Question about Lexmark Office Equipment & Supplies
I have a Lexmark X4650 and have it connected wirelessly to my iMac running OS X 10.5.5. I would like to set the default to draft quality for all printing. I cannot see how to do this. Also i have failed in setting up a scan to the computer. It tells me it failed to find the options and so fails. it will scan to USB stick. Anyone know how to fix these two issues? Barry
    Problem Solver:
  • 8 Answers
Try this... 1. Select your settings on the PDE (e.g. select paper type and print quality) 2. On the Presets, just below the printer selection, choose "save as" and name your settings. Everytime you print, choose File, Print then select your custom presets.
Posted on Oct 13, 2008
My wi fi orange light is blinking on my lexmark x4650 printer
The blinking WiFi light on your printer indicates either your printer is trying to communicate with your wireless network or your printer is not connected at all. For a quick fix, try to disconnect your printer from the power outlet. Power cycle your router and reboot your computer. Then, power on your router first, then your printer and lastly your computer. Check the WiFi light on your printer. If it goes to a solid green, that means you are connected back in your network. If not, you may reset your printer's wireless network adapter to its default settings. From the printer operator panel, press the Setup button > Network Setup > Reset Network Adapter to Default. The WiFi light on your printer will momentarily turn off then back on solid orange. Then try to run the Lexmark Wireless Setup Utility on your computer to reconfigure your printer to connect to your wireless network.
I hope this helps.
Nov 20, 2011 | Lexmark X4650 All-In-One InkJet Printer
How to stop wi fi from flashing orange on my x4650 lexmark printer
I hope this helps.
Nov 20, 2011 | Lexmark X4650 InkJet Printer
Lexmark 3600-4600 stops at 34% when trying to print a test page. Color ink is low, but I only want black in any event.
If your color ink is already empty or not substantial for printing, then you must replace it with a new cartridge. The Lexmark printer will continue to print when there's substantial ink in the cartridges.
If you prefer to print in black and white as your default print setting, please follow the steps below: (make sure your black and color cartridges ink levels are good)
For Windows OS:
1. Go to Control Panel.
2. Open Printers and Faxes.
3. Right-click on Lexmark 3600-4600 Series print object and click on Properties.
4. In the Lexmark 3600-4600 Series Properties window, go to Advanced tab. Click on Printing Defaults.
5. In the Lexmark 3600-4600 Series Printing Preferences window, under Ink Use, select Print using black ink only. Click OK.
6. Click OK button in the Lexmark 3600-4600 Series Properties window to save the changes.
Your printer will print in black and white draft mode the next time you send a print job to the printer.
For Mac OS:
1. With the file (you wish to print) open, go to Print. A window will pop up.
2. Select the Lexmark printer.
3. Expand the arrow pointing down beside printer name if you're not able to see other options for printing. Look for Quality and Media.
4. Under Paper tab, select Print in Black and White.
5. Save this as your default print setting. Click Presets option and choose Save as. You can personalize the name for this default print setting (e.g. Black and White Draft or My Setting).
Select this Preset name every time you print your files/documents.
Aug 31, 2011 | Lexmark X4690 Wireless InkJet Printer
My printer is connected to another wireless network which is not the same as my laptop how do i connect it to the right one?
I`ll guess You`ll have to connect your PC to the printer with the use of a usb cable.
Then run the Lexmark software (Lexmark printer home) or similar (don`t know what you are using?)... Go to "settings"; and choose wireless setup utility. You`ll have to manually set the SSID (the wanted wireless network) and the WIFI password for this network. Hope this will help.
May 23, 2011 | Lexmark X4650 InkJet Printer
After the power went out and came back up the wireless printer is orange and i reinstalled all the drivers on all the laptops, but it wont communicate with the printer lexmark x4650
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Frequently, issues are caused simply by a break in the signal sent from PC to printer or vice versa. Unplugging and re-plugging the printer allows the small amount of on-board memory on the printer to be cleared, with the result that the PC recognizes the machine properly. Programs continuing to run in the background of the operating system (OS) can cause the signal to be lost. Rebooting the PC ends all programs that may be running and makes a 'clean' start, allowing the signal to be detected.
