Question about GE PSC23SGRSS Side by Side Refrigerator
Ice and water dispensing problem; compressor shuts off when paddle pressed but dispensing is sporadic
Due to sporadic water and ice dispenser problems, I ordered and replaced the interface display circuit board but ...that fixed nothing. When I push the dispenser paddle, no ice will dispense but water will dispense sporadically. Whenever I push in the dispenser, the dispenser light will come on but then dim and if the compressor is running, it will shut down the compressor until the light timer shuts off....then the compressor revs up again. If I switch the panel to turn on the light only, the same dimming and compressor shut down occurs. The ice maker makes ice fine and sometimes the water will dispense fine but then seconds later will not.
Could the problem be as simple as the simple inexpensive switch up where the dispenser paddle triggers, or could it be the main circuit board or some solenoid? Something drags down the power source.
Your help would be much appreciated. I hate to keep buying parts with no success.
Dan
  • 2 more comments
  • dannos24672 Oct 11, 2008
    I have checked the ice bin auger and that is not jammed up. When I select ice (crushed or cubes)nothing even tries to turn or start.
    What concerns me is that even if I just turn on the dispenser light, it dims and the compressor stops until I turn the light off again. Then the compressor revs up again. This indicates to me that the switch for the dispenser paddle is not the problem since the power drag down problem occurs even without pressing in the paddle. I think it the problem is the main circuit board but want an experts opinion to cofirm my deduction. I am not sure if their would be something else.
    Thanks for the advice.
    The fan and compressor seem to be running fine and keeping the refrigerator and freezer at the correct temperature.
    How do I check the thermostat and thermostat valve? Would these be the problem if the refrig and freezer are staying cool?
  • dannos24672 Oct 12, 2008
    Ohms, Thank you for the reponse. I tried uploading pictures but this site only allows 150 kb .jpg files and I could not compress any of my pictures that small. I will keep trying. I had the whole front panel apart and the paddle removed and the paddle switch out. Is their another way to send you the pictures?
    NOTE: The water will dispense and the light will stay bright and not dim if the fan and compressor are at rest and not working. At that point it seems to have enough power to open the water valve. BUT...the ice dispensers still don't even make a noise....nothing regardless of the compressor and fan status.
    This behaviour just started all of a sudden one night. It was weird.
    Thanks Pablocsa but jammed ice does not seem to be the problem. The ice shoot is clear and open. I can also turn the auger by hand. The dispenser flap opens and closes ok by hand. Not sure if that solenoid has a problem which should open that round ice flap door when the paddle is pressed.
  • 2,071 Answers
    Sergeant:
  • 409 Answers
i can certainly simpathize with your problem.
here are some things to check before you call a repair man per the last suggestion.
the sporatic ice and water production is due to the icemaker itself malfuctioning. all icemakers have a built-in water valve. its better to replace the valve, rather that the icemaker. the water valve solenoids activate the water and ice paddles (or actuators). check the water valve and the solenoids for any leaks, rusting or otherwise. if all else fails, replace the icemaker.
seems that you don't have a water leak anywhere in the water line or otherwise, so that is a good sign. the best way to know, is to see if you have any frost build up on the inside of the door or any leaks on the bottom of the freezer.
the reason the compressor keeps kicking in and out may be many. if at a any point the compressor relay is tripped, the compressor will shut off. it's to protect it from overheating or even worse starting a fire. i would have a service man check out the compressor because it's part of the sealed system. i would recommend that you do not try to repair it yourself.
Posted on Oct 12, 2008
  • 750 Answers
Hello dannos24672
Welcome.
You said, Whenever you push in the dispenser, the dispenser light will come on but then dim and if the compressor is running, it will shut down the compressor until the light timer shuts off....then the compressor revs up again. And if you switch the panel to turn on the light only, the same dimming and compressor shut down occurs. The ice maker makes ice fine and sometimes the water will dispense fine but then seconds later will not.
Yes, In my opinion the problem could be as simple as the simple inexpensive switch up where the dispenser paddle triggers! Yes I think you are correct. Good call!
You asked,How do y check the thermostat and thermostat valve? Would these be the problem if the refrigerator and freezer are staying cool?
I believe that you could be correct in thinking that the thermostat is not related to this,
since the fridge is staying cool.
Very interesting!
Let me know how it goes.
Huuum
Please remember to leave a rating.
