Question about Pioneer GPS
Avic X1BT gps has a mind of its own. voice directions keeps telling me to do U turns even on motorway. Previous routes cancelled OK, verbal only works intermittantly. High lighted direction on maps will suddenly go off and i have to reselect route to get it back. Hide away unit is level, mounted firmly facing the right direction.Aerial on roof OK.
Total factory reset then with wiring diagramme I downloaded for my car and help of Pioneer technicians connected in speed pulse. Cured Problem O.K.
Posted on Nov 10, 2008
Sat Nav will not take me on motorways yet i havent got any avoidances set, once i get on motorway it wont redirect itself just tries to take me off motorway and go back. Also takes longest route possi
'Avoid Motorways' must be set in Avoidances, it is the only explanation, but there are also settings for 'Shortest Route' and 'Fastest Route'. It may be 'Shorter' not to go on the motorway.
You can also try resetting the unit and make sure you have the most up to date firmware and software.
specs, manual and support here. See page 19, Navigation Preferences and Avoidances.
Nuvi 50 Garmin
Oct 24, 2017 | Garmin nuvi 50 Travel Assistant
My garmin 205w doesn't tell me verbally names of streets and exits. My brother has the same exact model and his does this function.
Some of the voices on Garmin satnavs speak streetnames and others don't. Press Tools, then press settings, then press Language. You'll see the Voice name. Press it and select a different one. (American English Jack or Samantha TTS will speak the streetnames). Press OK and it should then be ok.
Aug 14, 2010 | Garmin nuvi 205 GPS Receiver
No verbal directions, just shows the route on screen
If you go to Preferences and click once, then click the arrow until you come too a pair of lips i think, click this only if it has Not got a cross through it, if it has then the unit has a problem
Apr 23, 2010 | Tomtom ONE GPS Receiver
I put in an address in my Magellan Maestro. But it shows me the directions to a previous destination.
you still have an active route...tap the map screen then scroll over to turn to next page...in there it says cancel route...cancel it then start over.
bill
Jan 29, 2010 | Magellan Maestro 4040 GPS Receiver
Navi g tells you to turn when you're right on the corner-too late
Hi
In the actual menu of your Nuvi there are different settings for getting to your destination via either
a) fastest route
b) shortest distance
Unfortunately quite often when the Nuvi is set to fastest route it will do all it can to get you onto the motorway or a main road as this is the way the software is set up. When in fastest route mode it cannot figure out that to go on the motorway in this instance is not the most convenient route for you to take at all.
If you change to shortest distance mode (its under the navigation menu I think) you will find it will take you by the route to your Nannas you would normally expect to go.
Sometimes this function is hard to work out as to which is the appropriate setting for a particular journey - you will need to experiment a bit with it but the general rule is if it is in fastest route mode it will look for motorways and main roads and ignore the convenient little back roads that we all know in our own locality.
You may find as general rule that if you plan a journey to somewhere thats within your local area its better to select shortest distance mode.
Fastest route may work better for longer journeys.
Hope this helps. Please do rate my answer. Many Thanks.
Jul 28, 2009 | GPS
Stop a nav route
Once you pick your new destination, the unit will ask if you want to delete the previous destination. If you just want to delete the route, hit the menu button, go to destination, and it's the bottom right selection.
Mar 25, 2009 | Pioneer AVIC-F700BT Car GPS Receiver
Msn direct status
try getting the new 2.0 firmware on and put it on a SD card, install the new firmware and then install AVIC feeder on ur computer and change the settings to your likeness and save it on ur SD card. your AVIC will ask you to update aka yes or no and click yes, after the first time it will restart and load again with the same ?, click no and go to MSN direct status. keep in mind that the upgrade must take place in the cradle in a msn direct zone.
Feb 09, 2009 | Pioneer AVIC-F500BT Multiumedia GPS...
Pioneer avic-x1 r
OK on the nav side it's not the vss wire the is to just tell the avic you seep for off road use to nav track your rout. in the nav menu it should say gps ant or sum thing like that it will tell you how Meany sat it sees that should tell you if the ant is broke or not
Dec 29, 2007 | Pioneer AVIC-X1R CD Player
Can not get route information desoite having had it programmed into garmin
Try doing a hard reset. Hold down the back button (leftside), the thumbwheel, and then the power button. This will reset all setting back to factory default. You will lose any custom setting, recent find and waypoints.
Nov 19, 2007 | Garmin StreetPilot i3 GPS Receiver
GPS Logo
148 people viewed this question
Top Pioneer GPS Experts
David Burbee
David Burbee
Are you a Pioneer GPS Expert? Answer questions, earn points and help others