If connection is still not established, try to print the network settings page to determine if your printer is still registered in your wireless network. 1. Press Setup (pattlnk_632008_2048-x4650stup.jpg) on the printer operator panel. 2. Press the right or left arrow button until Network Setup is displayed, and then press(pattlnk_632008_2052-x4650ok.jpg). 3. Press pattlnk_632008_2052-x4650ok.jpg at Print Setup Page. 4. Press pattlnk_632008_2052-x4650ok.jpg when prompted to Load Paper. 5. Press pattlnk_632008_2052-x4650ok.jpg. The network settings page will now print.
Check the SSID and the IP address on the settings page. If info shows that your printer is no longer registered, you may need to reset the wireless network settings of the printer.
Follow steps 1 & 2 above, 3. Press the right or left arrow button until Reset Network Adapter Defaults is displayed, and then press pattlnk_632008_2052-x4650ok.jpg. 4. Press the right or left arrow button to display Yes, and then press pattlnk_632008_2052-x4650ok.jpg. 5. Observe the message"Clearing Wireless Settings". The WiFi light will momentarily turn off then lights up solid orange. You can now launch Wireless Configuration Utility or Wireless Setup Assistant (Macintosh) to reconfigure your printer to connect to your network.
Sources: How to Print the Network Settings Page on X4600 Series All-In-Ones (AIOs) & How to Restore the Network Settings on the X4650 AIO to the Original Factory Defaults.
May 11, 2011 | Lexmark X4650 InkJet Printer
Unable to print from imac even it had been installed successful and the green line showing on wi
Try to print the wireless network settings page on your Lexmark X4650 to determine if your printer is still registered in your wireless network. 1. Press Setup (pattlnk_632008_2048-x4650stup.jpg) on the printer operator panel. 2. Press the right or left arrow button until Network Setup is displayed, and then press(pattlnk_632008_2052-x4650ok.jpg). 3. Press pattlnk_632008_2052-x4650ok.jpg at Print Setup Page. 4. Press pattlnk_632008_2052-x4650ok.jpg when prompted to Load Paper. 5. Press pattlnk_632008_2052-x4650ok.jpg. The network settings page will now print.
Check the IP Address and the SSID (network name).
May 09, 2011 | Lexmark X4650 InkJet Printer
Unable to connect wireless to my laptop lexmark x4650
This could be a firewall issue. Make sure to allow full access to all Lexmark softwares and printer communication processes in the program rules/permissions for your firewall.
Place your printer where it receives excellent wireless signal quality and away from other electronic devices which can cause wireless interferences (e.g. cordless phones, microwave ovens, baby monitors, garage door openers, and other wireless electronics).
You can also refer to these articles in the Lexmark website for further troubleshooting: How to identify a Wireless Communication Problem and Resolution Tips & Communication Not Available
My lexmark x4650 printer is connected to the wifi, but the orange light is blinking. And nothing is able to print. When I look at the printers activity it shows the document that im trying to print but...
When you installed your printer, you had to install the software on your PC. So go to your PC's start menu, go to Programs, select Lexmark software, select Tools and then select Wifi Configuration Utility. It will open a window which will give you step by step instruction on re-configuring your wifi settings. When you are doing this, make sure your printer is connected to your PC via the USB cable.
Apr 07, 2011 | Lexmark X4650 InkJet Printer
How do i reset my wireless printer? i cannot reconnect to it seems the printer cannot connect to the wifi network
Here's an article found in the Lexmark website on How to Restore the Network Settings on the X4650 AIO to the Original Factory Defaults. Just click on this link: http://bit.ly/aePRSr. Follow the instructions carefully. Hope this helps.
Jun 21, 2010 | Lexmark X4650 InkJet Printer
Wireless printer gets ip address different from my routers ip add
Check on the wireless network the printer is connecting to. Make sure it is your router.
Feb 03, 2009 | Lexmark X4650 InkJet Printer
56 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
