Question about IBM Color Scanner Flatbed Scanner
Need help to hook up IBM color flatbed scanner
I was just given an older IBM scanner, but don't know how to hook it up. I know I need to plug into power, but there are two 25 pin cable outlets on back, one male and one female and faint pictures for each. Looks like a monitor above the male and a computer (maybe a printer?) above the female. Don't know why I would need to hook into a monitor, so will it work if I hook into the computer one (has the 25 pin female outlet) and then in to the computer, then install drivers, or ?????
Any help at all is appreciated. Much Thanks!
Ron
Attach one end of a parallel port cable to the parallel (printer) port on your computer and the other end of the cable to the computer port on the rear of the scanner. If you have a printer connected to your computer, you must disconnect the printer cable from the computer before connecting the scanner cable.
If you have trouble attaching a cable connector to a port, be sure that you are connecting the correct end of the cable to the correct port.
IF. . . you want to use a printer WITH your scanner, attach one end of the printer cable to the printer port on the rear of the scanner and attach the other end of the cable to the printer.
Plug in power cord and then power up PC.
Power on scanner. Install drivers. Restart PC to activate EZ Station buttons.
Posted on Nov 25, 2008
I am having trouble finding the correct software to get my Windows 8 system to recognize (install) my IBM Ideascan flatbed color scanner model 0275-011. It is unused and I don't want to buy a new one. I...
The scanner should have had software. IF not go to the IBM website and see if the software is there. It may be a legacy machine, so be source to look for it in the IBMlegacy area. I have found universal IBM scanner by just entering the name, and not the number in Bing
please try a bing search. Use the name and the model number. Be sure your scanner is for a PC and not a Mac.
IF you have windows 8 or 10 go to control panel and ask it to find your devices if it does it will install software. Lastly, go to an IBM forum. And ask the question, you may find you software if it existts.
Sep 08, 2017 | IBM IdeaScan Flatbed Scanner
How to connect to the computer?
Devices: Canon CanoScan FB330P/FB630P Color Flatbed Scanners
Check pages 22-23 of this copy of your Canon Canoscan 630P Product Guide.
You'll need an "IBM-type" parallel printer cable - with a DB25 on each end, and your computer will also need to have an "IBM-type" DB-25 parallel printer port.
What the Canon Product Guide fails to mention is that this "IBM-type" printer cable is a kluged Centronics parallel printer cable, but became so popular (on older computers - your laptop may not have this port), that it got an IEEE standard: IEEE 1284 (with DB25 connectors on both ends).
You'll need a DB25-to-DB25 M/F cable, meaning DB25 connectors on both ends, with a Male on one end, and a Female on the other end.
The Male DB25 will plug into the Female DB25 connector on your computer/laptop, with the Female DB25 going to the FB630P Color scanner..
Here are some pictures/pricing:
http://www.computercablestore.com/IEEE_1284_Printer_DB25_to_DB25_catID2134.aspx
The nice thing about the design of the Canon FB630P Color Scanner is that the scanner also has a Female DB25 Printer port for an existing parallel printer, so when you connect an FB330P/FB630P to your system, your existing parallel printer is daisy-chained through this port - so you needn't give up you printer (to scan), nor must you install another parallel printer port onto your PCI-bus tower PC to keep your printer.
Canon Canoscan FB330P/FB630P Color Scanner Product Guide (82 pages):
http://canoncanada.custhelp.com/ci/fattach/get/267/
Most modern printers are USB-attached to laptop systems, so you may need an adapter, an example of which is seen here:
http://www.cablestogo.com/product.asp?cat_id=116&sku=16899
Dec 05, 2011 | Canon CanoScan FB630P Flatbed Scanner
I have an older(much) 2400p flatbed scanner. Our computer doesnt have the appropriate plug in for the scanner, which has a db25 female(to the pc) plug. I cant seem to find any info on whether the adapter...
This is a PARALLEL scanner and most of the much newer computers don always have these.
You can buy adaptors to install in the computer or USB adaptors that convert it to USB but by the time you have paid for one of those you could buy a new one.
Do a GOOLE search for parralell to USB and that will give you an idea of the cost.
Also do a search for parralel cards to get an idea of that route.
Prices vary from country to country which is why I have not given you any figures
Jan 27, 2011 | Visioneer PrimaScan Colorado 2400p Flatbed...
Connecting old IBM color flatbed scanner to new computer
Not likely to work reliably if you get it to work.
The parallel port must be set to communicate in both directions. The SUB to Parallel adapter may be a ONE-WAY communications device.
Get a new (or used) Epson scanner or Epson all-in-one ($50) which includes a scanner and printer! Your new computer may not have the proper drivers for your old IBM scanner, anyway. If you purchase an Epson all-in-one, get a "WorkForce" model - that's their latest product line.
Sep 28, 2009 | IBM Color Scanner Flatbed Scanner
Scanner installation in vista OS
i m using color flatbed scanner of acer i m not able to install the mira CD in windows vista home basic what is the solution for this .. the cd given to me is MiraCD 90.S0805.406
driver snapscan e 20 per vista os
instalacion de scanner 5000
I hae a MiraCD 90.s0805.406 -
Dec 12, 2008 | Office Equipment & Supplies
How to start up
I also have one of these and they are completely worthless with out the interface card that is ment to come with it :(
Aug 31, 2008 | IBM ADF Flatbed Scanner
Ibm color flatbed scanner
To download that, go to http://www.stuffware.co.uk/photostudio
Or download it right now by clicking Photo Studio Version 2.69
There are other files to get it working. You have to download this here at http://www.microsoft.com/downloads/details.aspx?displaylang=en&FamilyID=32BC1BEE-A3F9-4C13-9C99-220B62A191EE
It's theMicrosoft Visual C++ 2005 Redistributable Package
May 20, 2008 | IBM Color Scanner Flatbed Scanner
Lost drivers/instructions cd for IBM IdeaScan Flatbed Scanner
Go to the Lenovo website (www.lenovo.com). They bought out the IBM PC business. Search for 0275-011 and it will bring up the download page with drivers and instructions. Direct link is: http://www-307.ibm.com/pc/support/site.wss/document.do?sitestyle=lenovo&lndocid=MIGR-4793QC
Feb 20, 2008 | IBM IdeaScan Flatbed Scanner
Driver for Vista Business OS sytem
Might not be, a lot of scanners do not have Vista drivers.
You could consider VueScan from Hamrick.
Oct 14, 2007 | IBM Color Scanner Flatbed Scanner
Update driver for the scaner with win xp
The driver on the link below is reported to work with this scanner on Windows XP. You will need to register (free) on the site to download: http://www.scanner-drivers.com/drivers/120/120718.htm Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 12, 2007 | AcerScan 320P Flatbed Scanner
Open Questions:
IBM Color Scanner Flatbed Scanner Logo
225 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
