse appeared to have ghosts as it moved accross the screen. If I scrolled in a window with text all the text would run together. Then the lower half of the screen became nothing buy vertical stripes of various colors. nothing could be discrened on the lower 2/3 of the screen. Anyone know what would cause that and is there any way to repair it?
  • Gateway Master
  • 5,568 Answers
If possible, try your monitor with another PC; this sounds more like a video processor problem than a monitor unless you are using it in the VGA-analog mode, then, you could have a bad video cable. The smear can be caused by improper termination and that can come from a failed ground or shield.
Generally speaking, the kind of effect you describe can't happen with a digital interface; they cause the coarse pixelation one sometimes sees on TV sets too.
Posted on Oct 11, 2008
Screen image is stretched or smeared
I had that problem, after awhile of using mine, the words would appear to be streaking. I bought a new monitor.
Feb 19, 2014 | Gateway FPD1975W 19" LCD Monitor
Gateway FPD1975W Monitor Vertical lines in the right side of the screen
Open the unit back up and check the cable that goes from the control board to the LCD panel and make sure it is plugged in securely. If this cable is not connected all the way it can cause lines on the display. Also while you are inside the unit check the capacitors on the power supply board. The tops should be flat, if you have any with bulging tops then you need to replace all of the ones on the power supply board. This can also cause display issues if the power supply is not putting out the correct voltages because of bad capacitors.
Jul 17, 2012 | Gateway FPD1975W 19" LCD Monitor
When i plug in my Gateway FPD1975W TFT LCD Monitor, the screen stays black and the power button blinks. This goes on for hours without doing anything else. Suggestions?
If you have this connected to a computer and it happens,make sure the fault is not with the graphics card or port first. Test the monitor on another computer or laptop. Test and check the VGA cable.
If this is not the problem (ie the monitor will not work on another computer and another monitor will work on your computer), you are probebly having power capacitor problems and the monitor needs replacing.
This link will explain more
View sonic monitors were particularly known for this problem
Aug 16, 2011 | Gateway FPD1975W 19" LCD Monitor
Resolution Issues
PC-right click go to personalize (usually at bottom of menu)
XP/ME/98- tabs at the top, goto settings to change.
Apr 02, 2009 | Gateway FPD1975W 19" LCD Monitor
No signal then orange light on my Gateway FPD1975W 19Inch Monitor
If you have a add on display/graphic card in your CPU then shutdown the system, open the case and try to press the display card gently. Sometimes if the card get loose the display will not come.
If you don't have add on display then try to press the Memory gently after shutting down the PC and try the signal again.
If not resolve let me know whether any beep/sound is coming out of your CPU box?
Rate my answer please.
Jan 04, 2009 | Gateway FPD1975W 19" LCD Monitor
No signal on monitor
You probably have 2 monitor connections. you have a standard one, and one that is through a graphics card at the bottom of your tower. Check for that second connection and switch the plug.. that should solve it.
Jan 02, 2009 | Gateway FPD1975W 19" LCD Monitor
Monitor remains in sleep
try another monitor or hock it up to a TV. see if the problem follows. if not the monitor is gone. if the porblem follows the PC then it most likely is the video card.
Oct 20, 2008 | Gateway FPD1975W 19" LCD Monitor
Gateway FPD1975W TFT LCD Monitor Need to Resize Screen
Did you try changing your display resolution in your computer display properties ?
Right click anywhere on your screen backdrop, click on properties, go to settings then pick the resolution that fits your screen the best.
Aug 20, 2008 | Gateway FPD2275W LCD Monitor
19 inch tft lcd monitor blurry
go to control panel click on display icon and then go to setting tab and there you will find screen resolution settings
Apr 29, 2008 | Gateway FPD1975W 19" LCD Monitor
Did you try the card in your friends machine? That would be the next step. The card could be going bad.
Feb 29, 2008 | Gateway FPD1975W 19" LCD Monitor
Gateway FPD1975W 19" LCD Monitor Logo
289 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
