Jenn-Air 24 in. JDB1100AWS Built-in Dishwasher
Problem for Jenn-Air 24 in. JDB1100AWS Built-in Dishwasher
Jenn-Air Dishwasher Handle Loose
By kinger77 on Oct 11, 2008
The left side of the stainless steal handle is very loose and I don't see any where I can tighten a screw. I took out the screws on the inside of the dishwasher door. It looked like I couldn't get at the screw from the inside. Any ideas?
Same Problem
Feb 09, 2009
-   Yep... Left side handle is loose...
-   Guest
Nov 24, 2008
-   Hey! I found the answer...check out these instructions:
http://www.jennair.com/assets/pdfs/cms/other/dishwasher.pdf
-   Guby
Nov 24, 2008
-   We also have the same problem - left side of the door and we've taken the screws out on the inside stainless steel interior thinking that would be the access point. It's not. So don't try it. We're calling Jenn Air in the morning. Please take a moment to comment if you are experiencing the same thing - Jenn Air hates publicity like this.
-   Guby
Nov 04, 2008
-   I usually dont respond to these, but, I have the exact same problem, on the left side. Ive tried everything, except taking the whole door apart!
-   nwelbourne
Nov 01, 2008
-   I have the exact same model with the same problem on the left side of the dishwasher handle. I'm wondering if this is a manufacturer's defect. Mine also became loose in October of 2008. There is nothing in the owners manual to indicate how to get to the handle and the inside panel will not allow access to the screws even after you loosen it from the front stainless panel. I will let my builder know of this issue so that he can avoid all Jenn-Air appliances in future homes. -   scrapper1965
Best Solution
posted on Nov 03, 2009
Very Helpful)
Pokeyman
Rank: Apprentice
Rating: 100%, 1 votes
This worked perfectly for me. Follow the link that shows you which two screws to take out. It is one screw on each side of the inside door frame. One on the left and one on the right (not the top one, but the second one down). Then pull the door handle upward about 2 inches and the whole washer face comes up. Jiggle it off and tighten the handle. Only tricky thing is that you need a star screwdriver.
The problem I had in the beginning was that I took off the middle screws on top (cause that's what it looks like in the picture), but it's actually the side screws. Don't take them all off - just the two you need.
- Pokey
Comments:
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Jenn-Air 24 in. JDB1100AWS
Questions and Unsolved Problems for Jenn-Air 24 in. JDB1100AWS
Do you recommend Jenn-Air 24 in. JDB1100AWS Built-in Dishwasher?
Answer
Answer
My Jenn Air dishwasher has water standing in the bottom after every use model #JDB1111AWS. I'm using... (More)
Answer
Does my dishwasher have a filter that needs cleaning? My dishes are coming out dirty with particles... (More)
Answer
My JDB-5 Jenn-air dishwasher has started making a loud noise shortly before the drying cycle
Answer
We have a Genn Air JDB-5 Dish washer, last night when we turned it on and closed the door, all of a... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Jenn-Air 24 in. JDB1100AWS...:
Top Dishwasher Experts
Rank: Guru Guru
Solutions: 1581
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Dishwasher Experts
Top Dishwasher Repair
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 470-7119
All the parts that you need for your Dishwasher...
appliancehelp.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
