Question about Directv HR10-250 DTV Receiver
Power Issue? Hello. Last night we had a power outage (which has happened several times before). The DVR won't turn on...although I can hear the fan run, the power light won't come on. All other TV functions are normal (xbox, dvd player) Is my dvr unit shot? Thanks in advance, Chris
  • vwillang Dec 25, 2008
    I have the same issue. Power went out for about an hour. I can hear the fan and HD running but no power light and no output to the TV. Is my unit done, or am I missing something really simple?
  • 86 Answers
Unplug the satellite receiver from the electrical outlet for about 30 minutes and then try it again. If it still doesn't work, call DTV tech support to discuss having it replaced.
Posted on Mar 19, 2009
  • 68 Answers
Unplug the satellite cables and restart the dvr. if the dvr powers up plug in the cables when u see searching for satellite.
Posted on Jan 05, 2009
HP Compaq Presario CQ60 Won't Charge
Three blinks in a row is the LED code for a memory issue.
Turn the laptop over, remove the panel over the RAM, remove the DIMMs (it will likely have 2 in it), place one in at a time and try powering the system on.
One of the two is likely bad although it is possible (although very unlikely) that both are bad. It should boot up when the good DIMM is in place. Once you have identified the bad one, buy a replacement or possible choose to upgrade the total amount of RAM.
Jan 04, 2013 | Computers & Internet
Honeywell thermostat won't turn the furnace on after power outage.
probably tripped a limit switch or a low voltage fuse would kill your display on the tstat, you should have battery power on your stat though.unless you have knowlege of electrical you better call a technician
Dec 09, 2012 | Honeywell Programmable Thermostat Heater
We have a new 60 inch LED Sharp TV. Will an APC #BN600R battery backup, 600 VA 360 watts, handle a power outage or surge for this TV and a Dish network DVR??
Yes this UPS will protect the TV and the DVR.
The TV is pretty energy efficient, and uses just under 100watts powered on. The DVR uses under 30 watts, so under heavy load you won't go over 150 watts if just these two devices are plugged into the battery backup side of the UPS. I'm not sure how long this UPS battery last's in a power outage, but since you are not using it to the full 360 watts, you should get double time out of it, though of course, its best to power off your devices as soon as you can. Regards, Chris
Jul 12, 2011 | APC BN600R Battery Back-up 600VA UPS...
Pvr goes from on to off several times at start up. Also often deletes recorded programs.
All my recordings (30 + hours) were erased after a power outage!
Can I get it back??
Please help
Apr 25, 2010 | DISH Network DVR 510 DTV Receiver /...
Air conditioner compressor runs for about 1-2 min, then cuts off
well when u have outages the voltage drops obviously, the one that suffers are the capacitors the capacitor for the compressor might need to change, change it with the same capacity as the old one example if labels say 55 microfarady ( mf ) ( 55 mf ) get one of the same I am not saying it is a 55 mf capacitor vary depending on motor and brand. So check the label
Jul 23, 2009 | Danby Portable Air Conditioner
Packard Bell F9150 desktop power supply
open your cpu cover .
Then check your power led on motherbord blink or not also reattcha ll connection to motherbord.
check your smps fan is movinh when you switch on.
May be you have to change smps it is square box from with you attch power code.
Jul 17, 2009 | Computers & Internet
My Vip622 was down this morning, no power outage,
Unplug the unit from the mains for at least an hour, then plug it back in again and try to boot it up.
Good luck
Jun 19, 2009 | DISH Network ViP622 DVR DTV Receiver /...
How do I know if my Directv HR22-100 HD receiver is dead?
one last thing you can do, if it doesnt work the dvr is dead. reset the dvr and wait for the hello screen and then the screen will go black. when it turns black, hold the down arrow (on the front of the dvr) and the record button for at least 5 secs. this will re-format the hard drive. if it doesnt work the dvr is dead
Jan 02, 2009 | Directv (R10) DTV Receiver / 70-Hours...
DVR 510 WON'T WORK ANYMORE
Did you have a power outage last night or lightning strike? If not unplug the receiver for approxiamately 30 seconds and plug it back in to the wall plate. Try to turn it on now. If it fails to power up it may indicate that the receptacle is bad or the receiver. Swap the plug from the receiver to the known good outlet the tv plugs into and try to power it up. If it fails the receiver is dead and you will need a new one. 510 are due to be discontinued with Dish so your local provider may not have one to replace yours with and you may be left with the option of upgrading the receiver, seeing if Customer Service can send you one out if you have a warranty program or buying one from a retailer or online.
Hope this helps you.
Apr 07, 2008 | DISH Network DVR 510 DTV Receiver /...
Directv HR10-250 DTV Receiver Logo
740 people viewed this question
Top Directv Televison & Video Experts
john milligan
rundiggity
Are you a Directv Televison and Video Expert? Answer questions, earn points and help others
