Question about Vestax Handy Trax Turntable
Vestax Handy Trax
Hey,
I recently bought a Vestax Handy Trax turntable and I'm looking to upgrade the stylus to get a little better sound out of it. I'm looking for suggestions for a good, moderately priced stylus. Someone told me a Pfanstiehl would be good and cheap, but I'm not sure which model should be used. Thanks in advance for any help.
CL
Since the Handy Trax Comes with a Sapphire needle, upgrading to a diamong one will give a better sound http://www.turntablelab.com/dj_equipment/1/131/4962.html
Posted on Jan 04, 2009
Vestax Handy Trax Turntable skips toward the end of very LP played. Does anyone know how to resolve this issue?
Generally caused by a worn stylus, or incorrect pressure. Increase the weight - pressure, by adjusting the weight on the end of the arm.
Apr 22, 2014 | Vestax Handy Trax Turntable
Humming with vestax
hummm , does it also hum with the other gear shift out, especially tl and ledlights, if so it't a ground loop, but often is just the earth of the turntable not well connected
Apr 14, 2014 | Vestax Handy Trax Turntable
Clibrate pitch Vestax PDX d3S
It's a variable , since it's depended on more parts, but just clean it first and gently turn it until the platter moves correct,assuming you
mean to correct the variable resistor(potmeter) . If the value was everywhere the same, then you don't need a variable resistor:)
Jun 19, 2013 | Vestax Handy Trax Turntable
Looking to upgrade the cartridge/styli in my ion audio profile pro turntable. What products/company/style should I be looking for?
I have the same turntable, and sadly the cartridge is proprietary and unable to be changed. However, you can still upgrade the sound quality by replacing the stylus to a higher quality needle. I did that for about $25 and feel better about playing my precious vinyl. The biggest problem to this turntable is the lack of anti-skate. That's very bad...
Mar 27, 2011 | ION Audio Turntable Cartridge Replacement
My vestax doesn't start at all - is the tonearm damaged?
This is a belt driven turntable. It is very possible that the belt between the motor and platter has either broken or slipped off.
Consult your manual for instructions on how to access and replace the belt. Since it appears it isn't even trying to start, it is probably not just slipping.
If the belt isn't the problem - you could see if you see the drive motor running when activated. If the motor isn't running, there may be a problem with the motor, tone arm or something else.
Hopefully, the belt is the problem. Good luck!
Sep 21, 2010 | Vestax Handy Trax Turntable
How do i remove my stylus from the vestex handy trax
http://www.turntableneedles.com/search.asp?keyword=handy+trax&search=GO
use strong fingernail or similar to unclip the red plastic straight down. above is the needle you seek.
Apr 19, 2010 | Vestax Handy Trax Turntable
My turntable keeps skiping for no reason, no matter the record. i also made sure the turntable was level. the turntable is a vestax 2000mkII
What is the weight on the stylus? Flip the protective shield down to protect the stylus if available. Tare the tone arm (adjust the counterweight on the back of the arm until the arm floats perfectly level), then hold the counterweight and turn the dial markings to read zero. If you cannot find the recommended mass for the stylus you can use the average weight of 3g. Verify your tone arm is still floating in the center and the arm is perfectly level. Turn the counterweight until the dial indicates the specified weight of the cartridge manufacture specification sheet or you can set it for 3g if you do not have the specification sheet.
Nov 23, 2009 | Vestax PDX-2000MKII PRO Turntable
Pdx 2000 stylus calibration
Hi Misskit , i have a Dual turntable straight arm [Dual is the brand ] maybe you could visit their website and see if there is something similar to yours that you could get some specs from , i think they are still in business they are a German turntable manufacturer . happy spinning
May 24, 2009 | Vestax Pdx2000 Direct Drive Turntable...
Old Philips turntable 312 No sound
I am in a similar situation. I recently discovered that exact model turntable in our storage room. The Philips 312. While looking it over, I noticed the stylus is broken. I was wondering where you purchased yours?
Mar 27, 2009 | Philips Audio Players & Recorders
Vestax Handy Trax Turntable Logo
551 people viewed this question
Top Vestax Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve
Are you a Vestax Audio Player and Recorder Expert? Answer questions, earn points and help others
