Question about Lands Phones
Phone rings once then makes a sound like a fax machine pick up we do not have a fax hooked up????? unable to get calls becuse phone only rings once and cuts off we bought thid uniden only 2 weeks ago started this last night???????
I fixed it we are cancer patients and just bought this phone I do not feel that we should have to PAY to find out the problem Uniden I thought was a great company maybe I we wrong.We are unable to hire you for this thanks Barbara
Posted on Oct 12, 2008
I don't use an answering machine. My phone has voice mail but the machine is not even recognizing when a fax comes in. The fax call goes into the voice mail each time. The phone line is working-I get a...
You need to set your phone to pick up later than the fax machine. set it to pick up on the 4th or 5th ring, set the fax to pick up at 2 or 3. Better yet, get a distintive ring # set up by your phone co. then the fax will only recognize that ring.
Dec 30, 2010 | Canon PIXMA MX870 Wireless Office...
My hp 1040 will not pick up fax after the fifth ring answering machine picks after forth ring can't tell the between phone call or a fax used to before changed date on answering machine fax quite working
Set rings to answer
You can select the number of rings that will occur before the fax answers an incoming call. If you are using your machine as both a telephone and a fax machine, we suggest you set the ring count to at least 4 to give you time to answer.
TIP: HP 1050 Fax: The Toll Saver function for the Digital Message Center interacts with Rings to Answer. See Toll Saver on page 40. If you have the HP 1050 Fax and have Toll Saver turned on, set the Rings to Answer to 2.
1. Press Menu repeatedly until BASIC FAX displays and press Start/Enter.
Rings to Answer will display.
2. Press Start/Enter.
3. Enter the number of rings you want (2-7) and press Start/Enter.
The HP Fax rings the set number of times and then answers. It then produces a different sounding ring to alert you to which type of call is incoming.
• The additional ring may occur once for a fax call
• The additional ring occurs 5 times for a voice call. After the 5 additional rings, the answering machine will answer.
Dec 08, 2010 | HP 1040 Plain Paper Inkjet Fax
Not receiving any incoming faxes
Is the phone line working? Do you have any devices connected to the phone line that pick up before the fax machine? Make sure the machine has paper and is set to FAX or AUTO. Is there a Memory Full error? Clear the memory (Setup > Memory Clear then press Start/Enter. Use the left and right arrows to select the items to remove. Press Start/Enter twice (second time to confirm the choice). Repeat until all memory is cleared that you wish to clear. Then press Stop to exit.)
If you are using the ANS/FAX mode and have an answering machine connected to the extension port, disconnect the anwering machine and switch to FAX or AUTO. Check if the machine receives faxes. Sometimes the extra device causes interference. Call the fax machine from a different phone number and see if you hear the fax tones.
Check that the Junk Fax barrier is off, if the incoming call is from a machine that is not listed in your speed dial database. If you have a distinctive ring, make sure that the Fax machine has learned the ring by pressing Setup go to DRPD. Choose Set and call the fax machine from another phone. The LCD will say Waiting Ring until it gets that call and then once the ring is learned will say END DRPD Setup
I hope these ideas help.
(If you have a phone company voice mail service, the faxes may end up stuck in that box. It depends on how many rings the fax is set to wait before picking up versus when the voice mail opens to take the call.)
Jul 16, 2010 | Samsung SF-515 Plain Paper Laser Fax
My fax goes off periodicall when a call comes in.
It means that your fax machine is "answering" the incoming call before you pick up the handset. Usually, the factory setting on the fax machine picks up after two incoming rings. There are three ways you can address this issue: 1.) You can either change the number of rings to, say, five incoming rings to give you enough time to answer the phone before the fax machine picks up, or 2,) you can find out if your fax machine has a feature that allows for the voice hook "click over" that will allow you to override the fax when you pick up your handset, or 3.) turn your fax machine off until you need to send a fax.
If you want to investigate number 2.), then you'll need your operator's manual.
Good luck.
Aug 28, 2009 | Office Equipment & Supplies
Help I have a Lexmark all in one x7675 which I have been using without problems wirelessly. I am trying to use my home phone number as a fax connected to the printer. It seems to work if I ring it from my...
When you ring it from your biz line, does it pick up? If you're using a high speed dsl line, you'll need to put the machine where a normal phone would go. You should be able to ring the machine using our cell phone. If the machine indicates an incoming call, but still doesn't pick up, check the settings and make sure it isn't set to manual instead of automatic fax pickup.