Posted on Oct 11, 2008
    Sergeant:
    Champion:
  • 435 Answers
I would suggest that the best way to fix this would be by contacting GE service at  http://www.geappliances.com/service_and_support/service/schedule_service.htm
    Genius:
  • 1,124 Answers
The ice remains stuck between the dispenser and the top of feeding ice. This respond to a broke rubber on the last section where the ice must be delivered. Replace the rubber will fixed the problem. It is a common problem on this kind of devices. To remove the ice simply move the stuck ice from the bottom oro yu can try putting some warm water from the top. Before to do nothing, unplugg your refrigerator first.
  • 1,879 Answers
Something is grounded and based on your observation it only triggers when you use the dispenser or the light switch on the panel.
since you were able to replace the display circuit, can you open the panel to get a view where the light switch is and the wires for the dispenser paddle? take pictures and post it back here so that we can all see. kinda hard without looking at it.
    Sergeant:
  • 399 Answers
It could also be the problem of internal wirings of the circuit board which supports the compressor.
also to start check the fan is it running in the fridge as the compressor starts.if nor running check the fan motor.and also check for the thermostat and thermostat valve.
  • masterexpert Oct 11, 2008
    Compressor won't run or it is "clicking' on and off: This normally could be a bad start relay and over load for the compressor, dirty condenser coils need cleaning, condenser fan motor is not running or the compressor itself. To check the compressor properly you should test it with an amp meter, each compressor is rated in running amps ( see model/serial tag or the sticker on the compressor )...if the compressor is drawing too much current, this may be why it is shutting off. Check the model tag for proper amp rating. Some relays will be easy to notice the broken with them, they may be burnt. Example one, example two, example three. Some of these relays can be removed and give them a little shake, and if they rattle around inside the relay is likely bad. Compressors can also seize and click on and off or one of the electrical windings inside the compressor could have opened up. You can use a test cord to help check the compressor and this also will help with the amp test. If the compressor checks ok and you want to install a replacement start relay. You will need to find out which winding is which. You will need an ohm meter to determine the windings. First check to see if you have windings in the compressor. Then check to see if they are grounded. If the compressor has windings and they are not grounded, you can find which winding is which. Check for grounded windings by reading from each terminal to a good ground on the cabinet. Read from the top terminal to the lower left terminal. Read from the top terminal to the lower right terminal. Read from the lower left terminal to the lower right terminal. Write down the resistance of each reading as you go. The highest reading you get will be the run and start winding of the compressor in series with each other. The other terminal left will be the common terminal. Read from the common terminal to each of the other terminals. The terminal with the lower resistance will be the run winding. The higher resistance the start winding. Using the original style relay is always preferred, but using a general replacement can "get you by" if needed.
  • 958 Answers
Could be the big motor that turns the ice in the bin when dispensing the ice. pull out the ice bin, check the big metal thing that turns when you press ice at the front dispenser. or you have a big chunk of ice that the motor can not turn.
tnx 4 using fixya,
drcool
  • francis rivero Oct 11, 2008
    ok,
    when you replace the interface board, does it includes the micro switches that are pressed when you switch to ice or crushed?.
    could be the micro switch underneath the paddle where you put the glass when you want to get ice or water.
    please check them.
    tnx again, drcool
Samsung model rf4287hars only dispenses water when ice lever depressed
3b662ccb-018c-4390-ab7a-74a2025960df.jpg 3d562c7f-18a6-4fa7-9993-373c8c5d3c7f.jpg 763378c4-5f13-435a-aac3-b67d9041b031.jpg
First photo shows paddle assembly that can be purchased you need to got to Sears web site to find part # other wise you will have to buy the whole circuit board assembly hundreds more than the paddle assembly. The circuit board and paddle assembly is removed buy removing screw on inside of door and pulling it out be careful it seems strange but it just pops out. The paddle assembly slides on to the circuit board assembly look close and take your time to slide it off I thought I was going to break mine but did not and save me big money.
Second photo shows tab for water dispensing still there.
Third photo show ice dispensing tab broken and missing.
If you leave the assembly plugged in press the micro switch for the ice dispenser and see if it works most likely the tab has broken and is what hits the switch telling the door to open and ice dispensing screw to push ice to the door. Hope this helps
Mar 04, 2014 | Samsung RF4287HARS - 28 cu. ft. French...
