Question about Aiwa CDC-MP3 CD Player
No illumination and no sound in my Saturn LS2
Aiwa CDC-MP3YU
Saturn 2000 LS2.
I removed this stereo from my friends chevy van and it was working fine.
I bought the adapter harness to hook it up to my Saturn. The stereo turns on the the display works fine. the Power bar shows the that it is playing but I get no sound. If I put a CD in and turn the volume up to max (80) I can barely make out some sound. The mute is off.
Additionally, the interior illumination does not work at all.
I have checked power, ground and illumination to make sure they are working properly and everything seems correct.
Any suggestions would be very helpful.
Thank you
Louis
    Top Expert:
  • Aiwa Master
  • 75,797 Answers
I suspect you have an auxiliary factory amplifier. Contact this company at the link for installation information.
Shop Car Stereos
Posted on Apr 04, 2017
informatica
  • 1114 Answers
SOURCE: Aiwa CDC-X304
You can download the manual from the link below: http://www.us.aiwa.com/default.asp?page=ownerManual&action=browse&model=418
Posted on Aug 06, 2007
imseth85
  • 30 Answers
SOURCE: aiwa fm/am compact disc player cdc-x304 face plate
Buy a new radio, you'll never find just the faceplate... trust me on this one it's not worth the headache.
Posted on Mar 31, 2008
SOURCE: Aiwa CDC-X207
hi yellow go in left bottom corner
Posted on Aug 17, 2008
SOURCE: Display issues with Aiwa CDC X207
I had the same problem. There are two small light bulbs that illuminate the digital display, and they are burned out.
You can easily replace them. The Aiwa part number for them is 8Z-KT1-641-010. The bulb is made by Sony, and the Sony part number is U0087654U.
I purchased them from Union Electronic Distributors:
https://www.ued.net/ued/addItems.do?itemCode=SNYU0087654U
Note that the product is not an item they keep in stock, so it may take 1-2 weeks or more before you receive them. Be patient.
Here are the steps to replace the bulbs. You will need a small (#1) Phillips screwdriver and a soldering iron (low heat). A very small flat blade screwdriver (1/8") will also be helpful.
1) Remove the faceplate from the radio and bring it to a well-lit work table.
2) Remove the four Phillips screws on the back on the faceplate.
3) Carefully separate the back half of the faceplate cover from the front half. There are three locking tabs along the top, and three locking tabs along the bottom. I used the small flat blade screwdriver to separate the two halves.
4) Once the back half of the faceplate has been removed, re-install two of the Phillips screws to hold the circuit board in place (one screw on each end). You don't need to screw them down tightly; just screw them in until you begin to feel them stop. These screws will keep the circuit board from separating from the front faceplate and causing the buttons to fall out!
5) Locate the two bulbs. They are labeled PL 901 and PL 902 (may also be labeled PL 1 and PL 2). Carefully unsolder the bulbs and remove them from the circuit board. You may want to do one at a time.
6) Each bulb has a colored cover to change the color of the light (I jokingly refer to them as 'bulb condoms'). Remove the covers and carefully slide them in place on the new bulbs. You may want to slightly dampen the bulbs to aid in sliding the covers on. Be sure to slide them all the way down.
7) Solder the new bulbs in place. They are not polarity sensitive.
8) Trim off the excess wires.
9) If you installed the two screws in Step 4, remove them.
10) Carefully re-attach the rear faceplate cover to the front faceplate cover, making sure that all six locking tabs snap in place.
11) Put the four Phillips screws in the rear faceplate and carefully tighten them.
That's it! Now, put the faceplate back on the radio, turn it on, and enjoy your lighted display!
Hope this helps.
Ron
Posted on Feb 15, 2009
smartr10U
  • 1305 Answers
SOURCE: I just go an AIWA CDC-Mp3yu car cd player out of
It's most likely a connection for a cd changer unit. you may be able to get an aftermarket cable to run an ipod... cool stuff.
For an antenna adapter... the local stereo stores carry those as well as the wiring harness adapters...
Posted on Jun 10, 2009
I am trying to get a starter off 2000 saturn LS2 and i can't get to the bolts Do i need to remove alternator or somehting else
I am trying to get a starter off 2000 saturn LS2 and i can't get to the bolts Do i need to remove alternator or somehting else. and what size female torx is it mounted with
Aug 29, 2010 | 2000 Saturn L-Series
Just had aiwa cdc x204 stolen from car but they left wiring harness intack. Cannot find this stereo anywhere. Is there another Aiwa or make that uses same wiring harness?
Most modern car stereos all use a standard plug (the name escapes me at present) so virtually any stereo should just plug in...
If your not sure, pop in to a motor parts place such as halfords and ask them to take a quick look at the wiring in your car... they will tell you weather it is standard or not...
Aug 27, 2010 | Aiwa CDC-X204 CD Player
Trouble codes for saturn ls2 car is showing the following trouble codes. po300, po306, po451 p2bo3 and c112b
P0300 Multiple Cylinder Misfire Detected
P0306 Cylinder 6 Misfire Detected
P0451 EVAP Pressure Sensor Range/Performance
I have no idea what those last two are. Typo, maybe?
Your first two codes could be caused by old spark plugs and/or leaking plug wires.
Your EVAP code could be a bad fuel tank pressure sensor or a malfunctioning EVAP system. With that code, if you remove your fuel cap and get a whoosing sound, then it is an issue with your EVAP system not properly venting the tank. If you don't get that sound, then the tank pressure sensor is bad.
Mar 05, 2010 | 2000 Saturn Ls 4dr Sedan
AiWa stuck on mute - no sound from subs.
have you tried powering down unit and seeing what happens?
Dec 02, 2009 | Aiwa CDC-X227 CD Player
I have a aiwa cdc-x176m car stereo The sound is muted and cannot figure it out does it contain a battery
i have never seen a car stereo with its own battery - could be something as simple as a bad ground - don't rely on the radio chasis and a screw that attaches it to the dash. make sure the black wire in the radio harness has a good ground
Oct 19, 2009 | Aiwa CDC-X176M
I just go an AIWA CDC-Mp3yu car cd player out of my jeep for my car but the plugs none match i found an adapter for the one with all the wires but cant find adapter for antenna an i need to know what the...
Jun 10, 2009 | Aiwa CDC-MP3 CD Player
No sound from my car stereo, a aiwa cdc-z137.
Doudle check rca's. Also check the setting in the menu browers. Make sure the mute overide is not on. Not sure if your model has it but is very common, and overlooked
May 13, 2009 | Aiwa CDC-Z137 CD Player
I need a wiring diagram for the aiwa stereo harness.
I would like to see a plug for a aiwa car stereo
Mar 30, 2009 | Aiwa CDC-X207 CD Player
I need a mauual for car stereo radio cdc-x227
Are you asking for Instruction Manual or Service Manual, please mention it.
Nov 28, 2008 | Aiwa CDC-X227 CD Player
Aiwa fm/am compact disc player cdc-x304 face plate
Mar 30, 2008 | Aiwa CDC-X304 CD Player
Aiwa CDC-MP3 CD Player Logo
54 people viewed this question
Top Aiwa Car Audio & Video Experts
Greg Cann
Greg Cann
fordexpert
Andrew Taylor
Andrew Taylor
Are you an Aiwa Car Audio and Video Expert? Answer questions, earn points and help others
