Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Engine pulley belt seems too short
I have the engine pulley belt for mt Craftsman 917.275760 mower. It is too hard to stretch over the upper and lower engine pulley. If I unbolt the pulley to slide it on will this mess anything up/
thanks
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 5 Answers
Double... nay, tripple check that you bought the right belt. There are a zillion belt sizes and different brand may mean a different fit for the same numerical size. If you purchased a serpentine belt thats the same size as a regular belt, it might not fit your application... just because it is serpentine. Also, The department stores sell a specific set of brands of mower parts. Not every store will have every ajor brand part.
If you definately have the right belt, you might be able to find a mechanism for providing slack to our belt for installation, like a clutch pulley on a spring. By forcing the clutch pulley "in" you might get enough slack. Installation of snug belts is certainly an art. I find that prying the belt into the groove of the pulley while its turning makes it easier.
Posted on Oct 24, 2008
Hydraulic system
I would say,that the Motion Drive Belt,has stretched to the point,that it is slipping on the pulleys. Over time all belts stretch or break. There is no adjustment,that can be made,once stretched,its time for a new belt. Look in your Owner's Manual,to see,a picture and directions of how to remove and replace a motion drive belt. If there isn't a picture of the drive belt in your manual,then look under the left foot rest. There you will find a decal,showing the correct method to install the belt over the pulleys. This is going to be a long belt,it runs from the Transaxle to the motor's upper pulley assembly. You can,it will be hard to do,remove and replace the drive belt with the mower deck attached. First,try lowering the mower deck,to the lowest position. This will give some room,to get to the motion belt,you will have to remove the mower belt,to get to the motion belt. I find it is easier to just remove the mower deck entirely. Doing this,give you ample room to work on the motion belt. The mower belt,can be purchased from Sears Parts Direct. Give them the tractor's Model Number and the Belt Part #,if you have the number,they will look it up anyway,if not. I gave more information,than you asked for. I hope this will help you. Sincerely,Brad Locke DTD. 12/04/15
Jul 15, 2013 | Sears Craftsman 46 in Mulching Tractor...
JD STX38 mower stalls when deck is lowered
If the belt bounces then it has stretched or the belt tightener is not working. properly. Also check the shear pin in the drive pulley. If it has sheared the blades will try to turn but slip when any pressure is put on.
Jan 07, 2018 | Garden
2006 yaries removal of fan belt
- Loosen the alternator (generator) upper adjustable bracket bolt.
- Loosen the alternator lower bolt with 14 mm socket.
- Push the alternator toward the engine block to release the belt and take it out.
- Place the new belt on pulleys.
- Pull the alternator away from the engine block and make sure that the belt is aligned and seated properly on all the pulleys .
- Place a wooden hammer handle between the engine block and the alternator and pull the alternator away from the engine while
monitoring the tension of the belt.
- Do not over stretch the belt. Half inch of free play will be sufficient for the safer operation of the belt and bearings.
- Tighten the upper alternator bolt.
- Tighten the lower alternator bolt.
Mar 01, 2012 | 2007 Toyota Yaris
The mower has no power & the belt is squeeling., this is the upper drive belt. I had a craftsman mower that did this a few years ago & the front pulley was loose, however, this one seems to be...
If the Engine is running fine and you are still not getting power to the hydrostatic drive, you probably have a loose belt or a pulley that is starting to seize up on it's shaft, by the sounds of it I would guess the latter, a squealing belt is caused by the coefficient drag of the belt against the pulleys it operates on. Check all the pulleys for free movement and make sure the routing of the drive belt is correct. Check the wear of the belt itself if it is cracked or burnt in spots this will cause slippage also.Good Luck.
Apr 21, 2011 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
I have a craftsman garden tractor model # 917.273022. when moving the motion lever forward past the "mowing" speed the tractor slows down all most to a stop. moving the lever back it will start...
Depending on the usage of mower it is possible that belt is worn and likely it is stretched just enough to permit slippage. Usually belts will squeal and even have a burning smell. While the engine is often check to see the mechanical actions on the belt and feel for slackness.
Feb 24, 2011 | Craftsman Garden
Steps needed to change transaxle belt
lift the front of the tractor up at least 3 feet and lower the mow deck to give you clearance. push the clutch pedal and lock it down to release belt tension. remove the mower belt from the engine pulley only. remove the trans belt from the idlers about midway back then from the trans pulley & finally from the engine pulley. put the new belt around the engine shaft above the mower drive pulley but not on the drive pulley then around the trans pulley. now you can put it on the drive pulley and finally on the idlers. make sure you have it under all the various keepers or the belt will shred in like 10 minutes. release the clutch pedal & check the belt again to ensure it is in the correct place. replace the mower drive belt & ensure that didn't come off other pulleys in the process. lower the front of the tractor and test
Oct 14, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My craftsman lawn mower acts like its slipping going up small hills
check ur drive belt [ runs from the engine upper pulley under frame to the rear trans axle thru a series of pulleys and spring loaded adjusters] the belt has probably worn down or has streched to where it slips under a medium load
Mar 13, 2010 | Craftsman Garden
Re: Craftsman 50'' Garden Tractor, Mfr: AYR. Mower drive belt is in place, but will not drive mower...looks loose?
Make sure the routing of the belt is correct, pay attention to tension pulley. Make sure belt is also not stretched you might need new belt.
Oct 15, 2009 | Garden
Mower Belt Won't Engage
The fact is that belts don't stretch. They wear down on the sides, causing them to ride deeper in the pulleys and they APPEAR to be longer. Check belt "width" to see if it is less than one half inch. Most craftsman riders use half-inch (AKA: "A section") belts.
Sep 26, 2009 | Garden
How do you change Craftsman Lawn tractor model 917.272673 belt
it simple 1st lower mower deck 2nd take belt off of engine pulley then out behind the idler pulleys then the blade pulleys slide out & reinstall if i can further help you e-mail me wade at wadembly@aol.com
Jun 25, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
179 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