Samsung rf4287hars dispenser not dispensing ice
SAMSUNG RF4282/HARS has a total backwards-double negative on the menu screen ( at least to me ) tho granted, the ice maker is perhaps, lets say, one of the slower cube makers I have ever seen... it has a setting that is .... "Ice Making OFF".... with the option ON/OFF.... make sure that setting is set to OFF if u want ice, or non Orange on the ON screen, or no ice will be made... It could have been worded much better... ie: "Turn Ice Making Off" with option yes or no... but no... My mind says...Make Ice, have options yes or no = just that....if I select YES ... ice making should be on.... not with Samsung... Kinda should go with the other setup settings that Samsung has..... simple yes/no
Words are.... ( selection )
"Ice Making OFF" setting should be set to OFF... just to do that... you are turning the shut down mode OFF and u will be making ice ( you are turning the shut down ice making function OFF in common terms)
As expensive as this machine is.... It should be easier and programing should restore after a power flux.... anyone wanting a lot of ice... forget this machine... we continue to purchase bagged ice and keep it in the freezer in the garage, it can\'t keep up on a daily basis.... I continually have to re-enter my WIFI passcode at every power outage... ( sometimes a lot in summer with storms )
My wife wanted it.... steel look.... she now finds she hates keeping it clean... NEVER AGAIN.... Samsung has some great products, but we have to suck up on this one... never again
Feb 27, 2013 | Samsung RF4287HARS French Door...
Electrolux EI23CS55GSI - Water Dispenser Will Not Stop Running
sounds like the paddle you push to dispense the ice and water is sticking,if there's a rubber pad there try moving it to see if it frees it up,if not it looks like you have to replace the whole part 242100018 go here to see it
https://www.repairclinic.com/PartDetail/Dispenser/242100018/3513417
Jan 18, 2018 | Electrolux Refrigerators
My Samsung Model: RF4287HARS refrigerator stopped DISPENSING ice. It makes it, but only water comes out of both push levers now. I get ZERO help from samsung customer service. There is nothing in
The problem is actually in the dispenser lever. The paddle that you press to dispense ice has a plastic lever/arm that extends behind it (you can't see it, it's up high in the assembly.) This plastic lever presses upwards when you push the paddle and presses into a switch. The switch actuates the ice. This little lever is also the ONLY thing that stops the paddle from continuing to press into the water paddle. So when the lever breaks, it creates your two symptoms - no ice and if you press further, you press the water switch and get water.
You need part# DA97-08519A. This is the lever assembly with the switches. You pry the control panel assembly (the whole digital display above the water/ice dispenser) out by inserting a slim pry bar (I used a pocket knife and didn't damage the finish) on one side and working my way around. The assembly is held in place by five plastic tabs (two on each side and one on the top.) When this is removed, the part# above will be obvious.
Sep 08, 2012 | Refrigerators
Ice dispenser stuck on
Either the paddle for the ice/water dispenser is stuck or you have a bad microswitch behind the dispenser.
To stop the ice/water from dispensing open the freezer door and press or hold the child lock button down. Once the unit is in child lock mode you can shut the door without energizing the dispenser.
Another option is to remove the upper freezer door hinge cover and disconnect the wire connector up there. This will remove voltage from the dispenser as well. Then either replace the paddle or switch. Sometimes the paddles/switches will get stuck because of splash up from ice dropping in sugary drinks.
May 05, 2017 | Amana ASD2328HE Side by Side Refrigerator
In door ice and water dispensing
sounds like the paddle is hanging up or the micro switch that the paddle actuates is sticking if you can see the micro switch spray some wd 40 on it open the door and work the paddle a few times
Feb 15, 2008 | Frigidaire FSC23F7D Side by Side...
GE profile performance tfx30ppz ice dispenser not working
Had the same problem. The water line from the valve to the ice maker was cracked due to heat from the compressor.
Jan 09, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Psc23sgrd ss ice/water dispenser not working
It is possible. When you put hit your glass against the paddle to you hear the switch click? And can you still select between water, cubed, and crushed ice? Also does the light by your glass come on when you but your glass against the paddle?
When you put your glass on the paddle it pushes in a microswitch. That microswitch will power the light if it is working and also sends power to the board you are talking about to dispense ice or water depending on what you have selected.
Nov 03, 2007 | GE Profile PSI23NCR Side by Side...
Water dispenser
the slide switch ice - water may not be making up. the paddle inside the door operates a common microswitch to either dispense ice or operates the water solenoid. check out the selector switch.
Aug 10, 2007 | Whirlpool GS6SHAXLQ 25.5 Cubic Foot Side...
GE PSC23SGRSS Side by Side Refrigerator Logo
309 people viewed this question
Top Refrigerators Experts
Sal De GO PATS
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