Apr 20, 2009 | Lexmark X5470 All-In-One InkJet Printer
Canon MP530 receive fax issues
Receive Mode Settings Select from the following receive mode options to suit your needs. Once you've decided on which receive mode to use, follow the below instructions to set the receive mode using the operation panel. Receive Mode Setting
  1. Press the <FAX> button to enter Fax mode.
  2. Press <Menu>.
  3. Press the right or left arrow button to select [Receive mode settings], then press the <OK> button.
  4. Press the up or down arrow to select the receive mode that best suits your needs, then press <OK>.
Types of receive mode
Select the receive mode according to your needs.
Receive mode
Purpose
FAX/TEL AUTO SW When you want to receive faxes automatically as well as voice calls. FAX ONLY MODE When you want to receive only faxes automatically with your machine, or have a dedicated telephone line for FAX use only. DRPD When you have subscribed to a DRPD service with your telephone company. MANUAL MODE When you receive mainly voice calls and sometimes faxes, or want to receive faxes manually. ANS.MACHINE MODE When you want to receive voice messages on your answering machine and receive faxes automatically. FAX/TEL auto switch
FAX :
The machine does not ring but will receive the fax automatically. Voice call :
The phone attached to the machine will ring. Pick up the handset to answer the call. Note:
  • Ring start timing and Telephone ring length can be specified in FAX/TEL auto switch in the Receive mode settings.
  • If you want the telephone to ring when it receives a fax, connect a telephone to your machine and enable the Incoming ring settings in RX settings.
  • The phone attached to the machine may not ring depending on the telephone type you are using.
FAX only
FAX * :
The telephone does not ring. The machine will receive the fax automatically. Voice call :
You will not be able to answer the call. * If you want the telephone to ring, connect the telephone to your machine and enable the Incoming ring settings in RX settings menu.
DRPD
FAX :
Your telephone line will ring according to the ring pattern you have chosen and receive the fax automatically. Voice call :
Your telephone line will ring according to the ring pattern you have chosen. Pick up the handset to answer the call. Note: Specify the FAX pattern in the DRPD: Set FAX ring pat. in RX settings menu.
Manual RX
FAX :
The telephone attached to the machine will ring. Pick up the handset and if you hear a beep tone, press the <Color> or <Black> button on the machine to receive the fax. Voice call :
The telephone attached to the machine will ring. Pick up the handset to answer the call. Note: If you are far from your machine, you can use the remote receiving function to receive faxes. Pick up the handset of the telephone connected to the machine and press 25 (the remote receiving ID).
Ans. machine connect
FAX :
First the answering machine connected to your machine will respond to an incoming call, and then the machine will receive faxes automatically. Voice call :
The answering machine connected to your machine will respond to an incoming call. Note:
  • Set the answering machine to answer on the first or second ring.
  • The entire message should be no longer than 15
Nov 24, 2008 | Canon PIXMA MP530 All-In-One InkJet...
BROTHER FAX 1840-C.
Set your machine to MANUAL, this will allow you to answer every call yourself, then if it is a fax, the machine will take over. Sounds like you have it in fax/tel mode now, which allows for the fax machine to answer every call then if not a fax, double rings to you.
Sep 19, 2008 | Brother IntelliFAX 1840C Plain Paper...
DXA18580 series
Increase the # of rings before the fax picks up so that it's greater than the # of rings before the answering machine picks up. When you're expecting a fax, turn off the answering machine.
Syskiyou
Jul 26, 2008 | Uniden Cordless phone EXS9950
Cannot figure how to set up Canon MP830 All in One Fax machine with remote answering machine
Cannot figure how to hook up Canon MP830 all in one fax with remote answering machine. I can plug in phone line to send faxes fine but when hooked up in same hole and the phone rings it goes immediately to fax and can't receive phone calls. Maybe i have phone line hooked up in wrong place on my machine. The answering machine is in our master bedroom on the other side of the house. With my last a canon also i had it hooked up to go to fax after a certain amount of rings and it worked fine. That machine got fried by lightening and i replaced it with this machine. If anyone knows what i am doing wrong i really need this fax hooked up all the time for my business.
May 01, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Hooking up a fax machine on home telephone line
Well... the problem is that you are running two machines on one line. ONE of them has to take predominance. Both machines should have settings for "number of rings to answer at". It sounds like you currently have the fax set to less than the answering machine, so the fax picks up after two rings, while your answering machine might be set to more, which it never gets to, because the fax answered the call already(It doesn't matter if you answer the phone, or the fax picks up, once the line is open, the answering machine is taken out of the equation). Even if you set the answering machine to answer first, you're then taking the fax service out of the loop. I'm not sure how you're going to juggle that, since both types of machines each need control over the line to work properly. That's why we (business machine folk) always recommend a dedicated line for fax service.
Jan 23, 2007 | Canon FAXPHONE L170 Plain Paper Laser
Lands Phones Logo
610 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
