Question about SanDisk 8GB microSDHC Memory Card with MobilMate Micro Media Card Reader
SanDisk 8GB SDHC card cannot be read by either computer or T-Mobile Dash phone.
I have the 8GB SDHC SanDisk card and the reader that comes with it, but when I plug it all in and try to open it on My Computer, it doesn't pick it up. It says "Please insert a disk into drive F:" no matter how I fit the card into the reader.
I also have the same problem with the T-Mobile Dash phone, it won't recognize it when it's inserted into the card slot on the phone.
  • 4 more comments
  • nicholasnut Nov 02, 2008
    I have a motorola Q and a sabdisk micro sdhc. my computer wont recognize the sandisk on either the reader or the phone. Help!
  • Anonymous Dec 26, 2008
    my computer doesn't recognise sandik8gb(m2) but all lower cards........so the driver must be the trouble ......but how to get one ??
  • cuttinreps Jan 28, 2009
    I have the same problem w/ my T-Mobile G1. I had a 2gb sdhc mem card that I used in my blackberry pearl before and inserted it into my G1 and it worked fine. But for some reason it won't always recognize the 8 gb sdhc card. I tried to format by directly putting the sandisk into my parents desktop and it wouldn't do anything. Couldn't even right click to get a format option.. I don't think I can, but is there a way to format the sd card while it's in my G1? You think they would put that option on the phone itself...
  • dhruva_pk Mar 19, 2009
    i have a lg viewty phone and my 2gb micro sd worked fine but when i try puting my 8gb hc card it doesnt read it and it also doesnt read in my pc i know that my pc cant read hc cards but is there any firmware or upgrade for this i have a packard bell computer
  • Anonymous Apr 07, 2009
    i need to put music put for some reason the pc does not recognize the devive...i tried to plug it more than 6 times...and the same error pops out again
  • Anonymous Mar 13, 2014
    I insert, green light comes on and nothing else happens
Solution :
Put the card in your phone, link the phone to your pc and format the card through your pc. You should see two additional drives, one for your phones memory and one for your card. I had the same problem with my phone but it is now sorted !
Paul
Posted on Oct 25, 2008
My fujitsu doesn't read SDHC 16GB
If there is a BIOS update, that may help.
Sep 06, 2014 | Fujitsu LifeBook E751
My Sandisk micro card works fine in my phone, but my computer nor my photo printer will recognize it when it is in the adapter that came with it. Is there something that has to be done with the adapter or...
Hello, it depends how old your equipment is as SD cards and SDHC are not necessarily compatible, so if your pc and printer were designed in pre-SDHC days, then you probably wont get any success trying to reading your card.
SD cards only support 2gb max, and in order to support larger capacity for the same style card, the mapping of SDHC cards is totally different, so SD-supported equipment can't 'understand' the new mapping circuitry.
There's some interesting reading in Wikipedia which might clarify things better than my explanation.
Of course, this might not be the solution, but it's worth trying out an SD card if you have one, but I've noticed that SDHC cards are being advertised as SD cards; the only clue that they're actually SDHC is in the capacity, ie, >2gb.
Regards,
nicam49
Jan 28, 2011 | SanDisk 8GB microSDHC Memory Card with...
So My 8gb SDHC card is completely unreadable. When it is in my phone it say there is no external memory, I've tired taking the battery out of my phone, putting the card in and turning it back on, still...
the card is really shorted or crashed can be said!! till my knowledge it can't be fixed! so go for a new card instead of trying that again and again which may even damage your phone or card reader later!
reply and rate
Jul 10, 2010 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
SanDisk ULTRA II 8GB won't read when installed in a laptop. Works fine in the Digital camcorder. Trying to import the footage on to a Fujitsu tablet laptop (12 months old). Reads the standard 2Gb memory...
No, it's a hardware issue. Your 8GB card is an SDHC card (the HC stands for High Capacity), but the card reader in your machine is clearly only compatible with the older type SD cards. SDHC devices will accept SD cards, but devices designed solely for SD cards cannot read or format SDHC cards.
There is no firmware update for this, your only fix is to buy an external reader compatible with SDHC cards for connection via a USB socket. Most new readers are fully SDHC compliant, but check the specs for shelling out your hard-earned...
May 14, 2010 | SanDisk ULTRA II 4GB Compact Flash Card...
When i insert my 8 GB micro SD card it says the same thing.
Your 8GB card is considered "high capacity". You will need an SDHC USB card reader to read it.
Jun 24, 2009 | SanDisk 8GB microSDHC Memory Card with...
Formatting troubles for a 8gb Sandisk Micro SDHC
Hi Tony,
Have your My Computer window open and re-insert the card into the reader. If it doesn't show immediately, then right click and choose refresh. It should show up then.
Rob
Feb 27, 2009 | SanDisk 8GB microSDHC Memory Card with...
My computer won't read my sandisk 8gb sdhc microSD card throught the sd reader port
yes, some of the older readers will not recognize SDHC larger than 2G. you can buy a USB SD card reader off Ebay from Hongkong for a buck with shipping.
Aug 14, 2008 | Computers & Internet
T-mobile Dash With a SDHC Card
It does not come with the drivers to support SDHC over 2 gigs, but go this link and install the app. after that it will work.
ftp://xda:xda@ftp.xda-developers.com...port%20Kit.cab
Jul 30, 2008 | T-Mobile Dash Smartphone
Open Questions:
SanDisk 8GB microSDHC Memory Card with MobilMate Micro Media Card Reader Logo
1,301 people viewed this question
Top SanDisk Electronics - Others Experts
Brian Sullivan
Brian Sullivan
laikexpert
laikexpert
k24674
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
